AW1200125BK358
AW1200125BK358
    ALPHAWIRE(阿尔法电线)
    M12MSTRTOCUT22AWG04POL
AW1200125BK358 数据手册
Customer Specification PART NO: AW1200125 M12-A Female 90 Degree Drawings Issue: 1 Issue Date: 7/29/2016 Effective Date: 7/29/2016 Technical Data Cordage Construction Cordage Part Number Component 1 a) Conductor b) Insulation Insulation Colors Jacket a) Color(s) Cord Configuration End 1 End 2 Insert Mold Color Contact Coupling Nut O-Ring Available Lengths Diameters (In) 346 12 COND 0,25mm² (32x 0,10mm) Bare Copper (24 AWG) 0.010” Wall, Nom. PP White, Brown, Green, Yellow, Grey, Pink, Blue, Red, Black, Violet, Grey/Pink & Red/Blue 0.028” Wall, Nom. PUR, Zero Halogen Black 0.025 0.045 0.252 M12-A Female, 90 Degree Cut End Black TPU Black TPU Copper Alloy, Gold plated Copper Alloy, Nickel plated FKM 0.6, 1, 3, 5, 10, 15, 20 Meters ••••••••••••••••••••••••••••••••••••••• Alpha Wire | 711 Lidgerwood Ave, Elizabeth, NJ 07207 www.alphawire.com | 1-800-52 ALPHA 1 Customer Specification PART NO: AW1200125 M12-A Female 90 Degree Applicable SpecificationsCable UL CSA International Applicable SpecificationsCord Set UL Nominal Voltage Rated Voltage Ingress Protection Environmental Compliance CE REACH Regulation (EC 1907/2006) Physical & Mechanical Properties Temperature Range, Cord Temperature Range, Connector Bend Radius Pull Tension Current Rating Ordering Information AW1200125 BK355 AW1200125 BK356 AW1200125 BK357 AW1200125 BK358 AW1200125 BK359 AW1200125 BK400 AW1200125 BK401 Standard Package AWM/STYLE 20549 80°C / 300 VRMS C(RU) AWM I/II A/B FT2 80°C / 300 VRMS ANSI/UL 2238, Cable Assembly Extension RU, UL File Number E485156 30 V 36 V IP67/NEMA 6P All materials used in the manufacture of this part meet the requirements of European Directive 2011/65/EU regarding the restriction of use of certain hazardous substances in electrical and electronic equipment. Exemption used; 6a. This product does not contain Substances of Very High Concern (SVHC) listed on the European Union’s REACH candidate list in excess of 0.1% mass of the item. -40 to 80°C(static), -25 to 60°C (dynamic) -25°C to +80°C 5X Cable Diameter (static), 10X Cable Diameter (dynamic) 45 Lbs, Maximum 0.8 Amps @ 50°C 0.6 Meters 1.0 Meters 3.0 Meters 5.0 Meters 10.0 Meters 15.0 Meters 20.0 Meters Each Although Alpha Wire (“Alpha”) makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and • •product • • • • •availability. • • • • • • Alpha • • • •provides • • • • • the • • •information • • • • • • •and • • specification ••••• specifications does not ensure herein on an “AS IS” basis, with no Alpha Wire | 711 Lidgerwood Ave, NJ be 07207 representations or warranties, whether express, statutory or implied. In noElizabeth, event will Alpha liable any damages (including consequential, www.alphawire.com | 1-800-52 2 indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if ALPHA Alpha has been advised of the possibility of such damages, whether in an action under contact, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specification described herein.
AW1200125BK358
1. 物料型号:型号为ATMEGA328P-AU,是一款由Atmel公司生产的8位AVR微控制器,具有32KB的闪存、1KB的SRAM和512字节的EEPROM。
2. 器件简介:ATMEGA328P-AU微控制器广泛应用于各种嵌入式系统设计,因其高性能和低功耗而受到青睐。
3. 引脚分配:该微控制器有44个引脚,包括电源引脚、地引脚、复位引脚以及多个I/O引脚,支持多种I/O功能。
4. 参数特性:工作电压范围为1.8-5.5V,工作频率可达16MHz,具有多个定时器、中断、看门狗定时器等。
5. 功能详解:包括中央处理单元、存储器、I/O端口、模拟-数字转换器、通信接口等。
6. 应用信息:适用于各种工业控制、消费电子、医疗设备等领域。
7. 封装信息:采用TQFP封装,共有44个引脚。
AW1200125BK358 价格&库存
很抱歉,暂时无法提供与“AW1200125BK358”相匹配的价格&库存,您可以联系我们找货
