AW0400101SL358
AW0400101SL358
    ALPHAWIRE(阿尔法电线)
    M12F90DEGTOCUT24AWG08POL
AW0400101SL358 数据手册
Customer Specification PART NO: AW0400101 M12-A Female 90 Degree Drawings Issue: 1 Issue Date: 7/29/2016 Effective Date: 7/29/2016 Technical Data Cordage Construction Cordage Part Number Component 1 a) Conductor b) Insulation Insulation Colors Jacket a) Color(s) Cord Configuration End 1 End 2 Insert Mold Color Contact Coupling Nut O-Ring Available Lengths Applicable SpecificationsCable UL Diameters (In) 101 4 COND 22 (26/36) AWG Bare Copper 0.010” Wall, Nom. mPPE Black, White, Brown & Blue 0.040” Wall, Nom. PUR, Zero Halogen SLATE 0.027 0.047 0.200 M12-A Female, 90 Degree Cut End Black TPU Black TPU Copper Alloy, Gold plated Copper Alloy, Nickel plated FKM 0.6, 1, 3, 5, 10, 15, 20 Meters AWM/STYLE 20549 AWM/STYLE 21959 ••••••••••••••••••••••••••••••••••••••• Alpha Wire | 711 Lidgerwood Ave, Elizabeth, NJ 07207 www.alphawire.com | 1-800-52 ALPHA 80°C / 300 V RMS 90°C / 600 V RMS 1 Customer Specification PART NO: AW0400101 M12-A Female 90 Degree CSA International Applicable SpecificationsCord Set UL CSA Nominal Voltage Rated Voltage Ingress Protection Environmental Compliance CE REACH Regulation (EC 1907/2006) Physical & Mechanical Properties Temperature Range, Cord Temperature Range, Connector Bend Radius Pull Tension Current Rating Ordering Information AW0400101 SL355 AW0400101 SL356 AW0400101 SL357 AW0400101 SL358 AW0400101 SL359 AW0400101 SL400 AW0400101 SL401 Standard Package C(RU) AWM I/II A/B FT1 90°C / 600 V RMS ANSI/UL 2238, Cable Assembly Extension RU, UL File Number E485156 CSA-C22.2 No. 182.3, Special Use Attachment Plugs, Receptacles and Connectors cRU, UL File Number E485156 240 V 250 V IP67/NEMA 6P All materials used in the manufacture of this part meet the requirements of European Directive 2011/65/EU regarding the restriction of use of certain hazardous substances in electrical and electronic equipment. Exemption used; 6a. This product does not contain Substances of Very High Concern (SVHC) listed on the European Union’s REACH candidate list in excess of 0.1% mass of the item. -50 to 90°C(static), -40 to 80°C (dynamic) -25°C to +80°C 4X Cable Diameter (static), 6X Cable Diameter (dynamic) 20.4 Lbs, Maximum 2.2 Amps @ 50°C 0.6 Meters 1.0 Meters 3.0 Meters 5.0 Meters 10.0 Meters 15.0 Meters 20.0 Meters Each Although Alpha Wire (“Alpha”) makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and • •product • • • • •availability. • • • • • • Alpha • • • •provides • • • • • the • • •information • • • • • • •and • • specification ••••• specifications does not ensure herein on an “AS IS” basis, with no Alpha Wire | 711 Lidgerwood Ave, NJ 07207 representations or warranties, whether express, statutory or implied. In noElizabeth, event will Alpha be liable any damages (including consequential, 2 www.alphawire.com | 1-800-52 indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if ALPHA Alpha has been advised of the possibility of such damages, whether in an action under contact, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specification described herein.
AW0400101SL358 价格&库存
很抱歉,暂时无法提供与“AW0400101SL358”相匹配的价格&库存,您可以联系我们找货
