EW1200126BK358
EW1200126BK358
    ALPHAWIRE(阿尔法电线)
    M8F90DEGTOCUT3POL
EW1200126BK358 数据手册
Customer Specification PART NO: EW1200126 M23 Female 90 Degree Drawings Issue: 1 Issue Date: 7/29/2016 Effective Date: 7/29/2016 Technical Data Cordage Construction Cordage Part Number Component 1 a) Conductor b) Insulation Insulation Colors Component 2 b) Conductor b) Insulation Insulation Colors Jacket a) Color(s) Cord Configuration End 1 End 2 Insert Mold Color Contact Coupling Nut Available Lengths Applicable SpecificationsCable Diameters (In) 256 8 COND 0,50mm² (64 x 0,10mm), Bare Copper (20 AWG) Polypropylene White, Green, Yellow, Grey, Grey/Pink, Red/Blue, White/Green & Brown/Green 3 COND 1,00mm², (128 x 0,10mm), Bare Copper (18 AWG) Polypropylene Blue, Brown & Yellow/Green 0.057” Wall, Nom. PUR, Zero Halogen Black 0.057 0.077 0.366 M23 Female 90 Degree Cut End White PBT Black TPU Copper Alloy, Gold plated Copper Alloy, Nickel plated 0.6, 1, 3, 5, 10, 15, 20 Meters ••••••••••••••••••••••••••••••••••••••• Alpha Wire | 711 Lidgerwood Ave, Elizabeth, NJ 07207 www.alphawire.com | 1-800-52 ALPHA 1 Customer Specification PART NO: EW1200126 M23 Female 90 Degree UL CSA International Applicable SpecificationsCord Set Nominal Voltage Rated Voltage Ingress Protection Environmental Compliance CE REACH Regulation (EC 1907/2006) Physical & Mechanical Properties Temperature Range, Cord Temperature Range, Connector Bend Radius Current Rating Ordering Information EW1200126 BK355 EW1200126 BK356 EW1200126 BK357 EW1200126 BK358 EW1200126 BK359 EW1200126 BK400 EW1200126 BK401 Standard Package AWM/STYLE 20549/21198 C(RU) AWM I/II A/B FT2 80°C / 300 VRMS 80°C / 300 VRMS 240 V 250 V IP67/NEMA 6P All materials used in the manufacture of this part meet the requirements of European Directive 2011/65/EU regarding the restriction of use of certain hazardous substances in electrical and electronic equipment. Exemption used; 6a. This product does not contain Substances of Very High Concern (SVHC) listed on the European Union’s REACH candidate list in excess of 0.1% mass of the item. -50 to 80°C(static), -25 to 80°C (dynamic) -25°C to +80°C 5X Cable Diameter (static), 10X Cable Diameter (dynamic) 5.6 Amps @ 50°C (1,00mm² Conductors) 0.6 Meters 1.0 Meters 3.0 Meters 5.0 Meters 10.0 Meters 15.0 Meters 20.0 Meters Each Although Alpha Wire (“Alpha”) makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Alpha provides the information and specification herein on an “AS IS” basis, with no representations or warranties, whether express, statutory or implied. In no event will Alpha be liable any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Alpha has been advised of the possibility of such damages, whether in an action under contact, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specification described herein. ••••••••••••••••••••••••••••••••••••••• Alpha Wire | 711 Lidgerwood Ave, Elizabeth, NJ 07207 www.alphawire.com | 1-800-52 ALPHA 2
EW1200126BK358 价格&库存
很抱歉,暂时无法提供与“EW1200126BK358”相匹配的价格&库存,您可以联系我们找货
