Customer Specification
PART NO: KW0500115
Mini Female 7/8” 90 Degree
Drawings
Issue: 1 Issue Date: 8/1/2016 Effective Date: 8/1/2016
Technical Data
Cordage Construction
Cordage Part Number
Component 1
a) Conductor
b) Insulation
Insulation Colors
Jacket
a) Color(s)
Cord Configuration
End 1
End 2
Insert
Mold Color
Contact
Coupling Nut
Available Lengths
Applicable SpecificationsCable
UL
CSA International
Applicable SpecificationsCord Set
Diameters (In)
115
5 COND
16 (65/34) AWG Bare Copper
0.016" Wall, Nom. PVC/ 0.005" Wall Nylon
White, Red, Green/Yellow, Orange, Black
0.050” Wall, Nom. TPE
YELLOW
0.059
0.101
0.380
Cut End
Yellow TPU
Yellow TPU
Copper Alloy, Gold over Silver plated
Aluminum, anodized black
0.6, 1, 3, 5, 10, 15, 20 Meters
TC-ER
SUN RES
OIL RES I/II
AWM/STYLE 20327
C(UL) CIC Control/TC
FT4
Alpha Wire | 711 Lidgerwood Ave, Elizabeth, NJ 07207
www.alphawire.com | 1-800-52 ALPHA
90°C Dry/75°C Wet
600 V RMS
90°C Dry/75°C Wet
600 V RMS
1
PART NO: KW0500115
UL
CSA
Ingress Protection
Environmental Compliance
CE
REACH Regulation (EC
1907/2006)
Physical & Mechanical
Properties
Temperature Range, Cord
Bend Radius
Pull Tension
Current Rating
Ordering Information
KW0500115 YL355
KW0500115 YL356
KW0500115 YL357
KW0500115 YL358
KW0500115 YL359
KW0500115 YL400
KW0500115 YL401
Standard Package
ANSI/UL 2238, Cable Assembly Extension
RU, UL File Number E485156
CSA-C22.2 No. 182.3, Special Use
Attachment Plugs, Receptacles and
Connectors
cRU, UL File Number E485156
IP67
All materials used in the manufacture of
this part meet the requirements of
European Directive 2011/65/EU regarding
the restriction of use of certain hazardous
substances in electrical and electronic
equipment. Exemption used; 6a.
This product does not contain Substances
of Very High Concern (SVHC) listed on the
European Union’s REACH candidate list in
excess of 0.1% mass of the item.
-30 to 90°C(static), -15 to 90°C (dynamic)
7X Cable Diameter (static), 10X Cable
Diameter (dynamic)
101 Lbs, Maximum
7.3 Amps @ 50°C
0.6 Meters
1.0 Meters
3.0 Meters
5.0 Meters
10.0 Meters
15.0 Meters
20.0 Meters
Each
Although Alpha Wire (“Alpha”) makes every reasonable effort to ensure their accuracy at the time of this publication, information and
specifications described herein are subject to error or omission and to change without notice, and the listing of such information and
specifications does not ensure product availability. Alpha provides the information and specification herein on an “AS IS” basis, with no
representations or warranties, whether express, statutory or implied. In no event will Alpha be liable any damages (including consequential,
indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Alpha has been advised of the possibility of such damages,
whether in an action under contact, negligence or any other theory, arising out of or in connection with the use, or inability to use, the
information or specification described herein.
2
很抱歉,暂时无法提供与“KW0500115YL356”相匹配的价格&库存,您可以联系我们找货
