High Life Cycle Interface Connectors
3800 Series
Hirose's Unique Contact Structure with High Durability
1) Minimum contact shaving due to a rolled surface on the bellows contact side
2) The spring contact design prevents buckling.
3) Stable contact design provides the support needed to endure 20,000 mating cycles
Provides ideal long term contact force.
Rolled surface
Male contact
Bellows contact
Housing
Plug
Plug
Female contact
Fig.q
■Features
1. 20,000 mating/unmating life cycle with
unique Hirose contact structure.
Robust Structure
1) The 0.35 mm thick metal shell protects the housing.
◆Receptacle
2. The structure utilizes a metal shell that
is 0.35 mm thick. The shell is designed
t o c ov e r t h e h o u s i n g a n d p ro t e c t
against rough mechanical operation.
The addition of reinforced metal fittings increases
t h e P C B r e t e n t i o n fo r c e a n d a l l o w s t h e s e
connectors to be mounted with commercially
available screws for the cradle type. (Fig.w)
3. Sequential mating, that features a 0.5
mm range (Fig.e)
◆Cradle plug
2) Protected Guide Posts
Guide Post
The metal shell on the cradle provides
protection and cover to the guide posts
on the cradle plug.
3) Optional screw fastening
The cradle can be secured to the PCB with
the use of commercially available screws (M2
x 0.4 x 5) to provide additional retention force.
4) Reinforcing metal fittings
Commercial screw (optional)
Solder is allowed to flow into the through hole and onto the
reinforcing metal fittings to increase the PCB retention force.
4. Its small size and light weight design
are helpful for use in compact devices
5. Simple mating process with a tactile
cl i ck t h a t a s s u r e s p ro p e r m a t i n g
completion.
◆Plug
Fig.w
Sequential Mating Structure
The No.1 and 18 contacts are the first contacts to mate, with the remaining contacts mating thereafter.
[Effective Mating Length]
1 & 18 Contact: 1.4 mm
2 to 17 Contact: 0.9 mm
The pushbutton locking system leads to a simplified
mating process that delivers a tactile click to ensure
that the mating process was correctly completed.
Contact
No. 1
m
The assembly of this connector is simplified due to
its one-piece plug cover.
m
6. One piece plug cover
0.
5
Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
Receptacle
Receptacle
7. RoHS compliant
Fig.e
Contact No. 18
All materials and substances used to produce this
product comply with the RoHS free standards.
In cases where the application will demand a high level of reliability, such as automotive,
please contact a company representative for further information.
2016.7w
1
3800 Series●High Life Cycle Interface Connectors
■Product Specifications
Ratings
Items
1. Insulation
Resistance
2. Withstanding
Voltage
3. Contact
Resistance
4. Durability
No.2 ∼ N0.17 ⇒ 0.5A
No.1, No.18 ⇒ 1.5A
Rated Current
Rated Voltage
AC 125V
Operating Temperature Range
−40 ∼ +85℃
Specifications
Conditions
Minimum of 1,000Mø
Measured with DC 250V.
No flashover or breakdown
Apply 350V AC for 1 minute
Maximum of 70mø
Measured with 100mA (DC or 1,000 Hz) or
below
1) Maximum of 20mø of deflection from its initial state
2) No damaged, cracked or loose parts
■Materials / Finish
●Receptacle
Component
Housing
Contact
Dust cover
Metal shell
Materials
Polyamide resin
Copper alloy
Polyamide resin
Stainless Steel
Color/Finish
Black
Selective gold plating
Black
Tin plating
Remarks
UL94V-0
UL94V-0
Component
Materials
Color/Finish
Remarks
Housing
Polyamide resin
Black
UL94V-0
Contact
Copper alloy
Metal shell
Stainless steel
Tin plating
Fastening screw metal
Steel
Nickel under plating
Materials
Polyamide resin
Copper alloy
Polycarbonate
Stainless steel
Color/Finish
Black
Black
Remarks
UL94V-0
UL94V-0
●Cradle Type Plug
●Plug
Component
Housing
Contact
Cover
Metal shell
■Product Number Structure
Refer to the chart below when determining the product specifications from the product number.
Please select from the product numbers listed in this catalog when placing orders.
38 40 - B - 18 P
❶
2
❷
❸
❹
❺
❶ Series Number : 38
❸ Mating Key Type
❷ Termination style
40 : Soldering Type
60 : Right Angle SMT Type
80 : Cradle Type SMT Type
❹ No. of Contacts
❺ Type of Connector
P : Plug
S : Receptacle
■Receptacle Connector
20.9
Product Lot Number
Point of contact
(0.5)
B Key slots
No.1, No.18
No.2-17
22.4
22.3
1
No.18
7.5
5
4.3
No.1
No.2-17
20.55
3.5
(0.35)
(0.35)
4
Part No.
HRS No.
Quantity
3860-B-18S
238-2006-7 00
600 pcs/reel
(0.23)
0.8
13.6
■Cradle Plug Connector
32
PCB installation diagram
(10)
No.18
No.2
No.17
3.3
(2.76)
(20.16)
1.3
13.4
B Keys
21
2.4
Screw
M2×0.4×5
PCB(t=1.4∼1.8)
4.2
Product lot number
2.1
(1.6)
No.1
4.6
(0.35)
1.5
19.81
5.2
13.6
0.8
Part No.
HRS No.
3880-B-18P
238-2008-2 00
(0.5)
■Plug Connector
No.18
No.1
23.6
9
(20.16)
(2.76)
6.6
B Keys
27.5
1
1.3
3.5
22.25
(22.6)
8.4
(φ
Part No.
HRS No.
3840-B-18P
238-2007-0 00
6.4
(φ
3
BApplicable Cable
Cross Section
0.08mm2
Configuration
7 / 0.127mm
Outer Diameter
Ø0.38mm
Conductor Size
Outer Diameter of Insulation
Ø0.58mm
Wire Size
28 AWG
UL STYLE OF APPLICABLE CABLE:20620、20276
Ho
le)
BRecommended PCB Layout
r ou
4.3
1.3
Black
40.4
44
19.81
ole
No.2
.2(Ho
5.2
le)
3860-B-18S
2.3
2.7
No.1
No.17
A
(φ
13
(7.5) (49.5)
600 pieces per reel
Vacuum pick-up area dimension
3860-B-18S
5.5
13.6
No.18
hH
ug
ro
Th
1.9(
2xφ
Unreeling Direction
1.2
3.5
PCB Edge
Hole
(φ380)
ough H
ole)
3880-B-18P PCB Dimensions (Reference)
1.5(
2xφ
Plastic Reel Package Dimensions
(0.4)
φ1.6(T
hr
0.5
2xφ2
16
4
2
(30)
P=0.8
3
Embossed Carrier Tape Dimensions
Unreeling Direction
φ1
.3(
Th
20.55
1.75
(t=1.8 MAX)
22.25
Mounting
Surface
gh
3860-B-18S PCB Dimensions (Reference)
BReceptacle
Reel packaging dimensions (JIS C 0806-3)
21
26
BRecommended Reflow Temperature Profile
Cycle: Maximum of 2 reflow cycles
Maximum of 10
seconds
250℃
Temperature
220℃
60 ±10
seconds
150−180℃
90 ±30 seconds
Time
Please check the mounting conditions before use, conditions such as solder paste types, manufacturer, PCB size and any other
soldering materials may alter the performance of such materials.
4
2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN
TEL: +81-45-620-3526 Fax: +81-45-591-3726
http://www.hirose.com
http://www.hirose-connectors.com
The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use.
The contents of this catalog are current as of date of 07/2016. Contents are subject to change without notice for the purpose of improvements.
很抱歉,暂时无法提供与“3840-IM/CK-MP(01)”相匹配的价格&库存,您可以联系我们找货
