NEW
4.5 mm pitch, Horizontal Mating 2-Piece System Connectors
DF64 Series
(UL pending)
◆The floating structure of the BTB connection
provides increased flexibility by absorbing
the movement of the PCB’s.
Y
In two axes of directions
X
Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
Mating
Optimal mating
X axis direction
■Features
1. Versatile Board-to-Board and Board-toWire System
The DF64 Series connector system is a Board-toBoard connector and Board-to-Wire that utilizes a
unique floating structure and a Board-to-Wire
connector that features an excellent locking system
Y axis direction
±0.5mm
2. Floating structure
The Board-to-Board floating structure delivers an
increased connection range together with a wide
effective mating length and width. The unique
stress-free contact structure was designed to
absorb movement and misalignment between serial
PCBs and ensure a continuous connection. (Please
refer to Figure 1)
Movement tolerance range for the X axis: ±0.5 mm
Movement tolerance range for the Y axis: MAX 2 mm
MAX 2mm
Figure 1
◆Two-point contact structure
3. Reliable contact design
(B-to-B connection)
Our two-point contact structure provides a highly
reliable contact system. (Please refer to Figure 2)
A
A
First contact point
Second contact point
[A-A]
4. Stress free side-locking system for
Board-to-Wire connections
The BTW side-locking structure provides a clear
tactile click to confirm completion of the mating
process and also allows for a visual check on the
side locks. The structure endures wiring stress and
prevents the wires from being pulled out of
alignment. (Please refer to Figure 3)
Figure 2
◆BTW side-lock structure
5. 350V voltage capacity
Clear tactile click and
visual check possible.
Its unique mating structure secures a creepage
distance of no less than 3.2 mm between the
contacts and produces a 350 V voltage capacity.
6. PCB layout simplification
The DF64 connector system shares one common
receptacle. This helps to simplify the PCB layout by
accepting the BTB header and the BTW cable plug.
7. Resistant to high heat
Figure 3
These connectors can operate in temperatures of
up to 105ç
In cases where the application will demand a high level of reliability, such as automotive,
please contact a company representative for further information.
2013.11
1
DF64 Series●4.5 mm pitch, Horizontal Mating 2-Piece System Connectors
■Product Specifications
Current
Rating
(Note 1)
Voltage
Rating
Ratings
Item
5A
AWG#18
5A
BtoW
AWG#20
4A
AC/DC 350V
Operating Temperature Range: -55 ∼ to 105℃ (Note 2)
AWG#22
Operating Humidity Range : 20 to 80% (Note 3)
3A
Storage Temperature Range: -10 to 60℃ (Note 4)
Storage Humidity Range : 40 - 70% (Note 4)
Specifications
Conditions
1. Insulation
resistance
No less than 1,000 Mø
Measured at DC 500 V
2. Withstand voltage
No flashover or breakdown
AC 1, 500 V is applied for one minute.
30 Mø max
Measured at no more than DC 6 V, 100 mA (DC or 1,000 Hz)
No electrical discontinuity of 1µs or
greater
No electrical discontinuity outage of
1µs or greater
■ Contact resistance 30 Mø max
■ Insulation resistance 1,000 Mø minimum
Frequency 10-55 Hz, half amplitude 0.75 mm, 10 cycles in each
of three directions(axes)
Accelerated velocity: 490 m/s2, for 11 ms, half-sine in 3
directions, 3 times for each of the three directions (axes)
■Contact resistance 30 Mø max
■Insulation resistance 1,000 Mø minimum
-55ç for 30 minutes → 5 to 35ç for 2 to 3 minutes → 105ç for
30 minutes → 5 to 35ç for 2 to 3 minutes) in 5 cycles
■Number of matings/unmatings
10 mating cycles
Reflow: according to the Recommended Temperature Profile
Hand soldering: temperature of soldering iron at 350ç±10ç for
3 seconds
3. Contact
resistance
4. Vibration
Resistance
BtoB
5. Shock Resistance
6. Moistureresistance
7. Temperature
cycles
8. Durability
9. Resistance to
solder heat
The resin components will not
become deformed or loose
performance due to deformities
Temperature: 40 ±2ç; humidity: 90 to 95%, left as it is for 96 hours
(Note 1) This is the maximum current rating while all pins are powered or used as all power lines.
(Note 2) Includes the temperature rise of power lines.
(Note 3) Use without condensation on parts.
(Note 4) The storage condition refers to long-term storage of the product on the shelf before assembly. Please use the operating
temperature for temporary storage such as pre-assembly and during shipping.
■Materials
Product
Part
Insulator
Contact
Reinforcing metal fittings
Insulator
Contact
Insulator
Contact
Receptacle
Header
Crimp case
Crimp contact
Materials
LCP
Copper alloy
Brass
LCP
Copper alloy
Brass
LCP
Phosphorous Bronze
Finish
Beige
Tin-plating
Tin-plating
Beige
Tin-plating
Tin-plating
Beige
Tin-plating
UL spec.
UL94V-0
UL94V-0
UL94V-0
■Product Number Structure
Refer to the charts below for determining specific part number characteristics.
Please select connectors listed in this catalog when placing orders and be sure to check the latest delivery specifications at the
time of ordering the product.
●Connector
DF 64 - * S - 4.5 H
❶
❷
❸ ❹
❺
❻
DF 64 - * P - 4.5 H
❶
❷
❸ ❹
❺
❻
DF 64 - * P - 4.5 C
❶
❷
❸ ❹
❺
❻
❶ Series Name: DF
❺ Pitch : 4.5 mm
❷ Series No.: 64
❻ Wiring type
H: SMT Right Angle Type
C: crimp housing
❸ Number of contacts: 2, 3
❹ Connector type
S: receptacle P: plug
●Contact
DF 64 - 1822 PCF
❶
2
❷
❶ Applicable wire size
1822 : 18 – 22 AWG
❷ Packaging style
PCF: In-line plug plug contact, on reel
PC: In-line plug contact, loose piece
■Right angle receptacle
2±0.05
10.2
1
B±0.05
2±0.05
P= 4.5
4.7
10.15±0.05
6.15±0.05
2±0.05
1.1±0.05
Recommended PCB layout (t=1.6 mm)
1.5±0.05
P=4.5±0.05
Part Number.
DF64-2S-4.5H
DF64-3S-4.5H
HRS No.
No. of Contacts
667-1002-9-00
2
Under development
3
A
14.4
18.9
B
11.8
16.3
(Note) This product is sold 500 connectors per reel. Please order by full reel quantities.
Unreeling direction
P=24±0.1
P=4±0.1
2±0.15
E-E
+00
.5
1.75±0.1
●Tape and Reel dimensions
φ1
E
C±0.3
D±0.1
.1
10.2
1.5
17
2.5
A
F
E
F
F-F
Part Number
DF64-2S-4.5H
DF64-3S-4.5H
HRS No.
No. of Contacts
667-1002-9-00
2
Under development
3
C
32
44
D
28.4
40.4
3
■ Right angle pin header (SMT)
2.5
1.5
1.1±0.05
B±0.05
P=4.5
4.62
A
2±0.05
10.15±0.05
6.15±0.05
2±0.05
2±0.05
10.2
1
1.5±0.05
Product No.
DF64-2P-4.5H
DF64-3P-4.5H
HRS No.
667-1001-6-00
Under development
No. of Contacts
2
3
A
14.4
18.9
B
11.8
16.3
Unreeling direction
P=24±0.1
P=4±0.1
2±0.15
E-E
+00
.5
E
C±0.3
D±0.1
.1
1.75±0.1
● Tape and Reel dimensions
φ1
10.2
17
A
F
E
F
F-F
Product No.
DF64-2P-4.5H
DF64-3P-4.5H
HRS No.
667-1001-6-00
Under development
No. of Contacts
2
3
C
32
44
D
28.4
40.4
4
■ Crimp socket
4.55
A
B
A
HRS No.
667-1003-1-00
Under development
No. of Contacts
2
3
A
18.4
22.9
B
19.0
23.5
[Specification Number]
None: 1 package contains
100 pieces
(Note) Each package contains 100 pieces. Please order in full package quantities.
■ Crimp contact
2.1
(18.4)
13.6
2.1
4
P=4.5
Part Number
DF64-2P-4.5C
DF64-3P-4.5C
t=0.2
Product No.
DF64-1822PCF
DF64-1822PC
HRS No.
667-1004-4-00
Under development
Type
Reel contact (Note 1)
Loose piece contact (Note 2)
Quantity
Finish
1 reel = 5,000 pieces
Tin-plating
1 package = 100 pieces
(Note 1) This product is sold 5,000 pieces per reel. Please order by full reel quantities.
(Note 2) Each package contains 100 pieces. Please order in full package quantities.
●Applicable wire (Tinned, annealed copper wire)
●Recommended wire
Conductor size (Core structure)
Jacket Diameter
AWG (34 pieces/Ø 0.18 mm)
UL1015(Ø2.9mm)
AWG (21 pieces/Ø 0.18 mm)
AWG (17 pieces/Ø 0.16 mm)
UL1015(Ø2.6mm)
●Strip length
UL1015(Ø2.4mm)
3.0∼4.0mm
UL1015
(Note 1) Applicable wires will have conductors that are comprised of annealed, tin-plated material.
(Note 2) Please contact your local Hirose sales rep if you plan on using wires other than those listed above.
Applicable crimping tool
Item
Applicator
Press body
Hand tool
Part Number
AP105-DF64-1822
CM-105
HT801/DF64-1822
HRS No.
CL901-4633-9-00
CL901-0005-4-00
Under development
Extraction tool
DF62/RE-MD
CL902-4645-4-00
Applicable contact
DF64-1822PCF
DF64-1822PC
DF64-1822PCF
DF64-1822PC
(Note 1) Please conduct crimping work according to the "Crimping work standards" and "Crimping condition table".
(Note 2) Hirose does not cover damage created by the use of unapproved Hirose Tools. Please contact your local
Hirose Sales for clarification.
(Note 3) Hand tools do not have replaceable dies.
(Note 4) Approved wire is limited to UL1015; 18, 20, 22 AWG.
5
Precautionary notes
1.Recommended
Temperature Profile
(Compatible with lead-free
soldering)
[Applicable Conditions]
1. Peak temperature
2. Heating unit: no less than 220℃ for no more than 60 seconds
3. Preheating unit: 150 to 180℃ for 90 to 120 seconds
4. Number of times: 2 times max.
* Measurement is conducted at the contact lead part
Please check the mounting conditions before use. Conditions such as solder paste
types, manufacturer, PCB size and any other soldering materials may alter the
performance of such materials.
(Note 1) This temperature profile is a recommended value only; please contact your
Hirose Sales Rep for more information
2.Recommended hand
soldering conditions
Temperature of soldering iron: 350±10ç, soldering time: no more than 3 seconds
3. Recommended screen
thickness, aperture ratio
(pattern surface ratio)
Thickness: 0.1 mm, aperture ratio: 100%
4. Warping of the Board
A maximum of 0.02 mm at the center of connector, as measured from either end of the
connector
5. Cleaning Conditions
IPA cleaning is allowed. (Cleaning is not recommended because cleaning may change
the push/pull feeling etc. Please contact your local Hirose representative prior to the
use of any cleaning agents. )
■ When inserting the crimp contact into the crimp socket, do not insert it at a slanted
angle to maintain the reliability of its performance.
■ Please use caution when mating/unmating this connector if it has not been mounted
onto the PCB, doing so could deform or damage the contacts.
■ Do not pull on the wires of this connector as this may cause damage to the
connector.
■ During the hand soldering process, make sure to not apply too much flux. Doing so
may cause a solder wicking problem.
6. Important Notes
■ This product may experience some differences in color from one production lot to
another. This color difference does not influence the performance of the connector.
6
6-3,Nakagawa Chuoh-2-Chome,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN
TEL: +81-45-620-3526 Fax: +81-45-591-3726
http://www.hirose.com
http://www.hirose-connectors.com
The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use.
The contents of this catalog are current as of date of 11/2013. Contents are subject to change without notice for the purpose of improvements.
