314JCFNC402
314JCFNC402
    ALPHAWIRE(阿尔法电线)
    7/8INMINIFEMALEFRONTREC
314JCFNC402 数据手册
Customer Specification PART NO: JCF Series Mini 7/8” Female ½ NPT Mount Receptacle Issue: 1 Issue Date: 8/8/2016 Effective Date: 8/8/2016 Drawing Technical Data Mechanical Receptacle Style Applicable Specification Receptacle Threads Housing Insert Contact Mounting Orientation Panel Nut O-Ring Electrical Contact Resistance Nom. Current @ 40°C Rated Voltage UL File Lead Wires AWG Insulation Color Code Outside Diameter Lead Length UL Style CSA Style Environmental Mini, Female External Zinc, Black, Leads Epoxy Potted Polyurethane Copper Alloy, Gold Plated 1/2” 14-NPT Zinc Plated Steel FKM ≤ 5 mΩ 8A 600 V E485156 16 AWG (26/30) Tinned Copper PVC US 0.121” Nominal 0.5 Meters (19.7”) AWM 1015 & 1230 and MTW TEW ••••••••••••••••••••••••••••••••••••••• Alpha Wire | 711 Lidgerwood Ave, Elizabeth, NJ 07207 www.alphawire.com | 1-800-52 ALPHA 1 Customer Specification PART NO: JCF Series Mini 7/8” Female ½ NPT Mount Receptacle Degree of Protection Operating Temperature Range CE Issue: 1 issue Date: 8/4/2016 Effective Date: 8/4/2016 REACH Regulation (EC 1907/2006) Ordering Information 314JCF NC356 314JCF NC402 314JCF NC405 316JCF NC356 316JCF NC402 316JCF NC405 318JCF NC356 318JCF NC402 318JCF NC405 IP 68/ NEMA 6P -40C (-40F)/ +90C (+194F) All materials used in the manufacture of this part meet the requirements of European Directive 2011/65/EU regarding the restriction of use of certain hazardous substances in electrical and electronic equipment. Exemption used; 6a. This product does not contain Substances of Very High Concern (SVHC) listed on the European Union’s REACH candidate list in excess of 0.1% mass of the item. Description 3 Pin, 1 Meter 3 Pin, 0.3 Meter 3 Pin, 2 Meter 4 Pin, 1 Meter 4 Pin, 0.3 Meter 4 Pin, 2 Meter 5 Pin, 1 Meter 5 Pin, 0.3 Meter 5 Pin, 2 Meter Quantity Each Each Each Each Each Each Each Each Each Although Alpha Wire (“Alpha”) makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Alpha provides the information and specification herein on an “AS IS” basis, with no representations or warranties, whether express, statutory or implied. In no event will Alpha be liable any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Alpha has been advised of the possibility of such damages, whether in an action under contact, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specification described herein. ••••••••••••••••••••••••••••••••••••••• Alpha Wire | 711 Lidgerwood Ave, Elizabeth, NJ 07207 www.alphawire.com | 1-800-52 ALPHA 2
314JCFNC402 价格&库存
很抱歉,暂时无法提供与“314JCFNC402”相匹配的价格&库存,您可以联系我们找货
