DR0800112SL356
DR0800112SL356
    ALPHAWIRE(阿尔法电线)
    M12MSTRTOM12FSTR24AWG08L
DR0800112SL356 数据手册
Customer Specification PART NO: DR0800112 M12-A Male Issue: 1 Issue Date: 7/29/2016 Effective Date: 7/29/2016 Drawings Technical Data Cordage Construction Cordage Part Number Component 1 a) Conductor b) Insulation Insulation Colors Jacket a) Color(s) Cord Configuration End 1 End 2 Insert Mold Color Contact Coupling Nut O-Ring Available Lengths Diameters (In) 112 8 COND 22 (26/36) AWG Bare Copper 0.010” Wall, Nom. SR-PVC White, Brown, Green, Yellow, Grey, Pink, Blue & Red 0.032” Wall, Nom. TPE SLATE 0.027 0.047 0.255 M12-A Male Cut End Black TPU Black TPU Copper Alloy, Gold plated Copper Alloy, Nickel plated FKM 0.6, 1, 3, 5, 10, 15, 20 Meters ••••••••••••••••••••••••••••••••••••••• Alpha Wire | 711 Lidgerwood Ave, Elizabeth, NJ 07207 www.alphawire.com | 1-800-52 ALPHA 1 Customer Specification PART NO: DR0800112 M12-A Male Applicable SpecificationsCable UL CSA International Applicable SpecificationsCord Set UL CSA Nominal Voltage Rated Voltage Ingress Protection Environmental Compliance CE REACH Regulation (EC 1907/2006) Physical & Mechanical Properties Temperature Range, Cord Temperature Range, Connector Bend Radius Pull Tension Current Rating Ordering Information DR0800112 SL355 DR0800112 SL356 DR0800112 SL357 DR0800112 SL358 DR0800112 SL359 DR0800112 SL400 DR0800112 SL401 Standard Package AWM/STYLE 20327 PLTC C(RU) AWM I/II A/B FT4 105°C / 300 V RMS 105°C 105°C / 300 V RMS ANSI/UL 2238, Cable Assembly Extension RU, UL File Number E485156 CSA-C22.2 No. 182.3, Special Use Attachment Plugs, Receptacles and Connectors cRU, UL File Number E485156 30 V 36 V IP67/NEMA 6P All materials used in the manufacture of this part meet the requirements of European Directive 2011/65/EU regarding the restriction of use of certain hazardous substances in electrical and electronic equipment. Exemption used; 6a. This product does not contain Substances of Very High Concern (SVHC) listed on the European Union’s REACH candidate list in excess of 0.1% mass of the item. -35 to 105°C(static), -15 to 90°C (dynamic) -25°C to +80°C 7X Cable Diameter (static), 10X Cable Diameter (dynamic) 41 Lbs, Maximum 2.2 Amps @ 50°C 0.6 Meters 1.0 Meters 3.0 Meters 5.0 Meters 10.0 Meters 15.0 Meters 20.0 Meters Each ••••••••••••••••••••••••••••••••••••••• Alpha Wire | 711 Lidgerwood Ave, Elizabeth, NJ 07207 www.alphawire.com | 1-800-52 ALPHA 2 Customer Specification PART NO: DR0800112 M12-A Male Although Alpha Wire (“Alpha”) makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Alpha provides the information and specification herein on an “AS IS” basis, with no representations or warranties, whether express, statutory or implied. In no event will Alpha be liable any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Alpha has been advised of the possibility of such damages, whether in an action under contact, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specification described herein. ••••••••••••••••••••••••••••••••••••••• Alpha Wire | 711 Lidgerwood Ave, Elizabeth, NJ 07207 www.alphawire.com | 1-800-52 ALPHA 3
DR0800112SL356 价格&库存
很抱歉,暂时无法提供与“DR0800112SL356”相匹配的价格&库存,您可以联系我们找货
