KR0300107YL356
KR0300107YL356
    ALPHAWIRE(阿尔法电线)
    MINIMSTRTOCUT16AWG03POL
KR0300107YL356 数据手册
Customer Specification PART NO: KR0300107 Mini Female 7/8” Drawings Issue: 1 Issue Date: 7/29/2016 Effective Date: 7/29/2016 Technical Data Cordage Construction Cordage Part Number Component 1 a) Conductor b) Insulation Insulation Colors Jacket a) Color(s) Cord Configuration End 1 End 2 Insert Mold Color Contact Coupling Nut Available Lengths Applicable SpecificationsCable UL CSA International Applicable SpecificationsCord Set UL Diameters (In) 107 3 COND 18 (41/34) AWG Bare Copper 0.010” Wall, Nom. PVC, Semi Rigid Black, Brown & Blue 0.037” Wall, Nom. TPE YELLOW 0.043 0.063 0.216 Mini Female 7/8” Cut End Yellow TPU Yellow TPU Copper Alloy, Gold over Silver plated Aluminum, anodized black 0.6, 1, 3, 5, 10, 15, 20 Meters PLTC AWM/STYLE 20327 C(RU) AWM I/II A/B FT4 105°C 105°C / 300 V RMS 105°C / 300 V RMS ANSI/UL 2238, Cable Assembly Extension RU, UL File Number E485156 ••••••••••••••••••••••••••••••••••••••• Alpha Wire | 711 Lidgerwood Ave, Elizabeth, NJ 07207 www.alphawire.com | 1-800-52 ALPHA 1 Customer Specification PART NO: KR0300107 Mini Female 7/8” CSA Ingress Protection Environmental Compliance CE REACH Regulation (EC 1907/2006) Physical & Mechanical Properties Temperature Range, Cord Bend Radius Pull Tension Current Rating Ordering Information KR0300107 YL355 KR0300107 YL356 KR0300107 YL357 KR0300107 YL358 KR0300107 YL359 KR0300107 YL400 KR0300107 YL401 Standard Package CSA-C22.2 No. 182.3, Special Use Attachment Plugs, Receptacles and Connectors cRU, UL File Number E485156 IP67 All materials used in the manufacture of this part meet the requirements of European Directive 2011/65/EU regarding the restriction of use of certain hazardous substances in electrical and electronic equipment. Exemption used; 6a. This product does not contain Substances of Very High Concern (SVHC) listed on the European Union’s REACH candidate list in excess of 0.1% mass of the item. -35 to 90°C(static), -15 to 90°C (dynamic) 7X Cable Diameter (static), 10X Cable Diameter (dynamic) 38 Lbs, Maximum 6.4 Amps @ 50°C 0.6 Meters 1.0 Meters 3.0 Meters 5.0 Meters 10.0 Meters 15.0 Meters 20.0 Meters Each Although Alpha Wire (“Alpha”) makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Alpha provides the information and specification herein on an “AS IS” basis, with no representations or warranties, whether express, statutory or implied. In no event will Alpha be liable any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Alpha has been advised of the possibility of such damages, whether in an action under contact, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specification described herein. ••••••••••••••••••••••••••••••••••••••• Alpha Wire | 711 Lidgerwood Ave, Elizabeth, NJ 07207 www.alphawire.com | 1-800-52 ALPHA 2
KR0300107YL356 价格&库存
很抱歉,暂时无法提供与“KR0300107YL356”相匹配的价格&库存,您可以联系我们找货
