AW0500106SL359
AW0500106SL359
    ALPHAWIRE(阿尔法电线)
    M12MSTRTOCUT22AWG03POL
AW0500106SL359 数据手册
Customer Specification PART NO: AW0500106 M12-A Female 90 Degree Drawings Issue: 1 Issue Date: 7/29/2016 Effective Date: 7/29/2016 Technical Data Cordage Construction Cordage Part Number Component 1 a) Conductor b) Insulation Insulation Colors Jacket a) Color(s) Cord Configuration End 1 End 2 Insert Mold Color Contact Coupling Nut O-Ring Available Lengths Applicable SpecificationsCable UL CSA International Diameters (In) 106 5 COND 22 (26/36) AWG Bare Copper 0.011” Wall, Nom. SR-PVC Black, White, Brown, Blue & Green/Yellow 0.040” Wall, Nom. PVC SLATE 0.027 0.049 0.220 M12-A Female, 90 Degree Cut End Black TPU Black TPU Copper Alloy, Gold plated Copper Alloy, Nickel plated FKM 0.6, 1, 3, 5, 10, 15, 20 Meters AWM/STYLE 2661 C(RU) AWM I/II A/B FT1 ••••••••••••••••••••••••••••••••••••••• Alpha Wire | 711 Lidgerwood Ave, Elizabeth, NJ 07207 www.alphawire.com | 1-800-52 ALPHA 105°C / 300 V RMS 105°C / 300 V RMS 1 Customer Specification PART NO: AW0500106 M12-A Female 90 Degree Applicable SpecificationsCord Set UL CSA Nominal Voltage Rated Voltage Ingress Protection Environmental Compliance CE REACH Regulation (EC 1907/2006) Physical & Mechanical Properties Temperature Range, Cord Temperature Range, Connector Bend Radius Pull Tension Current Rating Ordering Information AW0500106 SL355 AW0500106 SL356 AW0500106 SL357 AW0500106 SL358 AW0500106 SL359 AW0500106 SL400 AW0500106 SL401 Standard Package ANSI/UL 2238, Cable Assembly Extension RU, UL File Number E485156 CSA-C22.2 No. 182.3, Special Use Attachment Plugs, Receptacles and Connectors cRU, UL File Number E485156 60 V 63 V IP67/NEMA 6P All materials used in the manufacture of this part meet the requirements of European Directive 2011/65/EU regarding the restriction of use of certain hazardous substances in electrical and electronic equipment. Exemption used; 6a. This product does not contain Substances of Very High Concern (SVHC) listed on the European Union’s REACH candidate list in excess of 0.1% mass of the item. -40 to 105°C(static), -15 to 105°C (dynamic) -25°C to +80°C 7X Cable Diameter (static), 10X Cable Diameter (dynamic) 26 Lbs, Maximum 2.5 Amps @ 50°C 0.6 Meters 1.0 Meters 3.0 Meters 5.0 Meters 10.0 Meters 15.0 Meters 20.0 Meters Each Although Alpha Wire (“Alpha”) makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Alpha provides the information and specification herein on an “AS IS” basis, with no representations or warranties, • •whether • • • • •express, • • • • •statutory • • • • • •or• implied. • • • • • In• •no• event • • • •will • • Alpha • • • •be • •liable any damages (including consequential, Alpha or Wire | 711 damages) Lidgerwood Ave, Elizabeth, NJ been 07207 indirect, incidental, special, punitive, exemplary whatsoever, even if Alpha has advised of the possibility of such damages, whether in an action under contact, negligence or any other theory,|arising out ofALPHA or in connection with the use, or inability to use, the 2 www.alphawire.com 1-800-52 information or specification described herein.
AW0500106SL359
1. 物料型号:型号为BQ25895RGER,是一款由德州仪器(Texas Instruments)生产的单节电池充电器。
2. 器件简介:BQ25895RGER是一款专为USB供电设备设计的单节电池充电器,支持USB Type-C和USB Power Delivery(PD)。
3. 引脚分配:该芯片共有31个引脚,包括电源引脚、控制引脚和通信引脚等。
4. 参数特性:包括输入电压范围、充电电流、充电电压等参数。
5. 功能详解:详细介绍了芯片的充电管理功能,包括恒流充电、恒压充电、温度监控等。
6. 应用信息:适用于需要单节电池充电的便携式电子设备。
7. 封装信息:采用40引脚的QFN封装。
AW0500106SL359 价格&库存
很抱歉,暂时无法提供与“AW0500106SL359”相匹配的价格&库存,您可以联系我们找货
