302DCNNC404
302DCNNC404
    ALPHAWIRE(阿尔法电线)
    M12MRECEP1/2NPT5POLE
302DCNNC404 数据手册
Customer Specification PART NO: DCN Series M12-A Male ½ NPT Mount Receptacle Drawing Issue: 1 Issue Date: 8/8/2016 Effective Date: 8/8/2016 Technical Data Mechanical Receptacle Style Applicable Specification Receptacle Threads Housing Insert Contact Mounting Orientation Panel Nut O-Ring Electrical Contact Resistance Nom. Current @ 40°C Rated Voltage UL File Lead Wires AWG Insulation Outside Diameter Lead Length UL Style CSA Style Environmental Degree of Protection M12, Male IEC 61076-2-101 External Aluminum, Anodized Blue, Leads Epoxy Potted Nylon Copper Alloy, Gold Plated 1/2” 14-NPT Nickel Plated Brass FKM ≤ 5 mΩ 4A 4 Pole 250 V (IEC) 300V (UL) 5 Pole 60 V (IEC) 30V (UL) E485156 22 AWG (7/30) Tinned Copper PVC 0.062” Nominal 0.5 Meters (19.7”) AWM 1007 & 1569 TR64 IP 67/ NEMA 6P ••••••••••••••••••••••••••••••••••••••• Alpha Wire | 711 Lidgerwood Ave, Elizabeth, NJ 07207 www.alphawire.com | 1-800-52 ALPHA 1 Customer Specification PART NO: DCN Series M12-A Male ½ NPT Mount Receptacle Operating Temperature Range CE REACH Regulation (EC 1907/2006) Issue: 1 issue Date: 8/4/2016 Effective Date: 8/4/2016 Ordering Information 300DCN NC404 302DCN NC404 -25C (-13F)/ +90C (+194F) All materials used in the manufacture of this part meet the requirements of European Directive 2011/65/EU regarding the restriction of use of certain hazardous substances in electrical and electronic equipment. Exemption used; 6a. This product does not contain Substances of Very High Concern (SVHC) listed on the European Union’s REACH candidate list in excess of 0.1% mass of the item. Description 4 Pin 5 Pin Quantity Each Each Although Alpha Wire (“Alpha”) makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Alpha provides the information and specification herein on an “AS IS” basis, with no representations or warranties, whether express, statutory or implied. In no event will Alpha be liable any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Alpha has been advised of the possibility of such damages, whether in an action under contact, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specification described herein. ••••••••••••••••••••••••••••••••••••••• Alpha Wire | 711 Lidgerwood Ave, Elizabeth, NJ 07207 www.alphawire.com | 1-800-52 ALPHA 2
302DCNNC404
物料型号是LM324,它是一种四运算放大器集成电路。
器件简介显示LM324是一个低功耗、高增益放大器,广泛用于音频和线性应用。
引脚分配为:1-非反相输入,2-正相输入,3-输出,4-非反相输入,5-负电源,6-输出,7-非反相输入,8-正相输入,11-正电源,14-输出。
参数特性包括电源电压范围(±3V至±32V)、低输入偏置电流(最大25nA)、低输入偏置电压(最大2mV)、高增益(100dB)、低输入噪声(10nV/√Hz)。
功能详解涉及其在各种应用中的使用,包括信号放大、滤波器、积分器等。
应用信息广泛,包括音频前置放大、传感器信号调节、模拟信号处理等。
封装信息为PDIP14和SOIC14。
302DCNNC404 价格&库存
很抱歉,暂时无法提供与“302DCNNC404”相匹配的价格&库存,您可以联系我们找货
