FW12EW126BK358
FW12EW126BK358
    ALPHAWIRE(阿尔法电线)
    M8F90DEGTOCUT4POL
FW12EW126BK358 数据手册
Customer Specification PART NO: FW12EW126 M23 Male 90 Degree to M23 Female 90 Degree Issue: 1 Issue Date: 7/29/2016 Effective Date: 7/29/2016 Drawings Technical Data Cordage Construction Cordage Part Number Component 1 a) Conductor b) Insulation Insulation Colors Component 2 b) Conductor b) Insulation Insulation Colors Jacket a) Color(s) Cord Configuration End 1 End 2 Diameters (In) 256 8 COND 0,50mm² (64 x 0,10mm), Bare Copper (20 AWG) Polypropylene White, Green, Yellow, Grey, Grey/Pink, Red/Blue, White/Green & Brown/Green 3 COND 1,00mm², (128 x 0,10mm), Bare Copper (18 AWG) Polypropylene Blue, Brown & Yellow/Green 0.057” Wall, Nom. PUR, Zero Halogen Black 0.057 0.077 0.366 M23 Male 90 Degree M23 Female 90 Degree ••••••••••••••••••••••••••••••••••••••• Alpha Wire | 711 Lidgerwood Ave, Elizabeth, NJ 07207 www.alphawire.com | 1-800-52 ALPHA 1 Customer Specification PART NO: FW12EW126 M23 Male 90 Degree to M23 Female 90 Degree Insert Mold Color Contact Coupling Nut Available Lengths Applicable SpecificationsCable UL CSA International Applicable SpecificationsCord Set Nominal Voltage Rated Voltage Ingress Protection Environmental Compliance CE REACH Regulation (EC 1907/2006) Physical & Mechanical Properties Temperature Range, Cord Temperature Range, Connector Bend Radius Current Rating Ordering Information FW12EW126 BK355 FW12EW126 BK356 FW12EW126 BK357 FW12EW126 BK358 FW12EW126 BK359 FW12EW126 BK400 FW12EW126 BK401 Standard Package White PBT Black TPU Copper Alloy, Gold plated Copper Alloy, Nickel plated 0.6, 1, 3, 5, 10, 15, 20 Meters AWM/STYLE 20549/21198 C(RU) AWM I/II A/B FT2 80°C / 300 VRMS 80°C / 300 VRMS 240 V 250 V IP67/NEMA 6P All materials used in the manufacture of this part meet the requirements of European Directive 2011/65/EU regarding the restriction of use of certain hazardous substances in electrical and electronic equipment. Exemption used; 6a. This product does not contain Substances of Very High Concern (SVHC) listed on the European Union’s REACH candidate list in excess of 0.1% mass of the item. -50 to 80°C(static), -25 to 80°C (dynamic) -25°C to +80°C 5X Cable Diameter (static), 10X Cable Diameter (dynamic) 5.6 Amps @ 50°C (1,00mm² Conductors) 0.6 Meters 1.0 Meters 3.0 Meters 5.0 Meters 10.0 Meters 15.0 Meters 20.0 Meters Each Although Alpha Wire (“Alpha”) • • makes • • • • every • • • •reasonable • • • • • • effort • • • •to• •ensure • • • •their • • •accuracy • • • • • at • •the • •time • of this publication, information and specifications described herein are subject error Lidgerwood or omission and Ave, to change without notice, and the listing of such information and Alpha Wireto| 711 Elizabeth, NJ 07207 specifications does not ensure product availability. Alpha provides the information and specification herein on an “AS IS” basis, with no 2 www.alphawire.com | 1-800-52 ALPHA representations or warranties, whether express, statutory or implied. In no event will Alpha be liable any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Alpha has been advised of the possibility of such damages, whether in an action under contact, negligence or any other theory, arising out of or in connection with the use, or inability to use, the
FW12EW126BK358 价格&库存
很抱歉,暂时无法提供与“FW12EW126BK358”相匹配的价格&库存,您可以联系我们找货
