DF19-2830SCFA(41)
DF19-2830SCFA(41)
    HRS(广濑)
DF19-2830SCFA(41) 数据手册
DF19 Series Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 1.0mm Pitch, Low Profile Wire-to-Board, FPC-to-Board, Micro-coaxial Cable-to-Board Connectors Jan. 2022 DF19 Series/1.0mm Pitch, Low Profile Wire-to-Board, FPC-to-Board, Micro-coaxial Cable-to-Board Connectors Features 1. De Facto Standard for LCD Panel Connection DF19 has been accepted as the market standard for LCD panels ( 12in. or less) due to its high performance for LVD high speed differential signals. Cable Connection Cable, micro- coaxial type : 1. 5mm thickness ( 1. 6mm Max. ) FPC Type : 1. 7mm Max. 8.2 7.2 DF19G-#P-1H(52) 1.5 1.65 Cable DF19G-#S-1C(05) DF19A-2830 / 3032 / 36SCFA PCB FPC Connection 8.2 7.2 DF19G-#P-1H(52) 1.65 (1.7) FPC DF19G-#S-1F(05) DF19G-#S-1F-GND(06) 3. Common Header Cable Type Header is compatible with the 3 socket types ( discrete wire, FPC and micro- coaxial types) , for a wide selection of mating combinations. (1.7) DF19G-#S-1F(05) +DF19G-#S-1F-GND(06) (7.7) (7.7) DF19G-#S-1C(06) DF19-#P-1V(52) (0.78) Cable, Micro-coaxial Type 1.3±0.2 DF19G-#S-1SD(06) +DF19G-#S-1SD-GND DF19-#P-1V(52) 4. Uniform External Dimensions External dimensions of each socket type are the same and can be used in a wide array of applications. 2 PCB FPC Type 1.5±0.1 (7.7) Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 2. Low Profile Design DF19-#P-1V(52) DF19 Series/1.0mm Pitch, Low Profile Wire-to-Board, FPC-to-Board, Micro-coaxial Cable-to-Board Connectors 5. Wide Varieties Top-board Mounted Header is available in top- board, offset, reverse mount offset and vertical mounted styles to meet a wide array of application needs. Discrete Wire Offset Mounted Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. FPC Reverse Offset Mounted Micro-coaxial Cable Vertical Mounted 6. Ground Connection with Outer Shell Metal shell enables ground connection. 7. Glow Wire Compatible ( IEC60695- 2- 11 Standard) Applications Mobile phones, LCD connections, DVC, DSC, PDA, camera modules, and other small equipment Micro-coaxial Cable DF19 FPC Twisted pair cable Notebook PC DF19 DF19 DF19 3 DF19 Series/1.0mm Pitch, Low Profile Wire-to-Board, FPC-to-Board, Micro-coaxial Cable-to-Board Connectors Product Specifications Rated Current 28 AWG 30 AWG 32 AWG 36 AWG FPC Micro-coaxial Cable 40 AWG 1A/pin 0.9A/pin 0.8A/pin 0.5A/pin 0.5A/pin 0.3A/pin Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Rated Voltage Note Note Note Note 1 2 3 4 : : : : Operating Temperature (Note 1) -35 to +85℃ Operating Humidity Range (Note 2) 40 to 80% Storage Temperature Range (Note 3) 100V AC/DC -10 to +60℃ Storage Humidity Range (Note 3) 40 to 70% Includes temperature rise due to current flow. Please use without condensation. Applicable to unused items in packaged state. Information contained in this catalog represents general requirements for this Series. Contact us for the drawings and specifications for a specific part number shown. Item Specification Conditions Insulation Resistance 500M Ω Min. 100V DC Withstanding Voltage No flashover or insulation breakdown. 300V AC for 1 min. Contact Resistance 30m Ω Max. (50m Ω Max. for FPC) 1mA Vibration No electrical discontinuity of 1μ s or more. Frequency : 10 to 55 Hz, single amplitude of 0.75mm, in 3 direction for 10 cycles Humidity (Steady State) Contact Resistance : 30m Ω Max. (50m Ω Max. for FPC) Insulation Resistance : 500M Ω Min. 96 hours at temperature of 40 ± 2℃ and humidity of 90 to 95% Temperature Cycle Contact Resistance : 30m Ω Max. (50m Ω Max. for FPC) Insulation Resistance : 500M Ω Min. Temperature : -55℃ → +5 to +35℃ → +85℃ → +5 to +35℃ Time (Minutes) : 30 → 10 → 30 → 10 for 5 cycles Mating Durability Contact Resistance : 30m Ω Max. (50m Ω Max. for FPC) 30 cycles Soldering Heat Resistance No deformation of the insulator parts affecting performance. Re-flow soldering : At the recommended temperature profile Manual soldering : Soldering iron temperature 350℃ , 5 seconds Materials / Finish Product Pin Header Crimp Case Socket Crimp Contact FPC Socket FPC Grounding Plate Micro-coaxial Socket Grounding Plate for Micro-Coaxial Component Material Finish / Color Remarks Insulator Polyamide Black or Beige Contacts Phosphor Bronze Partially Gold Plated - Exterior Shell Phosphor Bronze Partially Tin Plated - Insulator Polyamide Beige Exterior Shell Stainless Steel Tin Plated - Contact Phosphor Bronze Gold Plated - Insulator Polyamide Beige Contact Phosphor Bronze Gold Plated - Exterior Shell Stainless Steel Tin Plated - Insulator LCP Beige Contact Phosphor Bronze Partially Gold Plated - Exterior Shell Phosphor Bronze Tin Plated - Exterior Shell Phosphor Bronze Tin Plated - 4 RoHS2 UL94V-0 UL94V-0 UL94V-0 UL94V-0 〇 DF19 Series/1.0mm Pitch, Low Profile Wire-to-Board, FPC-to-Board, Micro-coaxial Cable-to-Board Connectors Product Number Structure Refer to the chart below when determining the product specifications from the product number. Please select from the product numbers listed in this catalog when placing orders. ■ Connector DF19 # - # P - 1 H(52) ❶ ❷ ❸ ❹ ❺ ❻ ❽ DF19 # - # S - 1 F - GND Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ❶ ❶ ❷ ❷ ❸ ❹ ❺ ❻ ❼ Series Name DF19 ❸ No. of Pos. 8, 14, 20, 30 (Note 1) ❹ Connector Type S : Single Row Socket P : Single Row Pin Header ❺ Contact Pitch 1.0mm ❻ Mounting Type/ Termination Type Configuration Pin Header G : Top-board Mouted (1.65mm Height) K : Offset Mounted (1.0mm Height) L : Offset Mounted (1.1mm Height) KR : Reverse Offset Mounted Version of DF19K (1.0mm Height) Crimp Socket Blank : No Exterior Shell G : With Exterior Shell (EMI Prevention Specification) FPC Socket G : With Grounding Plate Grounding Plate for FPC G : With Grounding Plate Micro-coaxial Socket G : With Grounding Plate Grounding Plate for Micro-coaxial Cable G : With Grounding Plate H:Right Angle SMT V:Straight SMT C:Crimp Case F : FPC, Socket SD:Micro-coaxial Socket ❼ Attachable Parts GND : Ground plate (Note 2) ❽ Specification (52) : Gold plated, tape & reel packaging Note 1 : The pin count availabilities vary based on connection style. Note 2 : Grounding plates are required when terminating with the FPC and Micro-coaxial cable. ■ Crimp Contact DF19A - 2830 SCF A (##) ❶ ❷ ❸ ❹ ❶ Conductor Size 2830 : 28-30 AWG 3032 : 30-32 AWG 36 : 36 AWG ❸ Plating A : Gold Plated ❷ Contact Type/ Packaging SCF : Socket Contact, Reel ❹ Packaging Blank : 10,000pcs per reel (41) : 20,000pcs per reel 5 DF19 Series/1.0mm Pitch, Low Profile Wire-to-Board, FPC-to-Board, Micro-coaxial Cable-to-Board Connectors Right Angle Pin Header (SMT) (Top-Board Mounted Type) A 2.375 B P= 1 2.175 4.7 2.45 0.25 2 Contact No. 1 Indicator C 1.65 1.65 Pictured mounted on board. Recommended PCB Mounting Pattern B±0.05 1.85±0.1 1+0.1 0 P=1±0.05 1.65±0.1 0.55±0.05 +0.1 0 2.5±0.05 1.1+0.1 0 2.5 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 5.7 Note : If there is a pattern on the the ground plate. portion and resist is not applied, it may come into contact with Unit : mm Part No. HRS No. No. of Pos. A B C DF19G-8P-1H(52) CL0685-0021-0-52 8 11.55 7.0 11.95 DF19G-14P-1H(52) CL0685-0004-0-52 14 17.55 13.0 17.95 DF19G-20P-1H(52) CL0685-0006-6-52 20 23.55 19.0 23.95 DF19G-30P-1H(52) CL0685-0015-7-52 30 33.55 29.0 33.95 Note : When using in combination with the single row socket (FPC Type), mount on the edge of the PCB. 6 Remarks Purchase Unit 1.65mm Height Above Board 1,000pcs per reel DF19 Series/1.0mm Pitch, Low Profile Wire-to-Board, FPC-to-Board, Micro-coaxial Cable-to-Board Connectors Right Angle Pin Header (SMT) (Offset Mounted Type) A 2.375 B 2.175 0.25 4.7 2.45 P=1 C F 6.7 Recommended PCB Mounting Pattern B±0.05 3.175±0.1 2.975±0.1 P=1±0.05 1+0.1 0 0.3 (2.2) 2.5 +0.1 0 5.3±0.1 0.3 1.5 +0.1 0 0.55±0.05 5.5±0.1 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Pictured mounted on board. Contact No. 1 Indicator 1 F 1.46 2 DF19K Identification Mark D+0.2 -0.1 E ±0.1 Unit : mm Part No. HRS No. No. of Pos. DF19K-20P-1H(52) CL0685-0008-1-52 20 23.55 19.0 26.55 24.15 25.15 1.0 DF19K-30P-1H(52) CL0685-0032-6-52 30 33.55 29.0 36.55 34.15 35.15 1.0 DF19L-14P-1H(52) CL0685-0003-8-52 14 17.55 13.0 20.55 18.15 19.15 1.1 A B C D E F Remarks 1.0mm Height Above Board DF19L-20P-1H(52) CL0685-0019-8-52 20 23.55 19.0 26.55 24.15 25.15 1.1 DF19L-30P-1H(52) CL0685-0016-0-52 30 33.55 29.0 36.55 34.15 35.15 1.1 7 Purchase Unit 1,000pcs per reel 1.1mm Height Above Board DF19 Series/1.0mm Pitch, Low Profile Wire-to-Board, FPC-to-Board, Micro-coaxial Cable-to-Board Connectors Right Angle Pin Header (SMT) (Reverse Offset Mounted Type) A 2.375 B 2.175 0.25 2 4.7 2.45 P=1 6.7 1 Contact No. 1 Indicator C 1 1.46 1 Recommended PCB Mounting Pattern 3.175±0.1 2.975±0.1 B±0.05 P=1±0.05 1+0.1 0 0.55±0.05 D (2.2) 0.3 5.3±0.1 2.5 +0.1 0 0.3 1.5 +0.1 0 5.5±0.1 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Pictured mounted on board. +0.2 -0.1 E±0.1 Unit : mm Part No. HRS No. No. of Pos. DF19KR-20P-1H(52) CL0685-0023-5-52 20 A B C D E Remarks Purchase Unit 23.55 19.0 26.55 24.15 25.15 1.0mm Height Above Board 1,000pcs per reel 8 DF19 Series/1.0mm Pitch, Low Profile Wire-to-Board, FPC-to-Board, Micro-coaxial Cable-to-Board Connectors 1.12 1.07 Straight Pin Header (SMT) P=1 0.95 0.25 B 1.3 1.56 5.22 A 1.96 Contact No. 1 Indicator Pictured mounted on board. C 1 3.8 0.25 Recommended PCB Mounting Pattern +0.1 +0.1 0.65 2.5 0 2.2±0.05 0.65±0.05 P=1±0.05 注1 0.55±0.05 (E) (F) 1.7+0.1 0 +0.1 +0 1.45 注1 +0.1 0 D±0.05 1.5+0 1.46±0.05 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. A 2 G±0.05 0.8±0.05 Note : If there is a pattern on the the ground plate. portion and resist is not applied, it may come into contact with Unit : mm Part No. HRS No. No. of Pos. A B C D E F G Purchase Unit 1,000pcs per reel DF19-14P-1V(52) CL0685-0036-7-52 14 17.9 13.0 15.25 14.95 6.675 6.325 13.0 DF19-20P-1V(52) CL0685-0037-0-52 20 23.9 19.0 21.25 20.95 9.675 9.325 19.0 9 DF19 Series/1.0mm Pitch, Low Profile Wire-to-Board, FPC-to-Board, Micro-coaxial Cable-to-Board Connectors Single Row Socket (Cable Type) DF19G-#S-1C(06) DF19-#S-1C A A B P=1 Mark Every 5 Contacts Contact No. 1 Indicator 1.5 1.5 Mark Every 5 Contacts Contact No. 1 Indicator A A Shown with terminated and installed contacts B 6.1 6.1 P=1 14 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Contact No. 1 Indicator Unit : mm Part No. HRS No. No. of Pos. A B Purchase Unit DF19-8S-1C CL0685-0029-1-00 8 11.5 7.0 DF19-14S-1C CL0685-0012-9-00 14 17.5 13.0 DF19-20S-1C CL0685-0011-6-00 20 23.5 19.0 DF19-30S-1C CL0685-0013-1-00 30 33.5 29.0 With Exterior Shell (EMI Prevention Specification) Part No. HRS No. Unit : mm No. of Pos. A B DF19G-8S-1C(06) CL0685-0022-2-06 8 11.5 7.0 DF19G-14S-1C(06) CL0685-0005-3-06 14 17.5 13.0 DF19G-20S-1C(06) CL0685-0007-9-06 20 23.5 19.0 DF19G-30S-1C(06) CL0685-0014-4-06 30 33.5 29.0 10 100pcs per bag Purchase Unit 100pcs per bag DF19 Series/1.0mm Pitch, Low Profile Wire-to-Board, FPC-to-Board, Micro-coaxial Cable-to-Board Connectors Socket Crimp Contacts 0.63 0.9 0.5 2 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 5.1 0.7 t=0.15 Part No. HRS No. DF19A-2830SCFA(##) CL0685-0048-6-## DF19A-3032SCFA(##) CL0685-0046-0-## DF19A-36SCFA(##) CL0685-0047-3-## Purchase Unit (##) : Blank Purchase Unit (##) : (41) 10,000pcs per reel 20,000pcs per reel Applicable Wire (Tin Plated Annealing Copper Wire) Part No. UL DF19A-2830SCFA(##) DF19A-3032SCFA(##) 1571 (Thin Type) DF19A-36SCFA(##) Wire Size Stranded Wire Structure Sectional Area 28 AWG 30 AWG 7/0.127mm 7/0.1mm 0.089mm2 0.055mm2 30 AWG 32 AWG 7/0.1mm 7/0.08mm 0.055mm2 0.035mm2 36 AWG 7/0.05mm 0.014mm2 Jacket Diameter φ 0.5-0.6mm Strip Length 1.2-1.9mm φ 0.27mm Note 1 : Please contact a Hirose sales representative when using cables other than those specified. Note 2 : Contact your Hirose sales representative when using 36 AWG. Applicable Tools Type Part No. HRS No. Applicator AP105-DF19S CL0901-4571-3-00 Press Unit CM-105C CL0901-0001-0-00 Note Note Note Note 1 2 3 4 : : : : Applicable Contact DF19A-2830SCFA(##) DF19A-3032SCFA(##) - Please conduct crimping work according to the "Crimping Quality Standard" (ETAD-H0945-00)" and "Crimping Condition Table". Issues with non-Hirose specified tools are outside the scope of warranty. Contact your Hirose sales representative when using 36 AWG. When non-authorized tools are used, please consult with Hirose sales representative about provision of the drawing of the crimping tool. 11 DF19 Series/1.0mm Pitch, Low Profile Wire-to-Board, FPC-to-Board, Micro-coaxial Cable-to-Board Connectors Single Row Socket (FPC Type) Note : Socket and grounding plate is required A B C 5.95 P=1 A 1.2 Contact Mark Indicator Shown terminated with FPC. D±0.08 0.45±0.3 0.2±0.1 2.2±0.05 0.2±0.15 0.7±0.03 t=0.145±0.03 グランド面<  :はんだめっ き1~5μm> Ground Area : Solder Plating 1 to 5μm thickness. .2 .05 ±0 0.05 0.05 0.3±0.15 R0.1 0.35±0.03 E±0.05 R0 0.4±0.05 ( 0.35) XR MA MAXR0 .2 0.2 3.6 2 ±0.15 P=1±0.03 1.85±0.25 C±0.05 .2 0.35±0.25 0.3±0.15 R0 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. CAV No. Signal信号面<  :はんだめっ Area : Solderき Plating 1 to 5μm thickness. 1~5μm> Unit : mm Part No. HRS No. No. of Pos. A B C D E DF19G-14S-1F(05) CL0685-0017-2-05 14 17.5 17.1 13.0 15.6 14.0 DF19G-20S-1F(05) CL0685-0009-4-05 20 23.5 23.1 19.0 21.6 20.0 DF19G-30S-1F(05) CL0685-0033-9-05 30 33.5 33.1 29.0 31.6 30.0 Note : When using in combination with the right angle pin header (Top Board Type), mount on the edge of the PCB. 12 Purchase Unit 100pcs per bag DF19 Series/1.0mm Pitch, Low Profile Wire-to-Board, FPC-to-Board, Micro-coaxial Cable-to-Board Connectors Ground Plate for FPC A B Contact No. 1 Indicator 4.1 No. of Pos. Indicator SIGNAL 1 4 1.5 C Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. D Unit : mm Part No. HRS No. No. of Pos. A B C D DF19G-14S-1F-GND(06) CL0685-0018-5-06 14 15.75 14.35 17.5 14.4 DF19G-20S-1F-GND(06) CL0685-0010-3-06 20 21.75 20.35 23.5 20.4 DF19G-30S-1F-GND(06) CL0685-0034-1-06 30 31.75 30.35 33.5 30.4 Purchase Unit 100pcs per bag Applicable Assembly Tools Type Part No. HRS No. Desktop tool (for 14pos.) DF19G-14S/PR-MD2 CL0902-4514-6-00 Desktop tool (for 20pos.) DF19G-20S/PR-MD2 CL0902-4513-3-00 Desktop tool (for 30pos.) DF19G-30S/PR-MD2 CL0902-4518-7-00 Note : Issues caused by tools other than those specified for Hirose are outside the scope of warranty. 13 DF19 Series/1.0mm Pitch, Low Profile Wire-to-Board, FPC-to-Board, Micro-coaxial Cable-to-Board Connectors 6.1 Contact 端子NO.1マ-ク No. 1 Indicator 1.33 C±0.2 D±0.15 P=1±0.1 Inner conductor 内部導体 Insulator 誘電体 Grounding bar 金属バ- スズコ- ト1.2MIN Solder Coat 1.2 Min. P=1 A B 3±0.1 0.7±0.05 0.9MAX Single Row Socket (Micro-coaxial) 0 0.55 -0.05 外部導体 Outer Conductor ジ ャケット Jacket Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Shown terminated with micro-coaxial cable. Note 1 : The pitch misalignment prevention tape can be connected without cutting, but please use a durable material. Note 2 : The inner conductor must be soldered in advance. Note 3 : When using a two position coaxial line, there are some pin arrangements that cannot be used due connector protrusion. Please check the official specifications. Unit : mm Part No. HRS No. No. of Pos. A B C D Purchase Unit DF19G-14S-1SD(06) CL0685-0026-3-06 14 17.4 13.0 14.8 13.0 DF19G-20S-1SD(06) CL0685-0025-0-06 20 23.4 19.0 20.8 19.0 100pcs per bag Applicable Cable (Micro-coaxial Cable) Wire Size (Core Wire Configuration) Jacket Diameter 40 AWG (7 / 0.03mm) φ 0.3-0.4mm 14 DF19 Series/1.0mm Pitch, Low Profile Wire-to-Board, FPC-to-Board, Micro-coaxial Cable-to-Board Connectors 4.36 Grounding Plate for Micro-coaxial Cable Contact No. 1 Indicator Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 1.27 A Unit : mm Part No. HRS No. No. of Pos. A DF19G-14S-1SD-GND CL0685-0028-9-00 14 17.5 DF19G-20S-1SD-GND CL0685-0027-6-00 20 23.5 15 Purchase Unit 100pcs per bag DF19 Series/1.0mm Pitch, Low Profile Wire-to-Board, FPC-to-Board, Micro-coaxial Cable-to-Board Connectors Embossed Carrier Tape Dimensions (JIS-C-0806 Standard) ● DF19G-#P-1H(52) ● DF19K-#P-1H(52) ● DF19L-#P-1H(52) 12±0.1 2±0.1 4±0.1 G-G 1.75±0.15 t=0.3±0.1 G 2±0.5 φ1.5 Feed Hole Depth C±0.1 Part Number Label φ2 H H H-H E +2 0 F G 2.5±0.15 (2.3) Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 1 B±0.1 A±0.3 D±0.3 φ13 φ80 +0 0 .1 φ330 1.5 1.75±0.1 φ Unreeling Direction 7.8±0.3 Unit : mm No. of Pos. A B C D E F 8 24.0 - 11.5 16.1 24.4 30.4 DF19G-14P-1H(52) 14 44.0 40.4 20.2 22.1 44.4 50.4 DF19G-20P-1H(52) 20 44.0 40.4 20.2 28.1 44.4 50.4 DF19G-30P-1H(52) 30 56.0 50.2 26.2 38.1 56.4 62.4 DF19K-20P-1H(52) 20 44.0 40.4 20.2 28.1 44.4 50.4 DF19K-30P-1H(52) 30 56.0 52.4 26.2 38.1 56.4 62.4 DF19L-14P-1H(52) 14 44.0 40.4 20.2 22.1 44.4 50.4 DF19L-20P-1H(52) 20 44.0 40.4 20.2 28.1 44.4 50.4 DF19L-30P-1H(52) 30 56.0 52.4 26.2 38.1 56.4 62.4 Part No. DF19G-8P-1H(52) 16 Remarks Top-board Mounted (1.65mm Height) Offset Mounted (1.0mm Height) Offset Mounted (1.1mm Height) DF19 Series/1.0mm Pitch, Low Profile Wire-to-Board, FPC-to-Board, Micro-coaxial Cable-to-Board Connectors ● DF19KR-20P-1H(52) 0 .1 1.75±0.15 t=0.3±0.1 2±0.5 C±0.1 G D±0.3 φ2 1 H E G 2.85±0.15 +2 0 F Unreeling Direction H-H (2.3 ) 7.8±0.3 Unit : mm Part No. No. of Pos. A B C D E F 20 44.0 40.4 20.2 28.1 44.4 50.4 DF19KR-20P-1H(52) Remarks Reverse type of DF19K Offset Mounted(1.0mm Height) 4±0.1 H G Ø13 1 H φ1.5 Feed Hole Depth Unreeling Direction t=0.4±0.1 φ80 φ380±2 3.7±0.2 2±0.5 E+20 F Ø2 4±0.2 G Part Number Label D±0.2 12±0.1 C±0.1 B±0.1 A±0.3 .1 +0 0 5 1. 2±0.1 1.75±0.1 ● DF19-#P-1V(52) φ Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Øφ13 φ 80 B±0.1 A±0.3 H φ1.5 Feed Hole Depth Part Number Label φ330 12±0.1 .5 +0 G-G 1.75±0.1 Ø1 Unit : mm Part No. No. of Pos. A B C D E F DF19-14P-1V(52) 14 32.0 28.4 14.2 18.2 32.4 38.4 DF19-20P-1V(52) 20 44.0 40.4 20.2 24.2 44.4 50.4 17 Remarks Straight Type DF19 Series/1.0mm Pitch, Low Profile Wire-to-Board, FPC-to-Board, Micro-coaxial Cable-to-Board Connectors Crimping Precautions ■ Items Required Prior to Crimping The work- related documents shown below are required before starting harness assembly. ( The ● mark represents required documents. ) Please contact your Hirose sales representative if you do not have these documents. Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Document Title Description Automatic Crimping Machine Hand Crimping Tool Remarks Bundled with purchase of main press machine unit. ① Crimping Machine Main Unit Instruction Manual Explanation of main press unit ● - ② Applicator Instruction Manual Crimp Method ● - ③ Applicator Spare Parts List Applicator Installation Instruction ● - ④ Crimp Conditions Crimp height, tensile strength standard value ● - ⑤ Crimp Quality Standards Various standards for crimping conditions ● - ⑥ Hand Tool Operating Instructions Crimp method, crimp height and tensile height standard value - ● Bundled with purchase of hand tool. ⑦ Cable Assembly Cable assembly ● ● Contact a Hirose sales representative. Bundled with purchase of applicator. ■ Tools ・Use tools designated by Hirose when crimping. ・Crimping performed using tools other than those specified is outside the scope of warranty. ・The operating instructions are available for the crimping machine and the applicator. Be sure to carefully read the operating instructions manual before beginning work. ■ Applicable Cables Check that the cables to be used are within the applicable range. If you intend to use a cable other than those recommended, contact a sales representative. [ Precautions] • Cables applicable to crimping connectors are tin- plated stranded soft- copper wire. • Avoid crimping solid wire, wires with polyester threads or tin coated wires. • Avoid crimping two cables together. • The crimp height setting values ( Note) may vary between tin- plated and gold- plated terminals even if the same electric wires are used. • The crimp height setting values ( Note) may vary depending on the difference in the core wire configuration even if the computed cross- sectional area is the same. Note : The crimp height is an important item that determines crimping quality. We execute crimping tests for each electric wire to ensure the optimal value for the crimp height with high precision, thereby ensuring optimal setup values. 18 DF19 Series/1.0mm Pitch, Low Profile Wire-to-Board, FPC-to-Board, Micro-coaxial Cable-to-Board Connectors Precautions 1. Recommended Temperature Profile Temperature (℃) 250℃ 220 200℃ 180 150℃ Preheating Soldering 250℃ 10s Max. 220℃ Min. 60s Max. 60 to 120s Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 100℃ 50℃ 30 50 100 150 200 Time(S) Note 1 : Up to 2 cycles of reflow soldering are possible under the same conditions, provided that there is a return to normal temperature between the first and second cycle. Note 2 : The temperature profile indicates the temperature of the surface of the connector lead. Note 3 : The color of the grounding plate may change color, although this does not affect the product performance. 2. Recommended Manual Soldering Conditions Manual soldering : 350±10℃ for 5 seconds 3. Recommended   Metal Mask Thickness 0.15mm 4. Board Warpage Maximum of 0.03mm at the connector center, with both ends of the connector as reference points. 5. Cleaning Conditions Refer to “Wire-to-Board Connector Use Handbook.” 6. Termination Conditions Refer to “Wire-to-Board Connector Use Handbook.” 7. Cautions ■ Excessive prying during mating and unmating may result in damage. 8. Handling Please refer to the following documents when handling the product. ■ Crimp Quality Standard(ETAD-H9045-00) ■ Wire-to-Board Connector Use Handbook ■ Cable Assembly Procedure (ETAD-H0963-00) 19 DF19 Series/1.0mm Pitch, Low Profile Wire-to-Board, FPC-to-Board, Micro-coaxial Cable-to-Board Connectors Single Row Socket (FPC Type) Assembly Method Insert the FPC diagonally from the top surface of the grounding plate. Pass the FPC through the grounding plate. Step1 After passing the FPC through lower downwards. Signal Surface Step2 Ground Surface Extend the FPC out and fully insert into the socket. Step3 Step4 Assembly point: Slightly raise the FPC to an angle of about 30 degrees, and then insert the grounding plate over the socket. Using the dedicated installation tool, insert the grounding plate. 1.7 Final completion Note 1 : The grounding plate and the socket are supplied as separate components. Note 2 : Dedicated assembly tools are required for assembly. Note 3 : When temporarily inserting the ground plate, the FPC can be easily inserted by lightly lifting the FPC up to 30° and designing a self- alignment guide. However, if excessive force ( bending, twisting, etc. ) is applied to the FPC, the FPC ( edge of the cover film) copper foil may crack. Note 4 : If the ground plate cannot be inserted, make sure it is aligned parallel to the socket and do not force it in. Note 5 : To protect the FPC, insert and remove the connector parallel to the mating surface. Note 6 : To protect the FPC, do not apply excessive tension. Note 7 : Refer to the FPC manufacture recommended bending radius and other specifications. Distance should be allowed for bending as shown below. MIN 5 SIGNAL MIN 10 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Temporarily insert the grounding plate into the socket. Note 8 : When terminating the FPC there is a risk of misuse of the tools, or injury from the ridge on the metal part of the connector, etc. Follow the terminal tools instruction manual to ensure proper termination. 20 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. DF19 Series/1.0mm Pitch, Low Profile Wire-to-Board, FPC-to-Board, Micro-coaxial Cable-to-Board Connectors While Taking into Consideration Specifications mentioned in this catalog are reference values. When considering to order or use this product, please confirm the Drawing and Product Specifications sheets. Use an appropriate cable when using the connector in combination with cables. If considering usage of a non- specified cable, please contact your sales representative. If assembly process is done by jigs & tools which are not identified by Hirose, assurance will not be given. If considering usage for below mentioned applications, please contact your sales representative. In cases where the application will demand a high level of reliability, such as automotive, medical instruments, public infrastructure, aerospace/ defense etc. Hirose must review before assurance of reliability can be given. 2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN        https://www.hirose.com ※ The contents of this catalog are current as of date of 1/ 2022. Contents are subject to change without notice for the purpose of improvements. 21
DF19-2830SCFA(41) 价格&库存
很抱歉,暂时无法提供与“DF19-2830SCFA(41)”相匹配的价格&库存,您可以联系我们找货
DF19-2830SCFA(41)
  • 1+0.885141+0.11456
  • 10+0.7411710+0.09593
  • 25+0.6948925+0.08994
  • 50+0.6597050+0.08538
  • 100+0.62877100+0.08138
  • 250+0.58910250+0.07625
  • 500+0.56071500+0.07257
DF19-2830SCFA(41)
  • 20000+0.5620920000+0.07275
