QR/P8-PC-211
QR/P8-PC-211
    HRS(广濑)
QR/P8-PC-211 数据手册
QR/P8 Series Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Ultra-compact, Rectangular, High Pin Count, Rack and Panel Crimp Connector Dec. 2021 ① QR/P8 Series/Ultra-compact, Rectangular, High Pin Count, Rack and Panel Crimp Connector Overview The QR/ P8 Series is a more compact version of the rectangular, multi- pin count and plug- in connection QR/ P, QR/ P1 and QR/ P4 Series for racks and panels, which have been well received in the market. Three different pin counts are available: 8, 12 and 20. Wire connection is performed using crimp termination for easier connection and higher reliability. Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Features 1. Smaller size with the same number of pin counts as the QR/ P4 Series ( 20% reduction) 2. The guide pin and housing are molded into one piece for space- saving. 3. Use of stepped screws enables a floating design. 4. UL, CSA, TÜ V certified. 2 QR/P8 Series/Ultra-compact, Rectangular, High Pin Count, Rack and Panel Crimp Connector Product Specifications Operating Temperature -10 to +60℃ Rated Current Rated Voltage 3A Max. (When using 20 AWG) Signal 2A Max. (When using 24 AWG) Power 300V AC Signal 30V AC Contact Resistance 30m Ω Max. at 1A DC Insulation Resistance 1000M Ω Min. at 500V DC Withstand Voltage Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Power Power 2000V AC for 1 min. Signal 500V AC for 1 min. Safety Standard UL, CSA Operating Temperature -10 to +60℃ 20 AWG 3A 22 AWG Rated Current 24 AWG Power 2A Signal 26 AWG 2.5A 1A 1A 28 AWG Rated Voltage TÜV Power 300V AC 380V AC Signal 30V AC 30V AC Materials / Finish Item Material Color / Finish Remarks Insulator Polycarbonate Black UL94V-0 Contact Phosphor Bronze Partial Gold Plating (Nickel Underplating) - 3 QR/P8 Series/Ultra-compact, Rectangular, High Pin Count, Rack and Panel Crimp Connector Product Number Structure Refer to the chart below when determining the product specifications from the product number. Please select from the product numbers listed in this catalog when placing orders. Connector Unit QR/P8 - 12 P - C (21) ❶ ❷ ❸ ❹ ❺ Contact QR/P8 - PC - 1 1 1 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ❶ ❻ ❼ ❽ ❾ ❶ Series Name QR/P8 ❻ Contact Gender PC : Male Crimp Contact SC : Female Crimp Contact ❷ No. of Pos. 8, 12, 20 ❼ Contact Type 1 : Loose Contact 2 : Reel Contact ❸ Insulator Gender P : Male Insulation Case S : Female Insulation Case ❽ Applicable Cable 1 : Thick Cable 20 to 24 AWG   ・・・2 contact holes on both sides 2 : Thin Cable 24 to 28 AWG ❹ Contact Connection Method C : Crimp Connection ❾ Surface Treatment 1 : Partial Gold Plating (Nickel Underplating) ❺ Specification (21) : UL, CSA, TÜV 4 QR/P8 Series/Ultra-compact, Rectangular, High Pin Count, Rack and Panel Crimp Connector Housing Male Housing A 4.3 B 1 3.2 2-φ 14 6 12 9 4 5.6 C 12 11 10 9 8 7 6 5 4 3 2 1 Unit : mm Part No. HRS No. No. of Pos. A B C QR/P8-8P-C(21) CL0221-0167-3-21 8 27.0 21.6 17.0 QR/P8-12P-C(21) CL0221-0169-9-21 12 31.0 25.6 21.0 QR/P8-20P-C(21) CL0221-0171-0-21 20 39.0 33.6 29.0 Purchase Unint 50pcs per bag Note : When attaching to the panel, make sure that the mated clearance dimensions on the male and females sides are 1.5mm or less. Female Housing A 6 12 1 7 13 5.1 M3×0.5 19 3.7 B 14 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 19 4 7 C 7 8 9 10 11 12 1 2 3 4 5 6 Unit : mm Part No. HRS No. No. of Pos. A B C QR/P8-8S-C(21) CL0221-0168-6-21 8 27.0 20.4 17.0 QR/P8-12S-C(21) CL0221-0170-8-21 12 31.0 24.4 21.0 QR/P8-20S-C(21) CL0221-0172-3-21 20 39.0 32.4 29.0 Note : When attaching to the panel, make sure that the mated clearance dimensions on the male and females sides are 1.5mm or less. 5 Purchase Unint 50pcs per bag QR/P8 Series/Ultra-compact, Rectangular, High Pin Count, Rack and Panel Crimp Connector Contact 1.2 Part No. HRS No. QR/P8-PC-111 CL0221-0182-7-00 QR/P8-PC-211 CL0221-0175-1-00 16.1 Applicable Cable 20 to 24 AWG Type of Packing Purchase Unit Loose 100pcs per bag Reel 8,000pcs per reel Note : The contacts for thick cables can be crimped when using an applicable cable size of 24 AWG, but the contacts for thin cables are recommended. 1.45 Female Contact for Thick Cable (2 Contact Holes on Both Sides) 1.7 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 1.45 Male Contact for Thick Cable (2 Contact Holes on Both Sides) 16.1 Part No. HRS No. QR/P8-SC-111(12) CL0221-0183-0-12 QR/P8-SC-211(12) CL0221-0173-6-12 Applicable Cable 20 to 24 AWG Type of Packing Purchase Unit Loose 100pcs per bag Reel 8,000pcs per reel Note : The contacts for thick cables can be crimped when using an applicable cable size of 24 AWG, but the contacts for thin cables are recommended. 6 QR/P8 Series/Ultra-compact, Rectangular, High Pin Count, Rack and Panel Crimp Connector Part No. HRS No. QR/P8-PC-121 CL0221-0184-2-00 QR/P8-PC-221 CL0221-0176-4-00 16.1 Applicable Cable 24 to 28 AWG Type of Packing Purchase Unit Loose 100pcs per bag Reel 8,000pcs per reel 1.45 Female Contact for Thin Cable 1.7 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 1.2 1.45 Male Contact for Thin Cable 16.1 Part No. HRS No. QR/P8-SC-121(12) CL0221-0185-5-12 QR/P8-SC-221(12) CL0221-0174-9-12 Applicable Cable 24 to 28 AWG 7 Type of Packing Purchase Unit Loose 100pcs per bag Reel 8,000pcs per reel QR/P8 Series/Ultra-compact, Rectangular, High Pin Count, Rack and Panel Crimp Connector Panel Mounting Dimensions Male Housing (QR/P8-#P-C) Attachment from Panel Rear Side A B 2-M3×0.5 R1 4- 4 R3 0.3 4.3 2- .7 5 C Attachment from Panel Front Side D 2-M3×0.5 E 11.5 6- R1 4.3 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 14.5 2-R F Unit : mm Type Rear Mount Front Mount 8pos. 12pos. 20pos. A 21.6 25.6 33.6 B 13.6 17.6 25.6 C 27.5 31.5 39.5 D 21.6 25.6 33.6 E 11.1 15.1 23.1 F 17.5 21.5 29.5 8 QR/P8 Series/Ultra-compact, Rectangular, High Pin Count, Rack and Panel Crimp Connector Female Housing (QR/P8-#S-C) Attachment from Panel Rear Side A B 2-M3×0.5 1 4-R 4 2- R4 0.3 3.7 15.2 2-R .1 Attachment from Panel Front Side D E 3.7 2-M3×0.5 15.2 6- R1 1.1 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. C F Unit : mm Type Rear Mount Front Mount 8pos. 12pos. 20pos. A 20.4 24.4 32.4 B 12.4 16.4 24.4 C 28.2 32.2 40.2 D 20.4 24.4 32.4 E 11.6 15.6 23.6 F 18.2 22.2 30.2 9 QR/P8 Series/Ultra-compact, Rectangular, High Pin Count, Rack and Panel Crimp Connector Contact Arrangement Male Housing (View from the Connection Side) ■ : Contact hole for thick cables ( Can insert contacts for thin cables) □ : Contact hole for thin cables QR/P8-8P-C(21) 1 234 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 5 QR/P8-12P-C(21) 8 1 23456 7 QR/P8-20P-C(21) 67 8 91011 12 1 2 3 4 5 6 7 8 9 10 11 12 13141516171819 20 10 QR/P8 Series/Ultra-compact, Rectangular, High Pin Count, Rack and Panel Crimp Connector Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Tools Manual Crimp Tool Type Automatic Crimp Tool CM-105C Part No. HRS No. TC-QR/P8-111 CL0250-0030-4-00 QR/P8-PC-111 QR/P8-SC-111 TC-QR/P8-121 CL0250-0031-7-00 QR/P8-PC-121 QR/P8-SC-121 AP105-QR/P8-1 CL0901-2533-3-00 QR/P8-PC-211 QR/P8-SC-211 AP105-QR/P8-2 CL0901-2534-6-00 QR/P8-PC-221 QR/P8-SC-221 TC-QR/P8-21 CL0250-0033-2-00 - Manual Crimp Tool Automatic Crimp Tool Applicator Extraction Tool Applicable Contact While Taking into Consideration Specifications mentioned in this catalog are reference values. When considering to order or use this product, please confirm the Drawing and Product Specifications sheets. Use an appropriate cable when using the connector in combination with cables. If considering usage of a non- specified cable, please contact your sales representative. If assembly process is done by jigs & tools which are not identified by Hirose, assurance will not be given. If considering usage for below mentioned applications, please contact your sales representative. In cases where the application will demand a high level of reliability, such as automotive, medical instruments, public infrastructure, aerospace/ defense etc. Hirose must review before assurance of reliability can be given. 2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN        https://www.hirose.com ※ The contents of this catalog are current as of date of 12/ 2021. Contents are subject to change without notice for the purpose of improvements. 11
QR/P8-PC-211 价格&库存
很抱歉,暂时无法提供与“QR/P8-PC-211”相匹配的价格&库存,您可以联系我们找货
