2-Meter Mini-Con-X® & EN3® Standard Cable Assemblies
NPB 630
Blunt cut on opposite end
for maximum flexibility
High quality, factory
overmolded connectors
Color coded, tissue paper
separated conductor wires
for easy termination
Cable selected by Switchcraft/
Conxall to withstand harsh
environments
Standard 2-Meter
(79”) Lengths
FEATURES
CABLE SPECIFICATIONS
High quality molded cables now available as a
standard, off-the-shelf item
Single ended cable with blunt cut
Straight or right angle connector options
2, 3, 4, 6, or 8 conductor versions available
Made in the USA
Molded 360° Flex Relief (EN3™ only)
Call factory for custom lengths and other
configurable options
See drawings on Switchcraft.com for detailed
specifications
Rated for 300 V
-30° C TO +105° C temperature rating
Jacket Material: 30 mils PVC, black
Conductor Insulation: 15 mils PVC
UV & water resistant
UL Recognized, CSA Certified, and
RoHS Compliant
SWITCHCRAFT: 5555 N ELSTON AVE, CHICAGO, IL 60630-773.792.2700 -SALES@SWITCHCRAFT.COM
CONXALL: 601 East WILDWOOD, VILLA PARK, IL 60181 - 630.834.7504 - SALES@CONXALL.COM
NPB 630
DETAILS AND AVAILABLE PART NUMBERS
Seal Rating
Voltage Rating
Life Rating
UV Resistance
Flex Relief
Configuration
Straight, 2-pos, Male
Straight, 2-pos, Female
Straight, 3-pos, Male
Straight, 3-pos, Female
Straight, 4-pos, Male
Straight, 4-pos, Female
Straight, 5-pos, Male
Straight, 5-pos, Female
Straight, 6-pos, Male
Straight, 6-pos, Female
Straight, 8-pos, Female
Right Angle, 2-pos, Male
Right Angle, 2-pos, Female
Right Angle, 3-pos, Male
Right Angle, 3-pos, Female
Right Angle, 4-pos, Male
Right Angle, 4-pos, Female
Right Angle, 5-pos, Male
Right Angle, 5-pos, Female
Right Angle, 6-pos, Male
Right Angle, 6-pos, Female
EN3®
IP68, integrated O-ring
250V, AC/DC
600 Insertion/Withdrawal Cycles
UL F1 Rated Materials
EN3® Part Number
CAEN3C2M07990
CAEN3C2F07990
CAEN3C3M07990
CAEN3C3F07990
CAEN3C4M07990
CAEN3C4F07990
CAEN3C5M07990
CAEN3C5F07990
CAEN3C6M07990
CAEN3C6F07990
CAEN3C8F07990
CARAEN3C2M07990
CARAEN3C2F07990
CARAEN3C3M07990
CARAEN3C3F07990
CARAEN3C4M07990
CARAEN3C4F07990
CARAEN3C5M07990
CARAEN3C5F07990
CARAEN3C6M07990
CARAEN3C6F07990
Mini-Con-X®
IP67, separate O-ring
300V, AC/DC
300 Insertion/Withdrawal Cycles
Not Rated (Custom UV rated cables
available, call factory)
Not Available
Mini-Con-X® Part Number
CA62802P07990
CA62802S07990
CA62803P07990
CA62803S07990
CA62804P07990
CA62804S07990
CA62805P07990
CA62805S07990
CA62806P07990
CA62806S07990
CA62808S07990
CARA62802P07990
CARA62802S07990
CARA62803P07990
CARA62803S07990
CARA62804P07990
CARA62804S07990
CARA62805P07990
CARA62805S07990
CARA62806P07990
CARA62806S07990
VISIT WWW.SWITCHCRAFT.COM FOR MORE PRODUCTS AND DETAILED SPECIFICATIONS
NPB 630
CONNECTOR DIMENSIONS (Ref Only)
1.50
38.1
POLARIZATION KEY
6 O'CLOCK
1.375
[34.9]
POLARIZATION KEY
12 O'CLOCK
0.92
23.4
0.70
17.8
1.57
39.8
0.70
17.8
1.109
[28.2]
1.69
42.9
1.92
48.6
0.71
18.0
2.46
62.5
1.88
47.8
0.65
16.5
CAEN3________
CARAEN3_______
CA6280________
CARA6280________
CONTACT LAYOUTS (Connector Face Side)
KEY
KEY
1
2
2
4
1
3
3 POSITION
#20 PIN & SOCKET
CONTACT
2
4 POSITION
#20 PIN & SOCKET
CONTACT
2
3
KEY
KEY
1
5
4
3
2 POSITION
#20 PIN & SOCKET
CONTACT
KEY
KEY
1
5 POSITION
#20 PIN & SOCKET
CONTACT
1
4
1
7
8
6
2
6
3
5
3
5
4
6 POSITION
#20 PIN & SOCKET
CONTACT
2
8 POSITION
#20 SOCKET
CONTACT
Mating Parts
Cable Part Number
CAEN3C2M07990
CAEN3C2F07990
CAEN3C3M07990
CAEN3C3F07990
CAEN3C4M07990
CAEN3C4F07990
CAEN3C5M07990
CAEN3C5F07990
CAEN3C6M07990
CAEN3C6F07990
CAEN3C8F07990
CARAEN3C2M07990
CARAEN3C2F07990
CARAEN3C3M07990
CARAEN3C3F07990
CARAEN3C4M07990
CARAEN3C4F07990
CARAEN3C5M07990
CARAEN3C5F07990
CARAEN3C6M07990
CARAEN3C6F07990
CARAEN3C8F07990
Mating Cable-to-Cable*
EN3L2FX
EN3L2MX
EN3L3FX
EN3L3MX
EN3L4FX
EN3L4MX
EN3L5FX
EN3L5MX
EN3L6FX
EN3L6MX
EN3L8MX
EN3L2FX
EN3L2MX
EN3L3FX
EN3L3MX
EN3L4FX
EN3L4MX
EN3L5FX
EN3L5MX
EN3L6FX
EN3L6MX
EN3L8MX
Mating Panel Mount*
EN3P2FX
EN3P2MX
EN3P3FX
EN3P3MX
EN3P4FX
EN3P4MX
EN3P5FX
EN3P5MX
EN3P6FX
EN3P6MX
EN3P8MX
EN3P2FX
EN3P2MX
EN3P3FX
EN3P3MX
EN3P4FX
EN3P4MX
EN3P5FX
EN3P5MX
EN3P6FX
EN3P6MX
EN3P8MX
Column1
Cable Part Number
CA62802P07990
CA62802S07990
CA62803P07990
CA62803S07990
CA62804P07990
CA62804S07990
CA62805P07990
CA62805S07990
CA62806P07990
CA62806S07990
CA62808S07990
CARA62802P07990
CARA62802S07990
CARA62803P07990
CARA62803S07990
CARA62804P07990
CARA62804S07990
CARA62805P07990
CARA62805S07990
CARA62806P07990
CARA62806S07990
CARA62808S07990
8282-2SG-3DC
8282-2PG-3DC
8282-3SG-3DC
8282-3PG-3DC
8282-4SG-3DC
8282-4PG-3DC
8282-5SG-3DC
8282-5PG-3DC
8282-6SG-3DC
8282-6PG-3DC
8282-8PG-3DC
8282-2SG-3DC
8282-2PG-3DC
8282-3SG-3DC
8282-3PG-3DC
8282-4SG-3DC
8282-4PG-3DC
8282-5SG-3DC
8282-5PG-3DC
8282-6SG-3DC
8282-6PG-3DC
8282-8PG-3DC
Mating Panel Mount*
7282-2SG-300
7282-2PG-300
7282-3SG-300
7282-3PG-300
7282-4SG-300
7282-4PG-300
7282-5SG-300
7282-5PG-300
7282-6SG-300
7282-6PG-300
7282-8PG-300
7282-2SG-300
7282-2PG-300
7282-3SG-300
7282-3PG-300
7282-4SG-300
7282-4PG-300
7282-5SG-300
7282-5PG-300
7282-6SG-300
7282-6PG-300
7282-8PG-300
*Additional configurations, backshell & grommet sizes, and mounting styles available. Visit Switchcraft.com for full product listing.
VISIT WWW.SWITCHCRAFT.COM FOR THE MOST UP-TO-DATE PRODUCT SPECIFICATIONS
