DR0800123SL401
DR0800123SL401
    ALPHAWIRE(阿尔法电线)
    CBLM12M8POSTOCUT22AWG20M
DR0800123SL401 数据手册
Customer Specification PART NO: DR0800123 M12-A Male Issue: 1 Issue Date: 7/29/2016 Effective Date: 7/29/2016 Drawings Technical Data Cordage Construction Cordage Part Number Component 1 a) Conductor b) Insulation Insulation Colors Jacket a) Color(s) Cord Configuration End 1 End 2 Insert Mold Color Contact Coupling Nut O-Ring Available Lengths Diameters (In) 123 8 COND 22 (26/36) AWG Bare Copper 0.010” Wall, Nom. mPPE White, Brown, Green, Yellow, Grey, Pink, Blue & Red 0.040” Wall, Nom. PUR, Zero Halogen SLATE 0.027 0.047 0.258 M12-A Male Cut End Black TPU Black TPU Copper Alloy, Gold plated Copper Alloy, Nickel plated FKM 0.6, 1, 3, 5, 10, 15, 20 Meters ••••••••••••••••••••••••••••••••••••••• Alpha Wire | 711 Lidgerwood Ave, Elizabeth, NJ 07207 www.alphawire.com | 1-800-52 ALPHA 1 Customer Specification PART NO: DR0800123 M12-A Male Applicable SpecificationsCable UL CSA International Applicable SpecificationsCord Set UL CSA Nominal Voltage Rated Voltage Ingress Protection Environmental Compliance CE REACH Regulation (EC 1907/2006) Physical & Mechanical Properties Temperature Range, Cord Temperature Range, Connector Bend Radius Pull Tension Current Rating Ordering Information DR0800123 SL355 DR0800123 SL356 DR0800123 SL357 DR0800123 SL358 DR0800123 SL359 DR0800123 SL400 DR0800123 SL401 Standard Package AWM/STYLE 20549 AWM/STYLE 21959 C(RU) AWM I/II A/B FT1 80°C / 300 V RMS 90°C / 600 V RMS 90°C / 600 V RMS ANSI/UL 2238, Cable Assembly Extension RU, UL File Number E485156 CSA-C22.2 No. 182.3, Special Use Attachment Plugs, Receptacles and Connectors cRU, UL File Number E485156 30 V 36 V IP67/NEMA 6P All materials used in the manufacture of this part meet the requirements of European Directive 2011/65/EU regarding the restriction of use of certain hazardous substances in electrical and electronic equipment. Exemption used; 6a. This product does not contain Substances of Very High Concern (SVHC) listed on the European Union’s REACH candidate list in excess of 0.1% mass of the item. -50 to 90°C(static), -40 to 80°C (dynamic) -25°C to +80°C 4X Cable Diameter (static), 6X Cable Diameter (dynamic) 41 Lbs, Maximum 1.9 Amps @ 50°C 0.6 Meters 1.0 Meters 3.0 Meters 5.0 Meters 10.0 Meters 15.0 Meters 20.0 Meters Each ••••••••••••••••••••••••••••••••••••••• Alpha Wire | 711 Lidgerwood Ave, Elizabeth, NJ 07207 www.alphawire.com | 1-800-52 ALPHA 2 Customer Specification PART NO: DR0800123 M12-A Male Although Alpha Wire (“Alpha”) makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Alpha provides the information and specification herein on an “AS IS” basis, with no representations or warranties, whether express, statutory or implied. In no event will Alpha be liable any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Alpha has been advised of the possibility of such damages, whether in an action under contact, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specification described herein. ••••••••••••••••••••••••••••••••••••••• Alpha Wire | 711 Lidgerwood Ave, Elizabeth, NJ 07207 www.alphawire.com | 1-800-52 ALPHA 3
DR0800123SL401
物料型号:DR0800123 器件简介:AlphaWire 提供的电缆,型号为 M12-A Male。 引脚分配:共有8个引脚,颜色分别为白、棕、绿、黄、灰、粉红、蓝和屏蔽。 参数特性:导体为22 AWG裸露铜线,绝缘材料为名义0.010英寸壁厚的mPPE,颜色有白、棕、绿、黄、灰、粉红、蓝和红。护套为名义0.040英寸壁厚的PUR,无卤素,颜色为板岩灰。 功能详解:此电缆符合UL和CSA的多种规格,具有30V的标称电压和36V的额定电压。防护等级为IP67/NEMA 6P,环境合规性符合CE指令,不含有超过0.1%质量的REACH候选清单上的高关注物质(SVHC)。 应用信息:适用于静态-50至90°C和动态-40至80°C的温度范围,弯曲半径为静态4倍电缆直径,动态6倍电缆直径,最大拉力为41磅,电流额定值为50°C时的1.9安培。 封装信息:提供0.6米至20米的不同长度选项,每个单独包装。
DR0800123SL401 价格&库存
很抱歉,暂时无法提供与“DR0800123SL401”相匹配的价格&库存,您可以联系我们找货
