1.7mm pitch, Low Profile Wire-to-Board Connectors for Power Supplies
DF65 Series
(UL, C-UL, Listed)
Lock structure and operation
Socket
Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
Latch
Header
Latches are deflected
slightly during mating.
■Features
1. Enhanced contact reliability and lock structure
The unique locking structure reinforces the
engagement between the wire side portion and
the header. This prevents the wire side from
becoming misaligned due to stress from poorly
routed wiring. (Fig.1) (Patented)
2. Vertical mating provides superior handling
The use of ver tical mating style reduces
assembly time and maximizes precious board
space which gives designers more freedom
when designing other components on the PCB.
(Fig.2)
3. Highly reliable contact structure
The two point contact structure provides optimum
reliability, a low mated height of 1.8mm and an
effective mating length of 0.35mm.
4. Increased cable retention
The header is designed to press the terminal
lance down during the mating operation; this
prevents the lance from moving and enhances
its strength.
And snap back in when
mating is complete.
A click feeling will be felt!
Fig.1
operability and maximizes board space.
Vertical mating type
Side view of the PCB
Vertical mating style allows other parts to be mounted.
(Enhances freedom in designing PCB)
5. High current of MAX 4A (24 AWG)
By utilizing highly conductive material for the
female terminals and suppressing the contact
resistance, the DF65 series can handle a
maximum of 4A with 24 AWG wire.
6. Solder wicking prevention
Molding is done in a way that removes the gap
between the contacts and the housing to prevent
wicking.
7. Prevents Accidental unmating
The mating face is easy to see,
resulting in proper insertion.
Horizontal mating type
Unused, open area
The molded structure is designed to prevent
accidental unmating due to poorly routed wiring
and harsh loads.
8. UL and C-UL Certified
The mating face can be hard to see,
which can lead to awkward insertion.
In cases where the application will demand a high level of reliability, such as automotive,
please contact a company representative for further information.
Fig.2
2019.1④
1
DF65 Series●1.7mm pitch, Low Profile Wire-to-Board Connectors for Power Supplies
■Product Specifications
Ratings
Current
Rating
No. of Contacts 24 AWG 26 AWG 28 AWG Operating Temperature Range −40 to +105 ℃
( Note 2)
Operating aHumidity Range
20 to 80%
3
( Note 3 )
4
4A
2.5A
2.5A Storage Temperature Range −10 to +60 ℃( Note 4 )
Storage Humidity Range
5
( Note 4 )
40 to 70%
6
7
3.5A
UL/C-UL/File No. and Recognition No.
:E52653
UL
C-UL :E52653
2A
AC/DC 50V
Voltage Rating Specification
Item
1. Insulation
resistance
2. Withstand voltage
3.Contact resistance
4. Vibration
Resistance
2A
Specifications
Conditions
100Mø min.
Measured at DC 100V
No flashover or breakdown
10mø max.
AC 500V is applied for one minute.
Measured at 1mA and no higher than 20mV
10 cycles in each of three directions at frequency
10-55 Hz, half amplitude 0.75mm
Accelerated velocity : 490m/s2, for 11 ms, half-sine in 3
directions, 3 times for each of the three directions
Temperature : 40 ±2ç ; humidity : 90 to 95%, left
as it is for 96 hours
-55ç : 30 minutes → 5 - 35ç : 2 - 3 minutes
→ 85℃ : 30 minutes → 5 - 35ç : 2 - 3 minutes)
5 cycles
Tin plated : 30 mating cycles
Gold plated : 50 mating cycles
Reflow : according to the recommended
temperature profile
Hand soldering : temperature of soldering iron at
350ç±10ç for 3 seconds
No electrical discontinuity for more than 1µs
5. Shock Resistance
6. Moistureresistance
Contact resistance : 20mø max.
Insulation resistance : 500Mø min.
7. Temperature
cycles
8. Durability
9. Resistance to
solder heat
The resin components will not become
deformed or lose performance due to
deformities
Note 1 : This is the maximum current rating while all pins are powered or used as all power lines. Depending on pin assignment,
more current may flow. When dividing the current more than the specified amount into multiple circuits, the actual
current value may exceed the rated value. Please contact Hirose Electric, for inquiries on the assignment of pins and
on the currents that can be delivered.
Note 2 : Includes the temperature rise of power lines.
Note 3 : Use without condensation on parts.
Note 4 : The storage condition refers to long-term storage of the product on the shelf before assembly. Please use the operating
temperature for temporary storage such as pre-assembly and during shipping.
■Materials / Finish
Product
Part
Insulator
Contact
Insulator
Contact
Header
Crimp socket
Crimp contact
Materials
LCP
Brass
LCP
Phosphorous Bronze
Finish
Black
Tin Plated or Gold plated
Beige
UL specification
UL94V-0
UL94V-0
■Product Number Structure
Refer to the chart below when determining the product specifications from the product number.
Please select from the product numbers listed in this catalog when placing orders.
●Header connector
DF 65 - * P - 1.7 V
❶
❷
❸ ❹
❺
❻
DF 65 - * S - 1.7 C
❷
❸ ❹
❺
❻
❸Number of contacts : 3, 4, 5, 6, 7
❹Connector type
P : Header
❶Series Name : DF
❷Series No. : 65
❹Connector type
S:socket
●Crimp contact
DF 65 - 2428 SCF
❶
2
❷Series No. : 65
❺Pitch : 1.7mm
●Socket connector
❶
❻Mounting style
V : SMT Straight Type
❶Series Name:DF
❷
❶Applicable wire size
2428:24 to 28 AWG
❺Pitch : 1.7mm
❻Termination form
C : crimp case
❷Packaging style
SCF : Socket contact・Reel・Tin plated
SCFA : Socket contact・Reel・Gold plated
■Straight pin header
A
B
P= 1.7
t= 0.2
1.65
6.05
5.55
1.605
1.62
Contact No.1
Vacuum nozzle
area
0.25
●Recommended PCB layout (t=1mm)
B±0.05
+0.05
0.6 0
1±0.05
1.7 ±0.05
[Specification Number]**
(21) : Tin plated, embossed packaging
(78) : Gold plated, embossed packaging
1.8 ±0.05
5.45 ±0.05
Contact No.1
+0.05
1.025 ±0.05
Part No.
0.7 0
No. of
Contacts
3
4
5
6
7
HRS No.
A
B
C
DF65-3P-1.7V
666-6004-5 **
7.5
3.4
6
DF65-4P-1.7V
666-6006-0 **
9.2
5.1
7.7
DF65-5P-1.7V
666-6001-7 **
10.9
6.8
9.4
DF65-6P-1.7V
666-6008-6 **
12.6
8.5
11.1
DF65-7P-1.7V
666-6014-9 **
14.3
10.2
12.8
Note 1 : This product is sold per reel with 4,000 connectors pcs/reel. Please order by reel quantities.
Note 2 : Please contact Hirose representative if you have request for (78) specification.
1.75 ±0.1
●Tape and Reel Dimensions
12±0.1
4±0.1
2±0.1
.1
+0
φ1
Reel dimensions
11.5 ±0.1
30.4 MAX
n1.
5 To the depth of the perforation 24.4+2
n1
3±
0.2
Unreeling direction
0.8
1±
n2
R1
0 .5
2±
φ80±1
φ380 ±2
+0.2
Product Label
22.25
C
Unreeling direction
3
■Crimp socket
D
P= 1.7
Contact No.1 mark
A
B
C
Part No.
HRS No.
DF65-3S-1.7C(**)
DF65-4S-1.7C(**)
DF65-5S-1.7C(**)
DF65-6S-1.7C(**)
DF65-7S-1.7C(**)
666-6005-8 **
666-6007-3 **
666-6002-0 **
666-6009-9 **
666-6015-1 **
No. of
Contacts
3
4
5
6
7
A
B
C
D
6.13
7.83
9.53
11.23
12.93
5.2
6.9
8.6
10.3
12
7.8
9.5
11.2
12.9
14.6
3.4
5.1
6.8
8.5
10.2
None : 1 package contains
100 pcs/pack
Note : Each package contains 100 pcs/pack. Please order in full package quantities.
Crimp contact
1.15
0.92
4.15
0.65
2.3
0.9
4.3
1.07
3
6.1
1.75
φ1
.2
1.45
2.95
4.5
Part No.
DF65-2428SCF
DF65-2428SCFA(**)
HRS No.
666-6003-2
666-6016-4 **
t= 0.15
Description
Reel contact
Reel contact
None : 18,000 pcs/reel
(07) : 18,000 pcs/reel・Gold plated
Quantity
18,000 pcs/reel
18,000 pcs/reel
Finish
Tin plated
Gold plated
Note : This product is sold per reel (18,000 pcs/reel), please order by reel quantities.
● Applicable wire (Tinned, annealed copper wire)
Conductor size (Core structure)
Jacket Diameter
24 AWG (11 pieces/Ø 0.16 mm)
Ø1.11mm
Ø0.98mm
Ø0.88mm
26 AWG (7 pieces/Ø 0.16 mm)
28 AWG (7pieces/Ø 0.127 mm)
●Recommended wire
UL10368
●Strip length
1.4 to 1.8mm
Note : Please contact your local Hirose sales rep if you plan on using wires other than those listed above.
4
Tooling Information
Item
Part No.
HRS No.
Applicable contact
Applicator
Press body
AP105-DF65-2428S
CM-105C
901-4630-0
901-0001-0
DF65-2428SCF, DF65-2428SCFA
Hand tool
HT305/DF65-2428S (Note3)
DF-C-PO (B)
550-0306-8
550-0179-2
DF65-2428SCF
Extraction tool
Note 1 : Hirose does not cover damage created by the use of unapproved Hirose Tools. Please contact your local
Hirose Sales for clarification.
Note 2 : Please conduct crimping work according to the "Crimping work standards" and "Crimping condition table".
Note 3 : The compatible wire is limited to UL10368, 24 to 28 AWG.
Precautionary notes
1. Recommended Soldering
Profile
(Compatible with lead-free
soldering)
[Applicable Conditions]
1. Peak temperature : MAX 250ç
2. Heating Area : 220ç or above, within 60sec .
3. Preheating Area : 150~180ç, 90~120sec.
* Measurement is conducted at the contact lead part
Please check the mounting conditions before use, conditions such as
solder paste types, manufacturer, PCB size and any other soldering
materials may alter the performance of such materials.
(Note 1) This temperature profile is a recommended value only ; please
contact your Hirose Sales Rep for more information
2. R e c o m m e n d e d h a n d
soldering conditions
Temperature of soldering iron : 350±10ç, soldering time : no more than 3
seconds
3. R e c o m m e n d e d s c r e e n
thickness, aperture ratio
(pattern surface ratio)
Thickness : 0.1mm, aperture opening ratio : 100%
4. Warping of PC Board
A maximum of 0.02mm at the center of connector, as measured from either
end of the connector
5. Cleaning Conditions
IPA cleaning is allowed. (Cleaning is not recommended because
cleaning may change the push/pull feeling etc. Please contact your local
Hirose representative prior to the use of any cleaning agents.)
6. Precautions
■ When inserting the crimp contact into the crimp socket, do not insert it at a
slanted angle to maintain the reliability of its performance.
■ Please use caution when mating/unmating this connector if it has not been
mounted onto the PCB, doing so could deform or damage the contacts.
■ Do not pull on the wires of this connector as this may cause damage to the
connector.
■ During the hand soldering process, make sure to not apply too much flux.
Doing so may cause a solder wicking problem.
■ This product may experience some differences in color from one production
lot to another. This color difference does not influence the performance of
the connector.
■ For handling precautions to be used during the insertion/removal process,
please refer to the “DF65 Push-pull procedure” (ETAD-H0803).
■ For the assembly procedure and the instruction manual, please refer to the
“DF65 Cable Assembly Procedure” (ETAD-H0736).
5
7. Mating and Unmating
Operation
Mating operation
① Align the receptacle over the header
② Insert and press down on the
receptacle in the direction of the
arrow.
Reinforced
locking portion
Friction fit
locking portion
③ Completed mating operation
Click feeling
Unmating operation
① Start by lifting up on the front edge of
the receptacle.
② Pull it upward to release the friction fit
lock portion.
Lever
③ Reinforced lock portion will then
be released. Continue lifting the
receptacle in an upward direction.
6
2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN
TEL: +81-45-620-3526 Fax: +81-45-591-3726
http://www.hirose.com
http://www.hirose-connectors.com
The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use.
The contents of this catalog are current as of date of 01/2019. Contents are subject to change without notice for the purpose of improvements.
