EW1900127BK358
EW1900127BK358
    ALPHAWIRE(阿尔法电线)
    M8F90DEGTOCUT4POL
EW1900127BK358 数据手册
Customer Specification PART NO: EW1900127 M23 Female 90 Degree Drawings Issue: 1 Issue Date: 7/29/2016 Effective Date: 7/29/2016 Technical Data Cordage Construction Cordage Part Number Component 1 a) Conductor b) Insulation Insulation Colors Component 2 b) Conductor b) Insulation Insulation Colors Jacket a) Color(s) Cord Configuration End 1 End 2 Insert Diameters (In) 242 16 COND 0,50mm² (64 x 0,10mm), Bare Copper (20 AWG) Polypropylene Yellow/Brown, Brown/Green, White, Yellow, Pink, Gray/Brown, Violet, Red, Gray, Red/Blue, Green, Gray/Pink, White/Green, White/Yellow, White/Gray & Black 3 COND 1,00mm², (128 x 0,10mm), Bare Copper (18 AWG) Polypropylene Blue, Brown & Yellow/Green 0.059” Wall, Nom. PUR, Zero Halogen Black 0.057 0.077 0.457 M23 Female, 90 Degree Cut End White PBT ••••••••••••••••••••••••••••••••••••••• Alpha Wire | 711 Lidgerwood Ave, Elizabeth, NJ 07207 www.alphawire.com | 1-800-52 ALPHA 1 Customer Specification PART NO: EW1900127 M23 Female 90 Degree Mold Color Contact Coupling Nut Available Lengths Applicable SpecificationsCable UL CSA International Applicable SpecificationsCord Set Nominal Voltage Rated Voltage Ingress Protection Environmental Compliance CE REACH Regulation (EC 1907/2006) Physical & Mechanical Properties Temperature Range, Cord Temperature Range, Connector Bend Radius Current Rating Ordering Information ER1200127 BK355 ER1200127 BK356 ER1200127 BK357 ER1200127 BK358 ER1200127 BK359 ER1200127 BK400 ER1200127 BK401 Standard Package Black TPU Copper Alloy, Gold plated Copper Alloy, Nickel plated 0.6, 1, 3, 5, 10, 15, 20 Meters AWM/STYLE 20549/21198 C(RU) AWM I/II A/B FT2 80°C / 300 VRMS 80°C / 300 VRMS 120 V 125 V IP67/NEMA 6P All materials used in the manufacture of this part meet the requirements of European Directive 2011/65/EU regarding the restriction of use of certain hazardous substances in electrical and electronic equipment. Exemption used; 6a. This product does not contain Substances of Very High Concern (SVHC) listed on the European Union’s REACH candidate list in excess of 0.1% mass of the item. -50 to 80°C(static), -25 to 80°C (dynamic) -25°C to +80°C 5X Cable Diameter (static), 10X Cable Diameter (dynamic) 5.6 Amps @ 50°C (1,00mm² Conductors) 0.6 Meters 1.0 Meters 3.0 Meters 5.0 Meters 10.0 Meters 15.0 Meters 20.0 Meters Each Although Alpha Wire (“Alpha”) makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and • •product • • • • •availability. • • • • • • Alpha • • • •provides • • • • • the • • •information • • • • • • •and • • specification ••••• specifications does not ensure herein on an “AS IS” basis, with no Alpha Wire | 711 Lidgerwood Ave, NJ be 07207 representations or warranties, whether express, statutory or implied. In noElizabeth, event will Alpha liable any damages (including consequential, www.alphawire.com | 1-800-52 2 indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if ALPHA Alpha has been advised of the possibility of such damages, whether in an action under contact, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specification described herein.
EW1900127BK358 价格&库存
很抱歉,暂时无法提供与“EW1900127BK358”相匹配的价格&库存,您可以联系我们找货
