H.FL-DFS111/CC-AC(62) 数据手册
Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
H.FL Series
SMT Low Profile Small Coaxial Connector
Sep. 2021
H.FL Series/SMT Low Profile Small Coaxial Connector
Features
1. Small Size, Low Profile
6.95
3
Mated height of the receptacle and right angle
plug is only 3mm.
H.FL-LP-DFS111
H.FL-R-SMT
3
6.45
H.FL-LP-DFS111-A
H.FL-R-SMT
H. FL- LP- DFS111- A, H. FL- R- SMT
2.9
8.95
4.5
H. FL- LP- DFS111, H. FL- R- SMT
H. FL- LP- DFS11- A and H. FL- R- SMT PCB Mounting
Space
2. Ultra- fine Coaxial
( Fluorinated Resin Insulated)
Cables
Compatible with φ1. 48mm and φ1. 32mm size
coaxial cables for smooth and easy installment.
3. RF Performance
V. S. W. R. DC to 3GHz : 1. 3 Max.
4. Supports Automatic Mounting
Tape and Reel packaging allows for pick- andplace mounting.
2
5. Clear, Tactile Lock
Compact connector with clear tactile lock enables
reliable mating.
6. RoHS2
Product Specifications
Nominal Characteristic Impedance
50 Ω
Operating Temperature
-40 to +90℃(90% RH Max.)
Rated Voltage
60V AC
StorageTemperature Range
-30 to +70℃(90% RH Max.)
Frequency Range
DC to 3GHz
Item
Specification
Conditions
Contact Resistance
Center : 20m Ω Max.
Outer : 10m Ω Max.
10mA Max.
Insulation Resistance
500M Ω Min
250V DC
Withstanding Voltage
No flashover or insulation breakdown.
300V AC for 1 min.
V.S.W.R.*
1.3 Max.
DC to 3GHz
Female Contact
Retention Force
0.2N Min.
Measured with φ 0.475 pin gauge
Mating Durability
(With Corresponding Plug)
Contact Resistance :
25m Ω Max. (Center)
15m Ω Max. (Outer)
50 cycles
Vibration
No electrical discontinuity of 1μ s min.
No damage, cracks or parts dislocation.
Frequency : 10 to 100Hz, single amplitude of 1.5mm,
acceleration of 59m/s2,
for 5 cycles in the direction of each of the 3 axis.
Shock
Acceleration of 735m/s2, 11ms duration,
sine half-wave waveform, 3 cycles in each of 3 axes.
Humidity
(Steady State)
Insulation Resistance :
10M Ω Min. (High Temperature)
500M Ω Min. (When Dry)
96 hours at temperature of 40℃ and humidity of 95%.
Thermal Shock
25m Ω Max. (Center)
15m Ω Max. (Outer)
Temperature : -40℃ → +5 to +35℃ →
+90℃ → +5 to +35℃
Time : 30min. → 5min. → 30min. → 5min.
5 cycles
Salt Spray
No significant corrosion
5% salt water solution, 48 hours
* V. S. W. R. Measurement System
The above V. S. W. R. standard values were measured using the measurement system shown below.
Network Analyzer
Test Set
Test Port
Test Port Cable
D.U.T Termination
Note 1 : Cable type connectors were measured with SMA conversion adapters attached to both ends of the harness product of a suitable 100cm cable.
Note 2 : Board type connectors were mounted to a 50φ glass epoxy board and measurements were conducted with SMA conversion adapters attached.
3
Materials / Finish
Part
Material
Finish
Flame Retardance
Shell
Phosphor Bronze
Silver Plated
Male Center Contact
Brass
Female Center Contact
Phosphor Bronze
Insulator
Gold Plated
Plug
PBT
Receptacle
LCP
Black
UL94V-0
Product Number Structure
Refer to the chart below when determining the product specifications from the product number.
Please select from the product numbers listed in this catalog when placing orders.
● Plug
H.FL - LP - DFS111 - A(01)
❶
● Female
❷
❸
❹
❻
Terminal
H.FL - LP Female Terminal
❶
❷
❸
● Receptacle
H.FL - R - SMT (C) (10)
❶
❷
❸
❺
❻
❶
Series Name
H.FL
❹
Plug Type
(Note 1)
❷
Connecter Type
LP :Right Angle Plug
R : Receptacle
❺
Receptacle
(C) : With Suction Cap
None : Without Suction Cap
❸
Compatible Cable
or
Board Mounting
Method
Plug
DFS111 : φ 1.48 Cable
A32 : φ 1.32 Cable
Female Terminal : Female Terminal for Plug
❻
Packing Types
(Note 2)
(01) : Packing(100pcs per pack)
(10) : Reel Packing(2,500pcs per Reel)
Receptacle
SMT : Printed Circuit Board Surface Mount
Type
Note 1 : Refer to the "Right Angle Plug" section for plug specifications.
Note 2 : Specification (10) is only available for the receptacle.
4
(A): Without Plug Ferrule
None : With Plug Ferrule
● How
to Designate Plug Cable Assembly Dimensions
The dimension specifications of the H. FL Series harness are as follows.
[ Single-ended Cable Assembly ]
[ Double-ended Cable Assembly ]
L(mm)
L(mm)
Ordering information
Note : Designate the dimensions from the center of the connector for both single-ended and double-ended cable assemblies. (Please write length L in mm.)
● Cable
Assembly Product Number Structure
H.FL - 2LP (A) - # - A -(L)
❶
❷
❸
❹
❺
❶
Series Name
H.FL
❸
Plug Type
(Note)
❷
Assembly Type
LP : Single Ended
2LP : Double Ended
❹
Cable Type
❺
Total Length
(mm)
Note : Refer to the "Right Angle Plug" section for plug specifications.
● Standard
Tolerances for (L)
Total Length(mm)
Standard Tolerance(mm)
35 ≦ L ≦ 200
±4
200 < L ≦ 500
±8
500 < L ≦ 1000
± 12
1000 < L
± 1.5%
Note : The shortest length is L = 35mm.
5
111, FHSB, 084* : φ 1.48 Cable
066N*, 0733 : φ 1.32 Cable
L length (mm)
Right Angle Plug
We accept cable assembly orders for the plug as well.
Ferrule
A
Female Terminal
Sold Separately
H.FL-LP-DFS111(01)
φ1.48 Cable
A
Female Terminal
Sold Separately
H.FL-LP-DFS111-A(01)
φ1.48 Cable
Item
Right Angle Plug Shell
(φ 1.48 Cable)
(φ 1.32 Cable)
Female Terminal
Part No.
H.FL-LP-DFS111(01)
H.FL-LP-DFS111-A(01)(Note)
HRS No.
Dimension A
CL0331-0503-4-01
CL0331-0507-5-01
(6.95)
(6.45)
H.FL-LP-A32-A(01) (Note)
CL0331-0508-8-01
(6.45)
H.FL-LP Female Terminal
CL0331-0511-2-00
Note : H.FL-LP-DFS111-A(01) and H.FL-LP-A32-A(01) do not require a ferrule. (Reduces cable assembly time)
6
Purchase Unit
100pcs
per pack
10,000pcs
per reel
Receptacle
GND
GND
GND
SIG
φ0.5
3-0.8
1.5 Max.
5
4.5
0.6
4.5
4
Part No.
HRS No.
Purchase Unit
H.FL-R-SMT(01)
CL0331-0521-6-01
100pcs per pack
H.FL-R-SMT(10)
CL0331-0521-6-10
2,500pcs per reel
Note : Tolerance value of mold resin applied to center contact.
1±0.05
2.8±0.05
●Recommended PCB Mounting Pattern
2±0.05
GND
3±0.05
3×1.2±0.05
GND
GND
SIG
1.5±0.05
1.2±0.05
3.1±0.05
3.1±0.05
Receptacle With Suction Cape
Final Product
Overview Diagram
φ0.5
Cap
5
4.5
0.6
3×0.8
(Note 1)
1.5 Max.
1.7
φ2.4
4.5
4
(Note)
1.7
φ2.4
Part No.
H.FL-R-SMT(C)(10)
HRS No.
Purchase Unit
CL0331-0522-9-10
2,500pcs per reel
Note 1 : Tolerance value of mold resin applied to center contact.
Note 2 : This product comes with a suction cap compatible with any automated mouting machine.
The receptacle cannot be mated with the cap on, so please remove before use.
7
Conversion Adapter
SMA Conversion Adapter (Mated Portion- H.FL Side : Jack, SMA Side : Plug)
(11.7)
8HEX
Part No.
HRMP-H.FLJ(40)
HRS No.
Purchase Unit
CL0311-0232-4-40
20pcs per pack
Note : The mating portion on the H.FL side does not have a locking mechanism, so it cannot be used for anything other than performance measurement.
SMA Conversion Adapter (Mated Portion - H.FL Side : Plug, SMA Side : Jack)
6
14.2
(4.05)
5.6
φ6.35
φ2.3
2.4
1/4-36UNS-2A
Part No.
HRMJ-H.FLP-3(40)
HRS No.
Purchase Unit
CL0311-0264-0-40
20pcs per pack
8
Inspection Receptacle
Receptacle for testing the conduction, withstanding voltage, etc. of the cable assembly.
13.1
(8.1)
5
1
φ2.3
7HEX
M5×0.5
Part No.
H.FL-R-1
HRS No.
Purchase Unit
CL0331-0516-6-00
20pcs per pack
Note : Product cannot be used for purposes other than conduction or withstanding voltage inspection because there is no lock on the mating portion.
9
Embossed Carrier Tape Dimensions
1.75
Dimensions of the Embossed Carrier Tape for H. FL- R- SMT( 10) are shown below.
φ1.5
Central Contact
4
8
(2.4)
Unreeling Direction
Reel Dimensions
φ330
13.5
A
A
2
3
φ1
φ2
1
Contact Extraction Tool
5
φ1
3.3
6
Tool for Unmating.
100
40
3
12
5.5
2
Part No.
H.FL-LP-N
HRS No.
Purchase Unit
CL0331-0551-7-00
1pc per pack
10
Usage Precautions
1.
Plugs
1. Mating/ Unmating
( 1)To disconnect the connector, insert the extraction tool ( H. FL- LP- N) under the connector flange.
Pull in a perpendicular direction in line with the connector' s mating axis.
Do not unmate the plug by pulling on the cable, this can damage the connector performance.
( 2)When mating, align the mating axes between the receptacle and cable assembly, and insert the cable assembly
downward and perpendicular into the receptacle.
Do not insert the cable assembly at a slanted angle.
3N Max.
5N Max.
H.FL-LP*
H.FL-R-SMT
3N Max.
3. Precautions
Do not use excessive prying to mate or un- mate the connectors as it may lead to damage.
2.
Receptacles
Heating Peak
250℃ 10 Seconds
260
(1) Recommended
Reflow Temperature Profile
Temperatue of Top of Component
2. Tolerable load to a cable after mating
Once the connector has been mated do not apply forces exceeding the values in the diagram below.
240
230℃
220℃
220
200
180
160
140
120
100
80
50 Seconds or Less
120 Seconds or Less
60 Seconds or Less
Time
1. Temperature refers to the temperature of the PCB surface at the terminal leads.
2. Reflow soldering should be performed at a printed circuit surface temperature of 250℃ Max.
3. The temperature profile may vary depending on board size, solder used and solder thickness.
(2) Recommended
Manual Soldering Conditions
Manual soldering : 350℃ for 5 seconds
(3) Recommended
Metal Mask Thickness
0.1mm to 0.15mm
(4) Reflow Cycles
2 times
11
3.
Operating Environment and Storage Conditions
1. Operation Environment
This product was designed for use in a normal environment.
Please be advised that using this product in the environments described below may result in discoloration and other
types of degradation.
・Exposure to excessive amounts of fine particles and dust.
・Regions/ areas with a high concentration of gases like sulfur dioxide, hydrogen sulfide and nitrogen dioxide.
・Areas with drastic temperature changes, such as locations near a heater.
2. Storage conditions
Store this product in Hirose' s packaging or similar conditions.
Temperature : - 10 to + 40℃ Humidity : 85% or less ( recommended storage conditions)
We recommend the product be used within six months from delivery.
Products that have been stored beyond the recommended storage period need to be tested for mounting and
solderability before use.
3. Silver Plating Discoloration
Discoloration occurs only on the plating surface. Since the contact portion is wiped, there is no effect on the electrical
contact.
12
Standard Connectors the Connect with H.FL
SMA Cable Type
Straight Plug
15
1/4-36UNS-2B
8HEX
Part No.
HRS No.
Applicable Cable
HRM-200-066PBN(40)
CL0323-0791-6-40
φ 1.32 Cable
HRM-200-088PBN(40)
CL0323-0800-5-40
φ 1.48 Cable
HRS No.
Applicable Cable
HRM-200-066JBN(40)
CL0323-0793-1-40
φ 1.32 Cable
HRM-200-088JBN(40)
CL0323-0801-8-40
φ 1.48 Cable
Straight Jack
17
4.5
8
1/4-36UNS-2A
8HEX
Part No.
13
Panel Jack (4 Screw Type)
9.55
1.7
12.7
8.64
1/4-36UNS-2A
4-φ2.6
φ6.4
17
Part No.
HRS No.
Applicable Cable
HRM-200-066PJ4BN(40)
CL0323-0796-0-40
φ 1.32 Cable
HRM-200-088PJ4BN(40)
CL0323-0803-3-40
φ 1.48 Cable
HRS No.
Applicable Cable
HRM-200-066PJ2BN(40)
CL0323-0788-1-40
φ 1.32 Cable
HRM-200-088PJ2BN(40)
CL0323-0802-0-40
φ 1.48 Cable
Panel Jack (2 Screw Type)
17
9.55
1.7
1/4-36UNS-2A
8
2×φ2.6
φ6.4
Part No.
14
Panel Jack (Nut Type)
1.5
17
11
1/4-36UNS-2A
8HEX
5.85
φ10
Part No.
HRS No.
Applicable Cable
HRM-200-066BPJBN(40)
CL0323-0798-5-40
φ 1.32 Cable
HRM-200-088BPJBN(40)
CL0323-0804-6-40
φ 1.48 Cable
Mounting Hole Dimensions
5.9 +0.1
φ6.4 +0.1
RP-SMA Cable Type
● Straight Jack
17
4.5
8
8 HEX
1/4-36UNS-2A
Part No.
HRS No.
Applicable Cable
SMA(R)-200-066JBN
CL0323-0931-3-00
φ 1.32 Cable
SMA(R)-200-088JBN
CL0323-0904-0-00
φ 1.48 Cable
17
12.7
9.55
1.7
8.64
1/4-36UNS-2A
.6
φ2
4×
Part No.
HRS No.
Applicable Cable
SMA(R)-200-066PJ4BN
CL0323-0932-6-00
φ 1.32 Cable
SMA(R)-200-088PJ4BN
CL0323-0934-1-00
φ 1.48 Cable
16
17
8
9.55
12.2
1/4-36UNS-2A
.6
φ2
2×
Part No.
HRS No.
Applicable Cable
SMA(R)-200-066PJ2BN
CL0323-0933-9-00
φ 1.32 Cable
SMA(R)-200-088PJ2BN
CL0323-0935-4-00
φ 1.48 Cable
HRS No.
Applicable Cable
SMA(R)-200-066BPJBN
CL0323-0902-5-00
φ 1.32 Cable
SMA(R)-200-088BPJBN
CL0323-0901-2-00
φ 1.48 Cable
17
1.5
8 HEX
11
5.85
φ10
1/4-36UNS-2A
Part No.
4+
5.9 +0.1
φ
6.
1.7
17
■Applicable Tools for SMA and RP-SMA Cable Type Connectors
Part No.
HRM-200-066PBN(40)
HRM-200-088PBN(40)
HRM-200-066JBN(40)
HRM-200-088JBN(40)
SMA(R)-200-066JBN
SMA(R)-200-088JBN
SMA(R)-200-066J4BN
SMA(R)-200-088J4BN
SMA(R)-200-066PJ2BN
SMA(R)-200-088PJ2BN
SMA(R)-200-066BPJBN
SMA(R)-200-088BPJBN
Wiring Tool
HRS No.
Overview
HRM-200/SO-MD
CL0902-3192-6-00
Cord Soldering Cradle
HRM-200/SO-MD2
CL0902-3199-5-00
Terminal Soldering Cradle
HRM-200-PBN/CV-MD
CL0902-3198-2-00
Cord Press-fit Tool
HRM-200/SO-MD
CL0902-3192-6-00
HRM-200/SO-MD2
CL0902-3199-5-00
HRM-200-JBN/CV-MD
CL0902-3195-4-00
Cord Press-fit Tool
HRM-200/SO-MD
CL0902-3192-6-00
HRM-200/SO-MD2
CL0902-3199-5-00
HRM-200-PJ4BN/CV-MD
CL0902-3197-0-00
Cord Press-fit Tool
HRM-200/SO-MD
CL0902-3192-6-00
HRM-200/SO-MD2
CL0902-3199-5-00
HRM-200-PJ2BN/CV-MD
CL0902-3196-7-00
Cord Press-fit Tool
HRM-200/SO-MD
CL0902-3192-6-00
HRM-200/SO-MD2
CL0902-3199-5-00
HRM-200-BPJBN/CV-MD
CL0902-3194-1-00
Cord Press-fit Tool
HRM-200/SO-MD
CL0902-3192-6-00
HRM-200/SO-MD2
CL0902-3199-5-00
HRM-200-JBN/CV-MD
CL0902-3195-4-00
Cord Press-fit Tool
HRM-200/SO-MD
CL0902-3192-6-00
HRM-200/SO-MD2
CL0902-3199-5-00
HRM-200-PJ4BN/CV-MD
CL0902-3197-0-00
Cord Press-fit Tool
HRM-200/SO-MD
CL0902-3192-6-00
HRM-200/SO-MD2
CL0902-3199-5-00
HRM-200-PJ2BN/CV-MD
CL0902-3196-7-00
Cord Press-fit Tool
HRM-200/SO-MD
CL0902-3192-6-00
HRM-200/SO-MD2
CL0902-3199-5-00
HRM-200-BPJBN/CV-MD
CL0902-3194-1-00
Cord Press-fit Tool
18
■ Cable Assembly Specifications
Designate and order the length specification of the H. FL Series and SMA or RP- SMA double- ended assembly based on the
below length specification diagram.
Lmm
15
A
Lmm
17
12.5
A
9.55
Lmm
1.7
7.45
9.55
1.7
7.45
11
A
Lmm
6
A
Lmm
1.5
A
Note : The shortest length is L = 50mm
Cable
φ 1.48
φ 1.32
Plug
A
H.FL-LP-DFS111(01)
6.95
6.45
H.FL-LP-A32-A(01)
6.45
19
While Taking into Consideration
Specifications mentioned in this catalog are reference values.
When considering to order or use this product, please confirm the Drawing and Product Specifications sheets.
Use an appropriate cable when using the connector in combination with cables.
If considering usage of a non- specified cable, please contact your sales representative.
If assembly process is done by jigs & tools which are not identified by Hirose, assurance will not be given.
If considering usage for below mentioned applications, please contact your sales representative.
In cases where the application will demand a high level of reliability, such as automotive, medical instruments, public
infrastructure, aerospace/ defense etc. Hirose must review before assurance of reliability can be given.
2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN
https://www.hirose.com
※ The contents of this catalog are current as of date of 9/ 2021. Contents are subject to change without notice for the purpose of improvements.
