CCA-000-M01R203
CCA-000-M01R203
    NORCOMP
CCA-000-M01R203 数据手册
DESCRIPTION: M5 - FEMALE TO BLUNT - 4 POSITION - CABLE ASSEMBLY RoHS COMPLIANT N C THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF NorComp AND SHALL NOT BE REPRODUCED, COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. DRAWN: M. SIGMON UNITS = mm DATE: 04-13-15 DO NOT SCALE FROM DRAWING NorComp SCALE: SHEET NTS DWG NO. REV OF 1 3 CCA-000-MYYR203 5 DESCRIPTION: M5 - FEMALE TO BLUNT - 4 POSITION - CABLE ASSEMBLY RoHS COMPLIANT N C THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF NorComp AND SHALL NOT BE REPRODUCED, COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. DRAWN: M. SIGMON UNITS = mm DATE: 04-13-15 DO NOT SCALE FROM DRAWING NorComp SCALE: SHEET NTS DWG NO. REV OF 2 3 CCA-000-MYYR203 5 DESCRIPTION: M5 - FEMALE TO BLUNT - 4 POSITION - CABLE ASSEMBLY RoHS COMPLIANT N C THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF NorComp AND SHALL NOT BE REPRODUCED, COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. DRAWN: M. SIGMON DO NOT SCALE FROM DRAWING DATE: 04-13-15 NorComp SCALE: SHEET NTS DWG NO. REV OF 3 3 CCA-000-MYYR203 5
CCA-000-M01R203 价格&库存
很抱歉,暂时无法提供与“CCA-000-M01R203”相匹配的价格&库存,您可以联系我们找货
CCA-000-M01R203
库存:21
