301ACFNC404
301ACFNC404
    ALPHAWIRE(阿尔法电线)
    M12FRECEPFRONT4POLE
301ACFNC404 数据手册
Customer Specification PART NO: ACF Series M12-A Female Front Mount PG9 Receptacle Issue: 1 Issue Date: 8/8/2016 Effective Date: 8/8/2016 Drawing Technical Data Mechanical Receptacle Style Applicable Specification Receptacle Threads Housing Insert Contact Mounting Orientation Panel Nut O-Ring Electrical Contact Resistance Nom. Current @ 40°C Rated Voltage UL File Lead Wires AWG Insulation Outside Diameter Lead Length UL Style CSA Style M12, Female IEC 61076-2-101 Internal Nickel Plated Brass, Leads Epoxy Potted Polyurethane Copper Alloy, Gold Plated Front Nickel Plated Brass FKM ≤ 5 mΩ 4A 4 Pole 250 V (IEC) 300V (UL) 5 Pole 60 V (IEC) 30V (UL) E485156 22 AWG (7/30) Tinned Copper PVC 0.062” Nominal 0.5 Meters (19.7”) AWM 1007 & 1569 TR64 ••••••••••••••••••••••••••••••••••••••• Alpha Wire | 711 Lidgerwood Ave, Elizabeth, NJ 07207 www.alphawire.com | 1-800-52 ALPHA 1 Customer Specification PART NO: ACF Series M12-A Female Front Mount PG9 Receptacle Environmental Degree of Protection Operating Temperature Range CE REACH Regulation (EC 1907/2006) Issue: 1 issue Date: 8/4/2016 Effective Date: 8/4/2016 Ordering Information 301ACF NC404 304ACF NC404 IP 67/ NEMA 6P -25C (-13F)/ +90C (+194F) All materials used in the manufacture of this part meet the requirements of European Directive 2011/65/EU regarding the restriction of use of certain hazardous substances in electrical and electronic equipment. Exemption used; 6a. This product does not contain Substances of Very High Concern (SVHC) listed on the European Union’s REACH candidate list in excess of 0.1% mass of the item. Description 4 Pin 5 Pin Quantity Each Each Although Alpha Wire (“Alpha”) makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Alpha provides the information and specification herein on an “AS IS” basis, with no representations or warranties, whether express, statutory or implied. In no event will Alpha be liable any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Alpha has been advised of the possibility of such damages, whether in an action under contact, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specification described herein. ••••••••••••••••••••••••••••••••••••••• Alpha Wire | 711 Lidgerwood Ave, Elizabeth, NJ 07207 www.alphawire.com | 1-800-52 ALPHA 2
301ACFNC404
物料型号为ACF系列,具体型号为M12-A Female Front Mount PG9 Receptacle。
器件简介为M12型,女性,前置安装PG9插座。
引脚分配为4针或5针配置。
参数特性包括接触电阻小于5毫欧,额定电流40°C时为4安培,额定电压为4针250V(IEC)/300V(UL),5针60V(IEC)/30V(UL)。
功能详解涉及电气性能、机械特性和环境特性,如IP 67/NEMA 6P的防护等级和-25°C至+90°C的工作温度范围。
应用信息包括符合IEC61076-2-101标准和UL文件E485156。
封装信息为镍镀黄铜外壳,聚氨酯插入件,铜合金接触件镀金,以及FKM O型圈。
产品符合CE标志要求和REACH法规,不含超过0.1%质量分数的高度关注物质(SVHC)。
订购信息包括4针型号301ACF NC404和5针型号304ACF NC404。
301ACFNC404 价格&库存
很抱歉,暂时无法提供与“301ACFNC404”相匹配的价格&库存,您可以联系我们找货
