DR08AR123SL356
DR08AR123SL356
    ALPHAWIRE(阿尔法电线)
    M23FSTRTOCUTEND19PZHPUR
DR08AR123SL356 数据手册
Customer Specification PART NO: DR08AR123 M12-A Male to M12-A Female Drawings Issue: 1 Issue Date: 7/29/2016 Effective Date: 7/29/2016 Technical Data Cordage Construction Cordage Part Number Component 1 a) Conductor b) Insulation Insulation Colors Jacket a) Color(s) Cord Configuration End 1 End 2 Insert Mold Color Contact Coupling Nut O-Ring Available Lengths Applicable SpecificationsCable UL CSA International Diameters (In) 123 8 COND 22 (26/36) AWG Bare Copper 0.010” Wall, Nom. mPPE White, Brown, Green, Yellow, Grey, Pink, Blue & Red 0.040” Wall, Nom. PUR, Zero Halogen SLATE 0.027 0.047 0.258 M12-A Male M12-A Female Black TPU Black TPU Copper Alloy, Gold plated Copper Alloy, Nickel plated FKM 0.6, 1, 3, 5, 10, 15, 20 Meters AWM/STYLE 20549 AWM/STYLE 21959 C(RU) AWM I/II A/B FT1 ••••••••••••••••••••••••••••••••••••••• Alpha Wire | 711 Lidgerwood Ave, Elizabeth, NJ 07207 www.alphawire.com | 1-800-52 ALPHA 80°C / 300 V RMS 90°C / 600 V RMS 90°C / 600 V RMS 1 Customer Specification PART NO: DR08AR123 M12-A Male to M12-A Female Applicable SpecificationsCord Set UL CSA Nominal Voltage Rated Voltage Ingress Protection Environmental Compliance CE REACH Regulation (EC 1907/2006) Physical & Mechanical Properties Temperature Range, Cord Temperature Range, Connector Bend Radius Pull Tension Current Rating Ordering Information DR08AR123 SL355 DR08AR123 SL356 DR08AR123 SL357 DR08AR123 SL358 DR08AR123 SL359 DR08AR123 SL400 DR08AR123 SL401 Standard Package ANSI/UL 2238, Cable Assembly Extension RU, UL File Number E485156 CSA-C22.2 No. 182.3, Special Use Attachment Plugs, Receptacles and Connectors cRU, UL File Number E485156 30 V 36 V IP67/NEMA 6P All materials used in the manufacture of this part meet the requirements of European Directive 2011/65/EU regarding the restriction of use of certain hazardous substances in electrical and electronic equipment. Exemption used; 6a. This product does not contain Substances of Very High Concern (SVHC) listed on the European Union’s REACH candidate list in excess of 0.1% mass of the item. -50 to 90°C(static), -40 to 80°C (dynamic) -25°C to +80°C 4X Cable Diameter (static), 6X Cable Diameter (dynamic) 41 Lbs, Maximum 1.9 Amps @ 50°C 0.6 Meters 1.0 Meters 3.0 Meters 5.0 Meters 10.0 Meters 15.0 Meters 20.0 Meters Each Although Alpha Wire (“Alpha”) makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Alpha provides the information and specification herein on an “AS IS” basis, with no representations or warranties, • •whether • • • • •express, • • • • •statutory • • • • • •or• implied. • • • • • In• •no• event • • • •will • • Alpha • • • •be • •liable any damages (including consequential, Alpha or Wire | 711 damages) Lidgerwood Ave, Elizabeth, NJ been 07207 indirect, incidental, special, punitive, exemplary whatsoever, even if Alpha has advised of the possibility of such damages, whether in an action under contact, negligence or any other theory,|arising out ofALPHA or in connection with the use, or inability to use, the 2 www.alphawire.com 1-800-52 information or specification described herein.
DR08AR123SL356 价格&库存
很抱歉,暂时无法提供与“DR08AR123SL356”相匹配的价格&库存,您可以联系我们找货
