DR0500102SL358
DR0500102SL358
    ALPHAWIRE(阿尔法电线)
    M12MTOCUT22AWG08POL
DR0500102SL358 数据手册
Customer Specification PART NO: DR0500102 M12-A Male Issue: 1 Issue Date: 7/29/2016 Effective Date: 7/29/2016 Drawings Technical Data Cordage Construction Cordage Part Number Component 1 a) Conductor b) Insulation Insulation Colors Jacket a) Color(s) Cord Configuration End 1 End 2 Insert Mold Color Contact Coupling Nut O-Ring Available Lengths Applicable SpecificationsCable Diameters (In) 102 5 COND 22 (26/36) AWG Bare Copper 0.010” Wall, Nom. mPPE Black, White, Brown, Blue & Green/Yellow 0.040” Wall, Nom. PUR, Zero Halogen SLATE 0.027 0.047 0.213 M12-A Male Cut End Black TPU Black TPU Copper Alloy, Gold plated Copper Alloy, Nickel plated FKM 0.6, 1, 3, 5, 10, 15, 20 Meters ••••••••••••••••••••••••••••••••••••••• Alpha Wire | 711 Lidgerwood Ave, Elizabeth, NJ 07207 www.alphawire.com | 1-800-52 ALPHA 1 Customer Specification PART NO: DR0500102 M12-A Male UL CSA International Applicable SpecificationsCord Set UL CSA Nominal Voltage Rated Voltage Ingress Protection Environmental Compliance CE REACH Regulation (EC 1907/2006) Physical & Mechanical Properties Temperature Range, Cord Temperature Range, Connector Bend Radius Pull Tension Current Rating Ordering Information DR0500102 SL355 DR0500102 SL356 DR0500102 SL357 DR0500102 SL358 DR0500102 SL359 DR0500102 SL400 DR0500102 SL401 Standard Package AWM/STYLE 20549 AWM/STYLE 21959 C(RU) AWM I/II A/B FT1 80°C / 300 V RMS 90°C / 600 V RMS 90°C / 600 V RMS ANSI/UL 2238, Cable Assembly Extension RU, UL File Number E485156 CSA-C22.2 No. 182.3, Special Use Attachment Plugs, Receptacles and Connectors cRU, UL File Number E485156 60 V 63 V IP67/NEMA 6P All materials used in the manufacture of this part meet the requirements of European Directive 2011/65/EU regarding the restriction of use of certain hazardous substances in electrical and electronic equipment. Exemption used; 6a. This product does not contain Substances of Very High Concern (SVHC) listed on the European Union’s REACH candidate list in excess of 0.1% mass of the item. -50 to 90°C(static), -40 to 80°C (dynamic) -25°C to +80°C 4X Cable Diameter (static), 6X Cable Diameter (dynamic) 20.4 Lbs, Maximum 2.2 Amps @ 50°C 0.6 Meters 1.0 Meters 3.0 Meters 5.0 Meters 10.0 Meters 15.0 Meters 20.0 Meters Each ••••••••••••••••••••••••••••••••••••••• Although Alpha Wire (“Alpha”) makesWire every|reasonable effort to ensure accuracy at time of this publication, information and Alpha 711 Lidgerwood Ave,their Elizabeth, NJthe07207 specifications described herein are subject to error or omission and |to1-800-52 change without notice, and the listing of such information and 2 www.alphawire.com ALPHA specifications does not ensure product availability. Alpha provides the information and specification herein on an “AS IS” basis, with no representations or warranties, whether express, statutory or implied. In no event will Alpha be liable any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Alpha has been advised of the possibility of such damages,
DR0500102SL358 价格&库存
很抱歉,暂时无法提供与“DR0500102SL358”相匹配的价格&库存,您可以联系我们找货
