High Speed Transmission, 1mm Pitch Small Interface Connector
DH Series
Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
Mating Face Area
Approximately 50% Reduced
Fig.1
■Overview
DH Series is an impedance controlled interface connector
for high speed transmission.
With a contact pitch of 1mm, the DH Series has a compact
and thin design, enabling higher density mounting
compared to generic half-pitch connectors.
4 different lock styles are available to meet various
application needs.
Grounding Structure
Panel
■Features
Metal Shielding
1. Small Design
With a contact pitch of 1mm and mounted pitch of 0.5mm,
the mating face area is reduced by approximately 50%
when compared to existing Hirose half-pitch connectors.
(Fig.1)
PCB
Fig.2
2. Robust Design
The D-shaped shell design enhances prying force.
Through-hole mounting of the shell and retention tabs
increases PCB retention force.
3. Unique Contact Arrangement for IDC Termination
The stagerred 2 row IDC contact arrangement reduces
plug size. Additionally, the 2 types of press plates, white
and black, can be used to prevent mis-wiring.
4. Excellent Shielding for EMI Prevention
The plug is covered with a metal shield and the ground
can be dropped to the panel or board. (Fig. 2)
5. Wide Variation
Wide product range available including screw lock types,
one touch lock types and variations to accommodate an
array of panel thicknesses.
6. Applicable for High Speed Data Transmission
Twinaxial cabling enables high speed transmission.
(Varies based on cable length and board)
In cases where the application will demand a high level of reliability, such as automotive,
please contact a company representative for further information.
2021.4③
1
DH Series●High Speed Transmission, 1mm Pitch Small Interface Connector
This data is for reference only. Data may differ based on the cable or PCB used in evaluation.
Eye Diagram
[ CH1-CH2 ]
500Mbps
1Gbps
(Cable:10m)
2.5Gbps
(Cable:5m)
(Cable:2m)
Measurement Method
Pin Assignment
G : Ground
S : Signal
Pair B
G-S-S-G
Pair A
G-S-S-G
Pair A
Pulse Pattern Generator
Measurement Method
·Measurement Pair : Deferential Pair A
·Cable : Twinax Cable
·Input Signal Voltage : 500mV
Cable Length
2
Pair B
Oscilloscope
■Specifications
Rated Current
Rated Voltage
Ratings
Item
1.Contact Resistance
2.Insulation Resistance
3.Withstanding Voltage
4.Insertion and
Withdrawal Force
Specification
50mø max. (IDC type) 65mø max. (Solder type)
1000Mø Min.
No flashover or insulation breakdown
17pos.
27pos.
37pos.
51pos.
Insertion f.
25N Max. 30N Max. 36N Max. 43N Max.
Withdrawal f. 2.6N Min. 3N Min. 3.3N Min. 3.8N Min.
1
6.Vibration
7.Shock
1
8.Temperature Cycles
9.Humidity (Steady State)
10.Salt Spray Test
–25ç to +85ç
–25ç to +60ç
Operating Temperature
Storage Temperature
1
5.Mating Durability
1
0.5A
125V AC
Conditions
100mA (DC or 1,000Hz)
100V DC
250V AC per min.
Measured with applicable connector.
①Contact resistance : 70mø Max. (IDC type)
85mø Max. (Solder type)
②No damage, cracks or parts dislocation.
1000 cycles
①No electrical discontinuity of 10µs or longer.
Frequency : 10 to 50Hz, single amplitude of
0.75mm, 5min/cycle, total 10 cycles.
Acceleration of 490m/s2, 11ms duration, sine half-wave
waveform, 3 cycles in each of the 3 axis.
①Insulation resistance : 100Mø Min.
No heavy corrosion resulting in a loss of function.
Excludes wire conductor resistance.
Temperature : -55ç/+5ç to +35ç/+85ç/5ç to+35ç
Time : 30/5/30/5(Minutes) 5cycles
96 hours at 40ç And RH 90% to 95%.
5% salt water solution for 48 hours.
*Unless otherwise specified, refer to JIS C 5402
■Materials
Products
Screw Lock Type Receptacle Connector
(DH60-**P / DH80-**P)
One Touch Lock Type Receptacle Connector
(DH60A-**P / DH80A-**P)
Plug Connector
(DH3*B-**S)
Plug Connector
(DH40-**S)
Screw Lock Type Cover Case
(DH-**-CV1B)
Hand-screw Lock Type Cover Case
(DH-**-CV2B)
One Touch Lock Type Metal Button Cover Case
(DH-**-CT1B)
One Touch Lock Type Plastic Button Cover Case
(DH-**-CT2B)
Lock Screw
(DH-LNA***)
Metal Clamp (DH-CMB(**))
Components
Insulator
Contacts
Shell
Retention Tab
Insulator
Contacts
Shell
Retention Tab
Metal Grounding Post
Insulator
Contacts
Rear Insert
Shell
Material
Polyamide Resin
Copper Alloy
Stainless Steel
Stainless Steel
Polyamide Resin
Copper Alloy
Stainless Steel
Brass
Steel
Polyamide Resin
Copper Alloy
PBT Resin
Stainless Steel
Finish
Black
Partially Gold Plated
Tin Plated
Partially Tin Plated
Black
Tin Plated
Tin Plated
Nickel Plated
Black
Black, Natural
Nickel Plated
Remarks
UL94V-0
Black
Nickel Plated
Nickel Plated
Black Chromate(Cr+3)
Black
Nickel Plated
Nickel Plated
Black
Black
Nickel Plated
UL94V-0
------UL94V-0
--------UL94V-0
--UL94V-0
Insulator : Polyamide Resin Rear Insert : Polyamide Resin
Contact : Copper Alloy
Cover
Shield
Screw Lock
Tapping Screw
Cover
Shield
Screw Lock
Screw Insulator
Tapping Screw
Cover
Shield
Lock Spring
Tapping Screw
Cover
Shield
Lock Spring
Button
Tapping Screw
Screw Lock
Washer
Spring Washer
Metal Clamp
Shell : Stainless Steel
Polycarbonate Resin
Stainless Steel
Steel
Steel
Polycarbonate Resin
Stainless Steel
Steel
Polyamide Resin
Steel
Polycarbonate Resin
Stainless Steel
Stainless Steel
Steel
Polycarbonate Resin
Stainless Steel
Stainless Steel
Polycarbonate Resin
Steel
Steel
Steel
Steel
Brass
--Black Chromate(Cr+3)
Black
Nickel Plated
--Black
Nickel Plated
Nickel Plated
Nickel Plated
------UL94V-0
----UL94V-0
--UL94V-0
------UL94V-0
----UL94V-0
3
■Product Number Structure
Refer to the chart below when determining the product specifications from the product number.
Please select from the product numbers listed in this catalog when placing orders.
●Receptacle
●Lock Screw
DH 60 − 27 P
❶
❷
❹
DH − LNA − W16
❺
❶
❽
❾
●Plug
●Metal Clamp
DH 30 B − 27 S
DH − 27 − CM B (7.3)
❶
❷
❻
❹
❺
❶
❹
❻
●Cover Case
DH − 27 − CV1 − B
❶
❹
❼
❶Series Name
❷Termination Style
❻
3※
40
60
80
Blank
A
❸Lock Style
❹No. of Pos.
❺Contact Gender
P
S
❻Serial No.
❼Cover Type
CV1
CV2
CT1
CT2
❽Lock Screw
❾Panel Thickness
Metal Clamp
Cable Outer Diameter
Blank
W4
W8
W16
DH
IDC Type
Solder Type
Right Angle SMT
Straight SMT
Screw Lock Type
One Touch Lock Type
17, 27, 37, 51
Female Type
Male Type
Screw Lock Type (Locked with screwdriver)
Screw Lock Type (Hand-screw)
One Touch Lock Type
One Touch Lock Type (Plastic Button)
LNA
1.4 to 1.6
0.9 to 1.2
0.5 to 0.8
No Panel
CM
(5.6), (6.3), (6.6), (6.9), (7.3), (7.8), (8.8), (9.0), (9.6)
■Functionality Diagram
DH Screw Lock Type
●Screwdriver Locking Type
●IDC Plug
●Right Angle Receptacle
●Metal Clamp
●Lock Screw
●Hand-screw Type
●Manual Solder Plug
●Straight Receptacle
●Metal Button
●IDC Plug
●Plastic Button
●Manual Solder Plug
DH One Touch Lock Type
●Metal Clamp
4
Screw Lock Type
■Receptacle Connector
A
B
0.5
Ø2
.3
×0
.4
4
(8)
●Right Angle Type
C
Contact No. H
(Ø1)
1.1
No. of Pos.
17
27
37
51
A
25
30
35
42
B
8
13
18
25
C
(19.2)
(24.2)
(29.2)
(36.2)
D
19
24
29
36
E
19.2
24.2
29.2
36.2
0.5
F
24.8
29.8
34.8
41.8
G
9
14
19
26
H
10
15
I
17
27
37
51
Remarks
●Straight Type
Ø1
(1.5)
27.8
16.5
4.9
4
(1.5)
30.8
(24.2)
Part No.
DH80-27P
HRS No.
244-0051-2 00
No. of Pos.
27
Remarks
6.5
4.6
DH80-27P
Contact No.14
M2.3×0.4
Contact No.15
Contact No.27
2.75
4.4
Contact No.1
2.4
■Lock Screw
M2∞0.4
M2.3∞0.4
DH-LNA
HRS No.
244-0045-0 00
244-0046-2 00
244-0004-2 00
244-0005-5 00
M2∞0.4
4.4
(14.4)
1.6
4.4
DH-LNA-W4
Ø3
M2∞0.4
M2.3∞0.4
M2.3∞0.4
DH-LNA-W8
Applicable Panel Thickness (mm)
1.4 to 1.6
0.9 to 1.2
0.5 to 0.8
.6
(14.4)
0.8
(14.4)
0.4
4.4
4.4
M2∞0.4
Part No.
DH-LNA
DH-LNA-W4
DH-LNA-W8
DH-LNA-W16
.6
Ø3
2.5
2.5
2.5
Ø3
2.5
.6
.6
Ø3
(14.4)
HRS No.
244-0006-8 00
244-0001-4 00
244-0007-0 00
244-0008-3 00
1.56
Contact No. I
D
E
F
DH60-27P
Part No.
DH60-17P
DH60-27P
DH60-37P
DH60-51P
(0.9)
1.6
4.8
Contact No. G
Contact No.1
M2.3∞0.4
DH-LNA-W16
Remarks
No Panel
5
■Cover Case
ØA
(25.4)
B
●Screw Lock (Used with Screwdriver)
11.7
C
DH-27-CV1B
Part No.
DH-17-CV1B
DH-27-CV1B
DH-37-CV1B
DH-51-CV1B
HRS No.
244-0009-6 00
244-0010-5 00
244-0011-8 00
244-0012-0 00
No. of Pos.
17
27
37
51
A
(7.8)
(8.8)
(10.3)
(11.1)
B
31.4
31.4
39
39
C
26
31
36
43
Remarks
Cable Outer Diameter 5.1 to 7.1mm
Cable Outer Diameter 6.6 to 7.8mm
Cable Outer Diameter 7.3 to 9.3mm
Cable Outer Diameter 8.5 to 10.1mm
ØA
(25.4)
B
●Screw Lock (Hand-screw)
11.7
C
DH-27-CV2B
Part No.
DH-17-CV2B
DH-27-CV2B
DH-37-CV2B
DH-51-CV2B
6
HRS No.
244-0013-3 00
244-0014-6 00
244-0015-9 00
244-0016-1 00
No. of Pos.
17
27
37
51
A
(7.8)
(8.8)
(10.3)
(11.1)
B
31.4
31.4
39
39
C
26
31
36
43
Remarks
One Touch Lock Type
A
B
0.5
5.2
4
8
●Right Angle Type
C
4.8
D
(0.9)
1.6
Contact No.
1
Contact No.
H
M2×0.4
Contact No.I
(0.95)
E
F
G
No. of Pos.
17
27
37
51
A
25.8
30.8
35.8
42.8
B
8
13
18
25
C
17.2
22.2
27.2
34.2
D
(21.2)
(26.2)
(31.2)
(38.2)
●Straight Type
E
19
24
29
36
F
19.2
24.2
29.2
36.2
A
B
C
Ø1
D
E
Contact No.1
DH80A-27P
Part No.
DH80A-27P
DH80A-37P
HRS No.
244-0052-5 00
244-0068-5 00
B
21.3
26.3
C
16.5
21.5
I
10
15
J
17
27
37
51
Remarks
(1.5)
Contact No.F
M2×0.4
2.4
Contact No.G
No. of Pos.
A
27
27.8
37
32.8
H
9
14
19
26
4
4.9
2.45
(1)
G
24.8
29.8
34.8
41.8
2.75
4.4
HRS No.
244-0038-4 00
244-0029-3 00
244-0040-6 00
244-0043-4 00
Contact No.
J
(1.5)
Part No.
DH60A-17P
DH60A-27P
DH60A-37P
DH60A-51P
6.5
4.6
DH60A-27P
(0.7)
(1.56)
D
E
30.8 (26.2)
35.8 (31.2)
Contact No.H
F
14
19
G
15
H
27
37
Remarks
7
ØA
■Cover Case
(17)
B
●Metal Button Type
11.7
C
DH-27-CT1B
Part No.
DH-17-CT1B
DH-27-CT1B
DH-37-CT1B
DH-51-CT1B
HRS No.
244-0039-7 00
244-0030-2 00
244-0041-9 00
244-0044-7 00
No. of Pos.
17
27
37
51
A
(7.8)
(8.8)
(10.3)
(11.1)
B
31.4
31.4
39
39
C
26
31
36
43
Remarks
ØA
(17)
B
●Plastic Button Type
11.7
C
DH-27-CT2B
Part No.
DH-17-CT2B
DH-27-CT2B
DH-37-CT2B
DH-51-CT2B
8
HRS No.
244-0047-5 00
244-0048-8 00
244-0049-0 00
244-0050-0 00
No. of Pos.
17
27
37
51
A
(7.8)
(8.8)
(10.3)
(11.1)
B
31.4
31.4
39
39
C
26
31
36
43
Remarks
■Plug Unit
Contact No.G
C
(9.55)
3.9
3.9
Contact No.E
A
B
(1)
(0.5) Contact No.1
(6.65)
●IDC Type
Contact No.F
(8.2)
(16.02)
No. of Pos.
17
27
37
51
17
27
37
51
A
(14.8)
(19.8)
(24.8)
(31.8)
(14.8)
(19.8)
(24.8)
(31.8)
B
(8)
(13)
(18)
(25)
(8)
(13)
(18)
(25)
C
(7)
(12)
(17)
(24)
(7)
(12)
(17)
(24)
D
(11)
(16)
(21)
(28)
(11)
(16)
(21)
(28)
E
9
14
19
26
9
14
19
26
F
10
15
10
15
G
17
27
37
51
17
27
37
51
Remarks
Conductor Size : 28 AWG
Insulator Outer Diameter :
Ø0.9±0.04
Ø0.66±0.04
●Solder Contact Type
A
B
(1)
(0.5)
Contact No.D
Contact No.1
DH40
A
(8.2)
C
Contact No.D
Contact No.1
6.65
9.55
HRS No.
244-0017-4 00
244-0018-7 00
244-0019-0 00
244-0020-9 00
244-0021-1 00
244-0022-4 00
244-0023-7 00
244-0024-0 00
D
6.18
6.18
A
Part No.
DH30B-17S
DH30B-27S
DH30B-37S
DH30B-51S
DH32B-17S
DH32B-27S
DH32B-37S
DH32B-51S
B
DH30B-27S
D
Contact No.E
Contact No.F
Contact No.E (15.7)
Contact No.F
DH40-27S
Part No.
DH40-17S
DH40-27S
DH40-37S
DH40-51S
HRS No.
244 0054-0 00
244 0053-8 00
244 0055-3 00
244 0056-6 00
Part No.
B
(8)
(13)
(18)
(25)
C
(7)
(12)
(17)
(24)
D
9
14
19
26
E
10
15
F
17
27
37
51
Remarks
HRS No.
244-0064-4 00
244-0031-5 00
244-0063-1 00
244-0036-9 00
244-0032-8 00
244-0065-7 00
244-0033-0 00
244-0066-0 00
244-0034-3 00
RF
B
C
[27pos.:DH-27-CMB(6.9)]
(Cable Outer Diameter 6.9mm)
DH-17-CMB(5.6)
DH-17-CMB(6.3)
DH-17-CMB(6.6)
DH-27-CMB(6.9)
DH-27-CMB(7.3)
DH-37-CMB(7.8)
DH-37-CMB(8.8)
DH-51-CMB(9.0)
DH-51-CMB(9.6)
A
(14.8)
(19.8)
(24.8)
(31.8)
RE
■Metal Clamp
No. of Pos.
17
27
37
51
4.7
A
D
A
(5.5)
(5.5)
(5.5)
(5.5)
(5.5)
(6.1)
(6.1)
(6.1)
(6.1)
B
(11.9)
(11.3)
(12)
(13.5)
(14.4)
(15.7)
(17.6)
(16.9)
(18.4)
C
(7.4)
(9.3)
(8.8)
(10.1)
(10.2)
(9.6)
(12.1)
(10.8)
(13.1)
Remarks
D
E
F
8.7 (3.35) (3.15) Cable Outer Diameter 5.6±0.5mm
9
(3.55) (3.35) Cable Outer Diameter 6.3±0.5mm
9.8 (3.9) (3.7) Cable Outer Diameter 6.6±0.5mm
10.6 (4.2)
(4) Cable Outer Diameter 6.9±0.3mm
9.5 (4.5) (4.3) Cable Outer Diameter 7.3±0.5mm
11.7 (4.3) (4.1) Cable Outer Diameter 7.8±0.5mm
12.4 (4.8) (4.6) Cable Outer Diameter 8.8±0.5mm
13.1 (4.9) (4.7) Cable Outer Diameter 9.0±0.5mm
13
(5.2)
(5) Cable Outer Diameter 9.6±0.5mm
9
BRecommended PCB Layout
●DH60-**P、DH60A-**P
A
B
C
Unit : mm
R0
.82
5)
TH
1.4(
5)
32
R0
Ho
2-
Ø1
1(
PCB End
2-0.65
(TH)
2(1.65)
(Land)
D
E
:Pattern Prohibited Area
●DH80-27P
6
Ø2.
(TH
nd
La
.2(
Ø3
27.8
24.2
13
No.2
No.1
Pad for
Terminal
0.43
No.13
No.14
2.6(Land)
2(TH)
le)
Ho
.1(
Ø1
Positioning
Hole
No.27
No.26
1
12
16.5
No.15
No.16
0.65(TH)
1.25(Land)
2.75
4.4
7.4
3.6
Pad for Shell
1
●DH80A-27P
27.8
Ø1
21.3
13
.8
TH
Ø2
.4
(L
an
d)
No.2
No.1
No.13
No.14
Pad for
Terminal
2.6(Land)
2(TH)
No.15
No.16
Positioning
Hole
1
No.27
No.26
12
16.5
0.65(TH)
1.25(Land)
.1
(H
ole
Ø1
2.75
4.4
7.4
3.6
Pad for Shell
1
0.43
BBoard Pattern Contact No.
●DH60-**P、DH60A-**P
D
No.1
No.(N+3)/2
No.2
No.(N+5)/2
No.(N+1)/2
No.N
No.(N-1)/2
No.(N-1)
*N:Number of positions
10
2.5
le
Positioning Hole
0.15
2-1
(Land)
3.1
1.2
2-Ø
2-2.55(TH)
2-(3.55)
(Land)
2.9
(R
1)
R1
2-1.5
(Land)
P=0.5
0.3
Pad for Terminal
Pad for Shell
2(2)
(Land)
Part No.
DH60-17P
DH60A-17P
DH60-27P
DH60A-27P
DH60-37P
DH60A-37P
DH60-51P
DH60A-51P
A
B
C
D
E
8
19
26
29.8 24.2 13
24
31
34.8 29.2 18
29
36
41.8 36.2 25
36
43
24.8 19.2
■Panel Cutout
●Screw Lock Type
Reference Panel Cutout (Right Angle Type, Straight Type)
(The dimensions are specified based on the center of the connector interface)
DH-LNA(CL244-0045-0-00)
A
5
Ø2
.5
2.5
B
PCB Mounting Surface
*Please set piercing R as less than R1.
C
2.9
5
2.5
D
2-R
1.1
A·B·C·D Dimension Table
Unit : mm
No. of Pos.
A
B
C
D
17
19.2
13.7
22
15
27
24.2
18.7
27
29.2
23.7
32
25
51
36.2
30.7
39
32
Connector Mounted on PCB
PCB
*Lock Screw
(DH-LNA)
30
24.2
Panel
PCB
Panel
Backside
PCB Mounting
Surface
*Panel t=1.6
*Panel t=1.6
4.9
8
Panel
Backside
*DH80-27P
PCB t=1.6
(For example, panel thickness is 1.6mm)
*The drawing features DH60-27P as the example.
30.8
24.2
2.5
PCB Mounting
Surface
Panel
4.6
4.8
PCB t=1.6
DH-LNA-W4(CL244-0046-2-00)
DH-LNA-W8(CL244-0004-2-00)
DH-LNA-W16(CL244-0005-5-00)
Reference Cutout Panel
*Select a lock screw from the below table based on panel thickness.
Part No.
DH-LNA
DH-LNA-W4
DH-LNA-W8
DH-LNA-W16
HRS No.
244-0045-0 00
244-0046-2 00
244-0004-2 00
244-0005-5 00
1.4 to 1.6
0.9 to 1.2
0.5 to 0.8
No panel
*The recommended screw tightening torque is from 0.12 to 0.3 N·m.
11
●One Touch Lock Type
A
2.5
5
2.4
B
.1
R1
2-
*Please set the draft R for process as max R1.
A·B Dimension Table
Unit : mm
No. of Pos.
A
B
17
23.5
18
27
28.5
23
37
33.5
28
51
40.5
35
Connector mounted on PCB
*The drawing features DH60A-27P as the example.
t=1.6 Max.
*1 Screw for Installation
30.8
26.2
Panel
*2 Screw for
Installation
Ø3.5
30.8
26.2
Panel
4.6
4.8
2.5
PCB t=1.6
Panel
Backside
PCB Mounting
Surface
PCB Mounting
Surface
*1 Installation with the panel must use a dedicated screw.
Purchase : qHRS Part No.[DH60A-SCREW]
HRS No.[CL244-0042-1]
wNITTOSEIKO Co., Ltd.
[FINE PAN HEAD MACHINE SCREW 2 TYPES]
*2 Installation with the panel must use a dedicated screw.
Purchase : qHRS Part No.[DH80A-SCREW]
HRS No.[CL244-0059-4]
*Screw for Installation
Ø3.5
0.6
0.6
Ø3.5
M2∞0.4∞10
12
PCB
t=1.6 Max.
0.6
5.1
8.4
8
4.9
Panel Backside
PCB t=1.6
PCB
*DH80A-27P
M2∞0.4∞5
■Applicable Tools
Process
Cable End Processing
2
3
4
5
6
Upper Level Wire Arranging
Upper Level Press Fitting
Lower Level Wire Arranging
Lower Level Press Fitting
Cable Cutting
7
Part No.
1
8
9
IDC
Cable Clamping
Cover Attaching
HRS No.
Manual Work
Tool for Wire Arrangement : DH/CA-MO
902-2183-0
Manual Work (Using nippers, etc.)
① IDC/Clamping Tool : DH/IDCK-MP
② Attachment for 17pos : DH-17UNIT
Attachment for 27pos : DH-27UNIT
Attachment for 37pos : DH-37UNIT
Attachment for 51pos : DH-51UNIT
③ HI-FLEX Termination Press
(Select appropriate attachment of each pin count from ②.)
② Attachment for DH-17-CMB(5.6) : DH-17-CMB(5.6)UNIT
Attachment for DH-17-CMB(6.3) : DH-17-CMB(6.3)UNIT
Attachment for DH-17-CMB(6.6) : DH-17-CMB(6.6)UNIT
Attachment for DH-27-CMB(6.9) : DH-27-CMB(6.9)UNIT
attachment for DH-27-CMB(7.3) : DH-27-CMB(7.3)UNIT
Attachment for DH-37-CMB(7.8) : DH-37-CMB(7.8)UNIT
Attachment for DH-37-CMB(8.8) : DH-37-CMB(8.8)UNIT
Attachment for DH-51-CMB(9.0) : DH-51-CMB(9.0)UNIT
Attachment for DH-51-CMB(9.6) : DH-51-CMB(9.6)UNIT
Manual Work (Using torque drivers, etc.)
902-2185-5
902-2186-8
902-2187-0
902-2188-3
902-2189-6
550-0082-2
902-2185-5
902-2197-4
902-2190-5
902-2196-1
902-2194-6
902-2191-8
902-2198-7
902-2192-0
902-2199-0
902-2193-3
550-0082-2
*For 7. IDC and 8. Cable clamping, one of the tools listed in each ①, ②, and ③ are required (select one).
*Customers that already have the HI-Flex termination press may use it for product assembly.
*DH/IDCK-MP listed in 7. IDC and 8. Cable clamping is the same tool. If there is at least one, then both IDC and cable
clamping can be completed by switching out the IDC attachment with the caulking attachment. Accordingly, two of both DH/
IDCK-MP and the HIFLEX termination press are required for mass production.
2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN
https://www.hirose.com/
The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use.
The contents of this catalog are current as of date of 04/2021. Contents are subject to change without notice for the purpose of improvements.
13
