The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information.
All non-RoHS products have been discontinued, or will be discontinued soon. Please check the products status on the Hirose website RoHS search at www.hirose-connectors.com, or contact your Hirose sales representative.
FD TYPE CONNECTOR FOR RIBBON CABLE
(1.27-millimeter pitch for standard ribbon cable)
Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
Nov.1.2016 Copyright 2016 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
General
The FD Series connectors are designed for ribbon
cable IDC termination. Connecting wires are grouped,
so the FD Series are useful for labor-saving in connection work and enhancing wiring reliability.
Being compatible with 1.27-mm (standard) ribbon
cables, the FD Series are general-purpose, high-performance connectors that are capable of being interacing with connectors for other types of ribbon cables.
9, 15, 25 and 37-contact models available.
Features
(1) Compact and sturdy due to metal shell.
(2) Can be mounted on the front or back of a panel or
chasis as necessary.
(3) Fixes the cable securely by fixing the ribbon cable
clamp with a metal plate in the connector.
(4) Can be easily connected to a standard ribbon
cable, having a cable IDC pitch of 1.27mm (standard).
(5) Easy to connect cables by following the same IDC
termination and connecting procedures as those
for our other ribbon cable connectors.
Application
Most suitable for modems in communications equipment such as computers, peripherals and terminals,
control equipment, and measuring instruments, and export equipment.
67
04/2009
Electrical and Environmental
Electrical and Environmental Characteristics
Current rating
1A
Voltage rating
200V AC
Insulation
resistance
1,000MΩ min.
at 500V DC
Contact
resistance
25mΩ max.
at 100mA DC
Withstand
voltage
650Vr.m.s. AC
for 1 minute
Material and Finish
Shell
Steel
Nickel plating
Insulator
PBT(GE Valox)
Black
Contacts
Copper alloy
Nickel-plating + Gold plating
Cable specifications
Ordering Informations
FD
B − 25
(1) (2)
P
(1)
(2)
(3)
(4)
Series Name FD: Insulation displacement termination
Shell Size E.A.B.C.
No. of Pin 9, 15, 25, 37
Type of contacts
P: Male contact
S: Female contact
(5) Shell dimpled (male connector only)
(6) Specification contents (05) : Nickel-plated shell
F (05)
(3) (4) (5) (6)
D Subminiature IDC Male
FDB-25P(05)
Unit: mm
68
HRS No
No.of pin
Part No.
A
CL211-0143-8-05
9
FDE-9P(05)
30.81
CL211-0145-3-05
CL211-0135-0-05
CL211-0147-9-05
15
25
37
FDA-15P(05)
FDB-25P(05)
FDC-37P(05)
B
C
D
16.9 24.99 17.6
39.14 25.24 33.32 25.8
53.04 39.01 47.04 39.6
69.32 55.47 63.5 56.14
E
F
G
H
I
J
19
19.28
5.99
1.2
24.39
2.7
27.2
41.4
57.9
27.55
41.28
57.71
5.99
5.87
5.87
1.2
1.3
1.4
24.39
24.37
24.47
2.7
3.2
3.2
RoHS
YES
04/2009
D Subminiature IDC, Male with Grounding Dimples
FDB-25PF(05)
Unit: mm
HRS No
No.of pin
Part No.
CL211-0721-2-05
CL211-0722-5-05
CL211-0723-8-05
9
15
25
FDE-9PF(05)
FDA-15PF(05)
FDB-25PF(05)
CL211-0724-0-05
37
FDC-37PF(05)
A
B
C
D
E
F
G
H
I
J
30.81 16.9 24.99
39.14 25.24 33.32
53.04 39.01 47.04
17.6
25.8
39.6
19
27.2
41.4
19.28
27.55
41.28
5.99
5.99
5.87
1.2
1.2
1.3
24.39
24.39
24.37
2.7
2.7
3.2
69.32 55.47
56.14
57.9
57.71
5.87
1.4
24.47
3.2
63.5
RoHS
YES
69
04/2009
FDB-25S(05)
Unit: mm
HRS No
No.of pin
Part No.
A
B
C
D
E
F
G
H
I
J
CL211-0144-0-05
9
FDE-9S(05)
30.81
16.4
24.99
17.6
19
19.28
6.17
1.2
24.37
2.7
CL211-0146-6-05
CL211-0136-2-05
15
25
FDA-15S(05)
FDB-25S(05)
39.14 24.59 33.32
53.04 38.3 47.04
25.8
39.6
27.2
41.4
27.55
41.28
6.17
6.17
1.2
1.2
24.37
24.37
2.7
3.2
CL211-0148-1-05
37
FDC-37S(05)
69.32 54.76
56.14
57.9
57.71
6.17
1.2
24.37
3.2
63.5
RoHS
YES
Connector Mounting Method and Mounting Dimensions
sConnector mounted on the face of the panel (front mounting)
Unit: mm
Shell size
A1
B1
E
24.99
22
A
33.32
30.3
B
47.04
44
C
63.5
60.5
sConnector mounded on the back of the panel (rear mounting)
Unit: mm
70
Shell size
A2
B2
E
24.99
20.2
A
33.32
28.6
B
47.04
42.5
C
63.5
59.2
04/2009
sConnecting Type
Male Connector
Female Connector
Pin No.
Pin No.
A Type
Cable mark
Cable mark
B Type
C Type
D Type
71
04/2009
Tools
Hi-Flex Connecting Press
Powered by TCPDF (www.tcpdf.org)
Guide Plate
HRS No
HRS No
Part No.
550-0082-2
Hi-Flex connecting press
Height
Width
Pressure Blook (For Plug)
72
Depth Weight
440mm 160mm 350mm
13kg
Part No.
902-0008-9
FDE-GP
902-0011-3
902-0005-0
FDA-GP
FDB-GP
902-0014-1
FDC-GP
Pressure Blook (For Socket)
HRS No
Part No.
HRS No
Part No.
902-0006-3
902-0009-1
902-0003-5
FDE-P pressure block
FDA-P pressure block
FDB-P pressure block
902-0007-6
902-0010-0
902-0004-8
FDE-S pressure block
FDA-S pressure block
FDB-S pressure block
902-0012-6
FDC-P pressure block
902-0013-9
FDC-S pressure block
04/2009
很抱歉,暂时无法提供与“FDC-S”相匹配的价格&库存,您可以联系我们找货
