AW0800124SL356
AW0800124SL356
    ALPHAWIRE(阿尔法电线)
    M12MSTRTOM12FSTR22AWG03L
AW0800124SL356 数据手册
Customer Specification PART NO: AW0800124 M12-A Female 90 Degree Drawings Issue: 1 Issue Date: 7/29/2016 Effective Date: 7/29/2016 Technical Data Cordage Construction Cordage Part Number Component 1 a) Conductor b) Insulation Insulation Colors Shield Jacket a) Color(s) Cord Configuration End 1 End 2 Insert Mold Color Contact Coupling Nut O-Ring Available Lengths Applicable SpecificationsCable Diameters (In) 124 8 COND 24 (19/36) AWG Bare Copper 0.010” Wall, Nom. PP White, Brown, Green, Yellow, Grey, Pink, Blue & Red 85% Tinned Copper Braid 0.040” Wall, Nom. PUR, Zero Halogen SLATE 0.025 0.045 0.276 M12-A Female, 90 Degree Cut End Black TPU Black TPU Copper Alloy, Gold plated Copper Alloy, Nickel plated FKM 0.6, 1, 3, 5, 10, 15, 20 Meters ••••••••••••••••••••••••••••••••••••••• Alpha Wire | 711 Lidgerwood Ave, Elizabeth, NJ 07207 www.alphawire.com | 1-800-52 ALPHA 1 Customer Specification PART NO: AW0800124 M12-A Female 90 Degree UL AWM/STYLE 20549 80°C / 300 V RMS CSA International Applicable SpecificationsCord Set UL C(RU) AWM I/II A/B FT2 80°C / 300 V RMS CSA Nominal Voltage Rated Voltage Ingress Protection Environmental Compliance CE REACH Regulation (EC 1907/2006) Physical & Mechanical Properties Temperature Range, Cord Temperature Range, Connector Bend Radius Pull Tension Current Rating Ordering Information AW0800124 SL355 AW0800124 SL356 AW0800124 SL357 AW0800124 SL358 AW0800124 SL359 AW0800124 SL400 AW0800124 SL401 Standard Package ANSI/UL 2238, Cable Assembly Extension RU, UL File Number E485156 CSA-C22.2 No. 182.3, Special Use Attachment Plugs, Receptacles and Connectors cRU, UL File Number E485156 30 V 36 V IP67/NEMA 6P All materials used in the manufacture of this part meet the requirements of European Directive 2011/65/EU regarding the restriction of use of certain hazardous substances in electrical and electronic equipment. Exemption used; 6a. This product does not contain Substances of Very High Concern (SVHC) listed on the European Union’s REACH candidate list in excess of 0.1% mass of the item. -40 to 80°C(static), -25 to 60°C (dynamic) -25°C to +80°C 5X Cable Diameter (static), 10X Cable Diameter (dynamic) 34 Lbs, Maximum 1.1 Amps @ 50°C 0.6 Meters 1.0 Meters 3.0 Meters 5.0 Meters 10.0 Meters 15.0 Meters 20.0 Meters Each ••••••••••••••••••••••••••••••••••••••• Although Alpha Wire (“Alpha”) makesWire every|reasonable effort to ensure accuracy at time of this publication, information and Alpha 711 Lidgerwood Ave,their Elizabeth, NJthe07207 specifications described herein are subject to error or omission and |to1-800-52 change without notice, and the listing of such information and 2 www.alphawire.com ALPHA specifications does not ensure product availability. Alpha provides the information and specification herein on an “AS IS” basis, with no representations or warranties, whether express, statutory or implied. In no event will Alpha be liable any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Alpha has been advised of the possibility of such damages,
AW0800124SL356 价格&库存
很抱歉,暂时无法提供与“AW0800124SL356”相匹配的价格&库存,您可以联系我们找货
