QR/P6-16P-C(01)
QR/P6-16P-C(01)
    HRS(广濑)
QR/P6-16P-C(01) 数据手册
The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. All non-RoHS products have been discontinued, or will be discontinued soon. Please check the products status on the Hirose website RoHS search at www.hirose-connectors.com, or contact your Hirose sales representative. QR/P6 SERIES QR/P6 SERIES RECTANGULAR MINIATURE MULTI-CONTACT RACK/PANEL CRIMP CONNECTOR General Nov.1.2022 Feb.1.2021 Copyright 2021 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. The QR/P6 Series are miniaturized versions of the QR/P and QR/P1 series. Rectangular multi-contact rack and panel connectors for plug-in connection. Available in 6, 12, 16, and 24 contacts for highly efficient and reliable crimp termination. Features (1) Offers smooth insertion/extraction and stable contact pressure through point-blade contact, and has ample allowance for the deviations in contact length specific to plug-in connection. (2) Miniaturized by separating power contacts from signal contacts. (3) Signal contacts in the housing are located in pitches of 2.54mm. The opposed contacts at one end of the connector are spaced 6.9mm so that they can withstand high voltage. Can be used for power supplies. Uses flame-retardant insulator (UL94-0). (4) Miniaturized using guide pins integral with the insulator. (5) Ensures smooth insertion and extraction, and designed to be fixed with stepped screws on a panel or rack. (6) The female housing is designed to allow the contact part of the female terminal to be below the mating surface, meeting the Finger Test Requirements (complying with UL 1950) (7) The connectors of the series have passed UL, CSA and TÜV standard. Application PPC, Transmission/Reception equipment, Data Communication, equipment, Vending machines, Measuring Instruments, Automation equipment, Switch-boards. 157 1 03/2021 04/2009 The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. All non-RoHS products have been discontinued, or will be discontinued soon. Please check the products status on the Hirose website RoHS search at www.hirose-connectors.com, or contact your Hirose sales representative. Main Specification General ratings of QR/P6 Contact Resistance Insulation Resistance Withstand Voltage (for 1 min.) Rated current Rated voltage Main materials Power terminal 10mΩ or less at DC1A Signal terminal 15.mΩ or less at DC1A Insulator PBT resin Black Terminal Phosphor bronze Selective Gold plating with nickel underplating 5000MΩ or less at DC 500V Power unit AC 1000V Signal unit AC 500V Power terminal 10A Signal terminal 1A *UL94V-0 QR/P6 ratings approved by safety standards UL Safety standard Operating temperature range Rated voltage AC 120V Power supply unit AWG#14 10A AWG#16 Nov.1.2022 Feb.1.2021 Copyright 2021 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. TÜV AC250V AC 250V Signal unit AWG#18 5A AWG#20 AWG#22 Rated current CSA −10∼+60℃ AWG Power supply #24 Signal unit AWG#26 AWG#28 AC125V 10A 8A 10A 5A 5A 3A 3A 3A 3A 1A 2A 1A 1A 2.5A 1A 1A 1A ―― Ordering Information ▲ Connector Unit 21 QR / P6 − 12 P − C − (01) (1) ▲ Contact (4) (11) QR / P1 − PC 1 A − 1 1 1 (1) (1) Series name (2) No.of contacts (6, 12, 16, 24) (3) Shape of insulator mating part P: Insulator male case S: Insulator female case (4) Type of termination C: Crimp termination (5) Male/ Female PC: Male crimp terminal SC: Female crimp terminal (6) Type 1: Power terminal 2: Signal terminal 2 158 (2) (3) (5) (6)(7) (8)(9)(10) (7) Crimp barrel size A: For thin wires B: For thick wires (8) Shape 1: Loose contact 2: Chain contact (9) Applicable wire 1: Power terminal AWG # 18 - # 24 Signal terminal AWG # 24 - # 28 2: Power terminal AWG # 14 - # 16 (10) Surface terminal 1: Selective gold plating with nickel underplating (11) Specifications meeting UL, CSA TÜV requirements 03/2021 04/2009 The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. All non-RoHS products have been discontinued, or will be discontinued soon. Please check the products status on the Hirose website RoHS search at www.hirose-connectors.com, or contact your Hirose sales representative. Housing Nov.1.2022 Feb.1.2021 Copyright 2021 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Male Housing Famale housing Unit: mm HRS No. No. of Pin Part No. A B C CL0221-0162-0-21 CL221-0162-0-01 6 QR/P6-06P-C(01) 21 24.67 32.67 15.87 CL0221-0163-2-21 CL221-0163-2-01 12 21 QR/P6-12P-C(01) 33.47 41.47 24.67 CL0221-0207-6-21 CL221-0207-6-01 16 21 QR/P6-16P-C(01) 38.55 46.55 29.75 CL0221-0209-1-21 CL221-0209-1-01 24 21 QR/P6-24P-C(01) 48.71 56.71 39.91 Unit: mm RoHS ○ HRS No. No. of Pin Part No. A B C CL0221-0161-7-21 CL221-0161-7-01 6 QR/P6-06S-C(01) 21 24.67 32.67 15.87 CL0221-0164-5-21 CL221-0164-5-01 12 21 QR/P6-12S-C(01) 33.47 41.47 24.67 CL221-0208-9-01 CL0221-0208-9-21 16 21 QR/P6-16S-C(01) 38.55 46.55 29.75 CL0221-0210-0-21 CL221-0210-0-01 24 21 QR/P6-24S-C(01) 48.71 56.71 39.91 RoHS ○ Note: Determine the combinations with the panel so that the mating clearance between the P side and S side is 1.5mm. Contact Male power terminal Female power terminal Selective gold plated with nickel underplating Applicable Wire HRS No. Part No. Selective gold plated with nickel underplating Type Packing RoHS Loose CL221-0114-7-12 100pin CL0221-0114-7-12 QR/P1-PC1B-121(12) contact UL1015 AWG#14∼16 CL221-0118-8-12 Chain 3,000pin QR/P1-PC1B-221 ( 12) CL0221-0118-8-12 contact Loose CL221-0102-8-12 100pin CL0221-0102-8-12 QR/P1-PC1A-111(12) contact UL1007 Chain AWG#18∼24 CL221-0106-9-12 CL0221-0106-9-12 QR/P1-PC1A-211(12) contact 5,000pin ○ Applicable Wire HRS No. Part No. Type Packing RoHS Loose CL221-0116-2-12 100pin CL0221-0116-2-12 QR/P1-SC1B-121(12) contact UL1015 AWG#14∼16 CL221-0120-0-12 Chain 3,000pin CL0221-0120-0-12 QR/P1-SC1B-221(12) contact Loose CL221-0104-3-12 100pin CL0221-0104-3-12 QR/P1-SC1A-111(12) contact UL1007 Chain AWG#18∼24 CL221-0108-4-12 CL0221-0108-4-12 QR/P1-SC1A-211(12) contact 5,000pin ○ 159 3 03/2021 04/2009 The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. All non-RoHS products have been discontinued, or will be discontinued soon. Please check the products status on the Hirose website RoHS search at www.hirose-connectors.com, or contact your Hirose sales representative. Contact Male signal terminal Female signal terminal Nov.1.2022 Feb.1.2021 Copyright 2021 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Selective gold plated with nickel underplating Applicable Wire HRS No. Part No. Selective gold plated with nickel underplating Type Packing RoHS CL0221-0103-0-12 QR/P1-PC2A-111(12) Loose CL221-0103-0-12 100pin UL1007 AWG#24∼28 CL221-0107-1-12 CL0221-0107-1-12 QR/P1-PC2A-211(12) Chain 5,000pin ○ Applicable Wire HRS No. Type Packing RoHS Part No. CL221-0105-6-12 100pin CL0221-0105-6-12 QR/P1-SC2A-111(12) Loose UL1007 AWG#24∼28 CL221-0109-7-12 CL0221-0109-7-12 QR/P1-SC2A-211(12) Chain 5,000pin ○ Panel Mounting Dimensions (for Cases with P Insulation) Unit: mm No. of pin Mounting on panel inside 8 Pin 12 Pin 16 Pin 24 Pin A 14.87 19.27 21.85 26.95 B 17.17 25.97 31.18 41.34 C 18.17 26.97 32.05 42.21 D 24.67 33.47 38.55 48.71 E 16.37 25.17 30.25 40.41 19.87 28.67 33.75 43.91 24.67 33.47 38.55 48.71 Mounting on F panel outside G Mounting on panel outside Applicable Tools Type HRS No. Part No. Applicator terminay CL0250-0020-0-00 CL250-0020-0 TC-QR/P1-PC1B TC-QR/P1-PC1A QR/P1-PC1B-121 QR/P1-PC1A-111 TC-QR/P1-SC1B TC-QR/P1-SC1A TC-QR/P1-PC2A QR/P1-SC1B-121 QR/P1-SC1A-111 QR/P1-PC2A-111 CL0250-0018-9-00 CL250-0018-9 TC-QR/P1-SC2A CL0901-2529-6-00 CL901-2529-6 AP105-QR/P1-1B-2 QR/P1-SC2A-111 QR/P1-PC1B-221 CL0901-2527-0-00 CL901-2527-0 AP105-QR/P1-1A-1 CL0901-2528-3-00 CL901-2528-3 AP105-QR/P1-2A-1 CL0250-0242-2-00 CL250-0242-2 TC-QR/P6-21 CL0250-0015-0-00 CL250-0015-0 Hand Crimp CL0250-0022-6-00 CL250-0022-6 Tool CL0250-0017-6-00 CL250-0017-6 CL0250-0016-3-00 CL250-0016-3 Auto Crimp Machine Applicator Hand crimping tool 4 160 Automatic crimping machine CM-105  CL901-0005-4 Hand Tool QR/P1-SC1B-221 QR/P1-PC1A-211 QR/P1-SC1A-211 QR/P1-PC2A-211 QR/P1-SC2A-211 03/2021 04/2009 The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. All non-RoHS products have been discontinued, or will be discontinued soon. Please check the products status on the Hirose website RoHS search at www.hirose-connectors.com, or contact your Hirose sales representative. Contacts for thick wire Contact Configuration Male Housing (Viewed from Wiring Side) 1 2 3 ■: indicates a contact hole for thick wire QR/P6-6P-C (01) QR/P6-6P-C(21) Nov.1.2022 Feb.1.2021 Copyright 2021 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 4 5 6 QR/P6-12P-C (01) 1 2 3 4 5 6 QR/P6-16P-C (01) QR/P6-12P-C(21) 7 8 9 10 11 12 QR/P6-24P-C (01) 1 2 3 4 5 6 7 8 QR/P1-32P-C (01) QR/P6-16P-C(21) 9 1 10 1112 13 14 15 16 2 3 4 5 6 7 8 9 10 11 12 QR/P6-24P-C(21) 13 14 15 16 17 18 19 20 21 22 23 24 161 5 03/2021 04/2009
QR/P6-16P-C(01) 价格&库存
很抱歉,暂时无法提供与“QR/P6-16P-C(01)”相匹配的价格&库存,您可以联系我们找货
