DR0300104SL356
DR0300104SL356
    ALPHAWIRE(阿尔法电线)
    M12MSTRTOCUT22AWG04POL
DR0300104SL356 数据手册
Customer Specification PART NO: DR0300104 M12-A Male Issue: 1 Issue Date: 7/29/2016 Effective Date: 7/29/2016 Drawings Technical Data Cordage Construction Cordage Part Number Component 1 a) Conductor b) Insulation Insulation Colors Jacket a) Color(s) Cord Configuration End 1 End 2 Insert Mold Color Contact Coupling Nut O-Ring Available Lengths Applicable SpecificationsCable Diameters (In) 104 3 COND 22 (26/36) AWG Bare Copper 0.011” Wall, Nom. SR-PVC Black, Brown & Blue 0.032” Wall, Nom. PVC SLATE 0.027 0.049 0.176 M12-A Male Cut End Black TPU Black TPU Copper Alloy, Gold plated Copper Alloy, Nickel plated FKM 0.6, 1, 3, 5, 10, 15, 20 Meters ••••••••••••••••••••••••••••••••••••••• Alpha Wire | 711 Lidgerwood Ave, Elizabeth, NJ 07207 www.alphawire.com | 1-800-52 ALPHA 1 Customer Specification PART NO: DR0300104 M12-A Male UL CSA International Applicable SpecificationsCord Set UL CSA Nominal Voltage Rated Voltage Ingress Protection Environmental Compliance CE REACH Regulation (EC 1907/2006) Physical & Mechanical Properties Temperature Range, Cord Temperature Range, Connector Bend Radius Pull Tension Current Rating Ordering Information DR0300104 SL355 DR0300104 SL356 DR0300104 SL357 DR0300104 SL358 DR0300104 SL359 DR0300104 SL400 DR0300104 SL401 Standard Package AWM/STYLE 2661 C(RU) AWM I/II A/B FT1 105°C / 300 V RMS 105°C / 3600 V RMS ANSI/UL 2238, Cable Assembly Extension RU, UL File Number E485156 CSA-C22.2 No. 182.3, Special Use Attachment Plugs, Receptacles and Connectors cRU, UL File Number E485156 240 V 250 V IP67/NEMA 6P All materials used in the manufacture of this part meet the requirements of European Directive 2011/65/EU regarding the restriction of use of certain hazardous substances in electrical and electronic equipment. Exemption used; 6a. This product does not contain Substances of Very High Concern (SVHC) listed on the European Union’s REACH candidate list in excess of 0.1% mass of the item. -40 to 105°C(static), -15 to 105°C (dynamic) -25°C to +80°C 7X Cable Diameter (static), 10X Cable Diameter (dynamic) 15.3 Lbs, Maximum 3.1 Amps @ 50°C 0.6 Meters 1.0 Meters 3.0 Meters 5.0 Meters 10.0 Meters 15.0 Meters 20.0 Meters Each Although Alpha Wire (“Alpha”) makes every reasonable effort to ensure their accuracy at the time of this publication, information and ••••••••••••••••••••••••••••••••••••••• specifications described herein are subject to error or omission and to change without notice, and the listing of such information and Alpha Wire | 711 Lidgerwood Ave, Elizabeth, NJ 07207 specifications does not ensure product availability. Alpha provides the information and specification herein on an “AS IS” basis, with no 2 www.alphawire.com | 1-800-52 ALPHA representations or warranties, whether express, statutory or implied. In no event will Alpha be liable any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Alpha has been advised of the possibility of such damages, whether in an action under contact, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specification described herein.
DR0300104SL356
物料型号:DR0300104 器件简介:M12-A Male连接器 引脚分配:导线配置中提到端1为M12-A Male,端2为切割端 参数特性: - 导线部分号:104 - 导体:22 AWG裸铜 - 绝缘:0.011英寸壁厚,名义SR-PVC,绝缘颜色为黑色、棕色和蓝色 - 护套:0.032英寸壁厚,名义PVC,颜色为石板灰 - 插入件和模具颜色:黑色TPU - 接触件:铜合金,镀金 - 螺母:铜合金,镀镍 - O形圈:FKM - 可用长度:0.6、1、3、5、10、15、20米 功能详解: - 适用规范:电缆符合UL AWM/STYLE 2661,105°C/300 VRMS,CSA国际C(RU) AWM I/II A/B FT1,105°C/3600 VRMS - 额定电压:250V - 环境防护等级:IP67/NEMA 6P - 环境合规性:符合CE指令和REACH法规 封装信息: - 温度范围:静态-40到105°C,动态-15到105°C - 弯曲半径:静态7倍电缆直径,动态10倍电缆直径 - 拉力:最大15.3磅 - 电流额定值:在50°C时为3.1安培 - 订购信息:提供了不同长度的型号和标准包装
DR0300104SL356 价格&库存
很抱歉,暂时无法提供与“DR0300104SL356”相匹配的价格&库存,您可以联系我们找货
