GR0400101SL356
GR0400101SL356
    ALPHAWIRE(阿尔法电线)
    M8FSTRTOCUT4POL
GR0400101SL356 数据手册
Customer Specification PART NO: GR0400101 M8 Female Issue: 1 Issue Date: 7/29/2016 Effective Date: 7/29/2016 Drawings Technical Data Cordage Construction Cordage Part Number Component 1 a) Conductor b) Insulation Insulation Colors Jacket a) Color(s) Cord Configuration End 1 End 2 Insert Mold Color Contact Coupling Nut Available Lengths Applicable SpecificationsCable UL Diameters (In) 101 4 COND 22 (26/36) AWG Bare Copper 0.010” Wall, Nom. mPPE Black, White, Brown & Blue 0.040” Wall, Nom. PUR, Zero Halogen SLATE 0.027 0.047 0.200 M8 Female Cut End Black TPU Black TPU Copper Alloy, Gold plated Copper Alloy, Nickel plated 0.6, 1, 3, 5, 10, 15, 20 Meters AWM/STYLE 20549 ••••••••••••••••••••••••••••••••••••••• Alpha Wire | 711 Lidgerwood Ave, Elizabeth, NJ 07207 www.alphawire.com | 1-800-52 ALPHA 80°C / 300 V RMS 1 Customer Specification PART NO: GR0400101 M8 Female CSA International Applicable SpecificationsCord Set UL CSA Nominal Voltage Rated Voltage Ingress Protection Environmental Compliance CE REACH Regulation (EC 1907/2006) Physical & Mechanical Properties Temperature Range, Cord Bend Radius Pull Tension Current Rating Ordering Information GR0400101 SL355 GR0400101 SL356 GR0400101 SL357 GR0400101 SL358 GR0400101 SL359 GR0400101 SL400 GR0400101 SL401 Standard Package AWM/STYLE 21959 C(RU) AWM I/II A/B FT1 90°C / 600 V RMS 90°C / 600 V RMS ANSI/UL 2238, Cable Assembly Extension RU, UL File Number E485156 CSA-C22.2 No. 182.3, Special Use Attachment Plugs, Receptacles and Connectors cRU, UL File Number E485156 30 V 36 V IP67/NEMA 6P All materials used in the manufacture of this part meet the requirements of European Directive 2011/65/EU regarding the restriction of use of certain hazardous substances in electrical and electronic equipment. Exemption used; 6a. This product does not contain Substances of Very High Concern (SVHC) listed on the European Union’s REACH candidate list in excess of 0.1% mass of the item. -50 to 90°C(static), -40 to 80°C (dynamic) 4X Cable Diameter (static), 6X Cable Diameter (dynamic) 20.4 Lbs, Maximum 2.2 Amps @ 50°C 0.6 Meters 1.0 Meters 3.0 Meters 5.0 Meters 10.0 Meters 15.0 Meters 20.0 Meters Each Although Alpha Wire (“Alpha”) makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Alpha provides the information and specification herein on an “AS IS” basis, with no • •whether • • • • •express, • • • • •statutory • • • • • •or• implied. • • • • • In• •no• event • • • •will • • Alpha • • • •be • •liable any damages (including consequential, representations or warranties, Alpha or Wire | 711 damages) Lidgerwood Ave, Elizabeth, NJ been 07207 indirect, incidental, special, punitive, exemplary whatsoever, even if Alpha has advised of the possibility of such damages, www.alphawire.com 1-800-52 whether in an action under contact, negligence or any other theory,|arising out ofALPHA or in connection with the use, or inability to use, the 2 information or specification described herein.
GR0400101SL356 价格&库存
很抱歉,暂时无法提供与“GR0400101SL356”相匹配的价格&库存,您可以联系我们找货
