300DCRNC404
300DCRNC404
    ALPHAWIRE(阿尔法电线)
    M12MRECEPREAR4POLE
300DCRNC404 数据手册
Customer Specification PART NO: DCR Series M12-A Male Rear Mount PG9 Receptacle Drawing Issue: 1 Issue Date: 8/8/2016 Effective Date: 8/8/2016 Technical Data Mechanical Receptacle Style Applicable Specification Receptacle Threads Housing Insert Contact Mounting Orientation Panel Nut O-Ring Electrical Contact Resistance Nom. Current @ 40°C Rated Voltage UL File Lead Wires AWG Insulation Outside Diameter Lead Length UL Style CSA Style Environmental Degree of Protection Operating Temperature Range M12, Male IEC 61076-2-101 External Nickel Plated Brass, Leads Epoxy Potted Nylon Copper Alloy, Gold Plated Rear Nickel Plated Brass FKM ≤ 5 mΩ 4A 4 Pole 250 V (IEC) 300V (UL) 5 Pole 60 V (IEC) 30V (UL) E485156 22 AWG (7/30) Tinned Copper PVC 0.062” Nominal 0.5 Meters (19.7”) AWM 1007 & 1569 TR64 IP 67/ NEMA 6P -25C (-13F)/ +90C (+194F) ••••••••••••••••••••••••••••••••••••••• Alpha Wire | 711 Lidgerwood Ave, Elizabeth, NJ 07207 www.alphawire.com | 1-800-52 ALPHA 1 Customer Specification PART NO: DCR Series M12-A Male Rear Mount PG9 Receptacle CE REACH Regulation (EC 1907/2006) Issue: 1 issue Date: 8/4/2016 Effective Date: 8/4/2016 Ordering Information 300DCR NC404 302DCR NC404 All materials used in the manufacture of this part meet the requirements of European Directive 2011/65/EU regarding the restriction of use of certain hazardous substances in electrical and electronic equipment. Exemption used; 6a. This product does not contain Substances of Very High Concern (SVHC) listed on the European Union’s REACH candidate list in excess of 0.1% mass of the item. Description 4 Pin 5 Pin Quantity Each Each Although Alpha Wire (“Alpha”) makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Alpha provides the information and specification herein on an “AS IS” basis, with no representations or warranties, whether express, statutory or implied. In no event will Alpha be liable any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Alpha has been advised of the possibility of such damages, whether in an action under contact, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specification described herein. ••••••••••••••••••••••••••••••••••••••• Alpha Wire | 711 Lidgerwood Ave, Elizabeth, NJ 07207 www.alphawire.com | 1-800-52 ALPHA 2
300DCRNC404 价格&库存
很抱歉,暂时无法提供与“300DCRNC404”相匹配的价格&库存,您可以联系我们找货
