MDF51-24SCF
MDF51-24SCF
    HRS(广濑)
MDF51-24SCF 数据手册
High Voltage Wire-to-Board Connectors MDF51 Series ●Simple and secure mating with one push Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Socket Header Lock Fig.1 ■Features ●Secure hold during the soldering operation 1. Simple, one step mating Built-in locks assure correct and complete mating with just a single, downward push on the plug. 2. Vertical mating style The vertical mating style and built-in, self aligning features are efficient and eliminates the need for additional space that would be required with a horizontal mating style connector. Insulator Contacts 3. Designed for high voltage applications Wide contact pitch and creepage distance maintain stable and safe performance at high voltage levels. 4. Secure attachment to the board Hold-down Four solder points are provided to keep the headers firmly secured to the PCB. Fig.2 5. Secure hold during the soldering operation. The 12 mm pitch version incorporates a built in holddown feature that helps keep the connector aligned during the soldering operation. 6. UL, C-UL, and TÜV certified (12mm pitch only) 7. RoHS compliant ■Applications LCD TV backlights, FPD power supplies and other applications requiring small high-voltage connectors. In cases where the application will demand a high level of reliability, such as automotive, please contact a company representative for further information. 2015.8w 1 MDF51 Series●High Voltage Wire-to-Board Connectors ■Product Specification Current rating 1A Voltage rating 3000V AC/DC Ratings Ratings -35°C to +85°C (Note 1) Operating humidity range RH 20% to 80% Storage temperature range -10°C to +60°C (Note 2) Storage humidity range RH 40% to 70% (Note 2) ■File and recognition numbers: UL, C-UL TÜV Current rating 1A 1A Voltage rating 1000V AC/DC 1000V AC/DC Item Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Operating temperature range UL and C-UL : E52653 TÜV Specifications : R50085755 Conditions 1. Insulation resistance 1000Mø min. 500V DC 2. Withstanding voltage No flashover or insulation breakdown 5000V AC / 1 minute 3. Contact resistance 20mø max. 20mV max., at 1mA . No electrical discontinuity of 1µs or longer Frequency: 10 to 55Hz, single amplitude of 0.75mm, No damaged, cracked or loose parts. 10 cycles, 3 axis No electrical discontinuity of 1µs or longer Acceleration of 490 m/s2, 11 ms duration, sine half-wave, No damaged, cracked or loose parts. 3 cycles in each of the 3 axis 4. Vibration 5. Shock Contact resistance: 40mø max., 6. Humidity Insulation resistance: 500Mø min. 96 hours at of 40 ±2ç, and humidity of 90 to 95% No damaged, cracked or loose parts. 7. Temperature cycle 8. Mating cycles Contact resistance: 40mø max., -55ç → 5 to 35ç → 85ç → 5 to 35ç Insulation resistance: 500Mø min. Times: 30 min. → 3 min. → 2 min. to 3 min. → 30 min. → 2 min. to 3 min. No damaged, cracked or loose parts. 5 cycles Contact resistance: 40mø max. No damaged, cracked or loose parts. 9. Resistance to soldering No deformation of components affecting heat performance 30 cycles Reflow: At the recommended temperature profile (MDF51SU) Flow: Solder temperature 260ç, 10 seconds (MDF51K and MDF51SY) Manual soldering: 350ç for 3 seconds Note 1 : Includes temperature rise caused by current flow. Note 2 : The term "storage" refers to products stored for a long period prior to mounting and use. The operating temperature and humidity range covers the non-conducting condition of installed connectors in storage, shipment or during transportation. ■Material / Finish ●Header Part Material MDF51K Insulator Contact PBT Finish Remarks Color : Black MDF51SU : Polyamide Color : Beige MDF51SY : Polyamide Color : Black Brass Tin plating UL94V-0 ----------------- ●Crimp socket Part Socket Insulator Crimp contact 2 Material MDF51 : Polyamide Finish Color : White MDF51SU : Polyamide Color : Gray Phosphor bronze Tin plating Remarks UL94V-0 ----------------- MDF51 Series●High Voltage Wire-to-Board Connectors ■Product Number Structure ●Header MDF51 # – * P – 12 DSA ❷ ❶ ❸ ❹ ❺ ❻ ❶ Series name : MDF51 ❸ No. of contacts ❷ Configuration type ❹ Connector type K : Contact pitch 12mm, through hole ❺ Contact pitch SU : Contact pitch 13mm, surface mount ❻ Mounting style SY : Contact pitch 13mm, through hole P : Header 12mm or 13mm DSA : Through hole, straight V Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. :2 : Surface mount, straight ●Crimp socket MDF51 # – * S – 12 C ❷ ❶ ❸ ❹ ❺ ❻ ❶ Series name : MDF51 ❸ No. of contacts ❷ Configuration type ❹ Connector type Blank : Contact pitch 12mm, standard ❺ Contact pitch SU ❻ Termination : Contact pitch 13mm, standard :2 S : Crimp socket 12mm or 13mm C : Crimp ●Contacts MDF51 – 24 SCF ❶ ❶ Applicable wire size 24 : 24 AWG ❷ ❷ Packaging SCF : Female crimp contact / reel 3 MDF51 Series●High Voltage Wire-to-Board Connectors ■Header (Contact pitch : 12 mm) ●Straight, through hole Contact No.1 mark 1.6 11.9 0.5 6.28 1.8 21.5 P=12 A (1.8) 6.75 12±0.1 2.8 1.5+0.1 0 12±0.1 6.28±0.1 Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Recommended PCB layout dimensions (Thickness : 1.6mm) 0.5+0.1 0 t=0.3 16.7 16.7±0.1 Unit : mm 16 7±0 ●Packaging Specification 340 16.65 P=18 260 P=18 Part No. HRS No. No. of Insulator contacts Color MDF51K-2P-12DSA(20) 547-2017-9 20 2 Black Packaging 150 pcs/tray Please place orders in full tray increments. ■Crimp socket (Contact pitch : 12 mm) Contact No.1 mark 1 2 A 9.85 25.6 ●With crimp contacts assembled Unit : mm P=12 Part No. HRS No. No. of contacts Insulator Color Packaging MDF51-2S-12C 547-2004-7 00 2 White 100 pcs/pack Please place orders in full pack increments. 4 1.45 4.55 • Contacts supplied separately 9.35 MDF51 Series●High Voltage Wire-to-Board Connectors ■Header (Contact pitch : 13 mm) ●Straight, surface mount 24.1 18.2 P=13 3.5mm dia. flat surface, for placement with automatic equipment. t=0.3 18.2 0 (4.45) 0.1 6.5 Recommended PCB layout dimensions 2.6 +0.1 0 +0.1 (3.85) 8±0.05 3 0 12.1 14.1 18.2±0.05 2±0.05 2±0.05 18.2±0.05 Contact No.1 mark Unit : mm ●Packaging Specification + 0 0 .1 1.75±0.1 20±0.1 B Ø1 .5 (24.5) B-B (Ø80) (Ø380) 0.2 Ø13± 44±0.3 20.2±0.1 Unreeling direction 40.4±0.1 (2) 4±0.1 (44.5) 50.4MAX .1 +00 75 0.2±0.05 A R0. Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 14.1 (7.7) B A A-A Unreeling direction (14.5) Part No. HRS No. No. of contacts Insulator Color Packaging 2 Beige 600 pcs/reel MDF51SU-2P-13V(23) 547-2016-6 23 Please place orders in full reel increments. 5 MDF51 Series●High Voltage Wire-to-Board Connectors ■Header (Contact pitch : 13 mm) ●Straight, through-hole 19.1 1.2 Contact No.1 mark 1.8 P=13 t=0.3 6.85 2.8 1.2 Recommended PCB layout dimensions PCB thickness : 1.6mm 6.75 2.8 2 +0.1 0 (1.8) 0.9 +0.1 0 6.85±0.1 24.1 2 +0.1 0 0.9+0.1 0 Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 19.1±0.1 18.2 Unit : mm 18.2±0.1 ●Packaging Specification ()% &+#+* E2(( Part No. HRS No. '+% No. of contacts Insulator Color Packaging 2 Black 120 pcs/tray MDF51SY-2P-13DSA(21) 547-0920-3 21 E2(( Please place orders in full tray increments. 12.75 ■Crimp socket (Contact pitch : 13 mm) Contact No.1 indicator 1.45 4.45 27.8 13 Unit : mm Part No. HRS No. No. of contacts Insulator Color Packaging MDF51SU-2S-13C(03) 547-2018-1 03 2 Gray 100 pcs/pack Please place orders in full pack increments. 6 MDF51 Series●High Voltage Wire-to-Board Connectors Crimp contact 3.1 1.4 1 3 4.1 0.8 8.1 2.25 1.4 t=0.2 Part No. MDF51-24SCF(40) HRS No. 547-2005-0 40 Unit : mm Finish Tin plating Packaging 10,000 / reel Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Please place orders in full reel increments. ●Applicable wire (Tin plated, annealed copper wire) Wire size (Stranded wire conductor) AWG#24 (19 / Ø0.127mm) ●UL style : UL3239 Jacket diameter Ø1.74mm ●Strip length Note : When using other than the recommended wire, contact your nearest Hirose sales representative. 1.8 to 2.6mm Tools Type Applicator Press Contact extraction tool Part No. AP105-MDF51-24S CM-105 DF-C-PO (B) HRS No. 901-4607-9 00 901-0005-4 00 550-0179-2 00 Applicable contact MDF51-24SCF ----------------MDF51-24SCF Usage Recommendations 1.Recommended temperature profile Temperature (ç) 255çMAX 250 10sMAX 230ç 30~60sec 200 180ç 150 60~120sec 100 Time (Seconds) 2.Reccomended flow temperature 3. Recommended manual soldering 4. Recommended screen thickness and open area ratio (Pattern area ratio) 5. Board warpage 6. Cleaning conditions 7. Wire preparation and contact crimping Note 1 : Up to 2 cycles of Reflow soldering are possible under the same conditions, provided that there is a return to normal temperature between the first and second cycle. Note 2 : The temperature profile indicates the board surface temperature at the point of contact with the connector terminals. Peak temperature : 260ç for 10 seconds max. Manual soldering : 350ç for 3 seconds max. Thickness : 0.15mm Open area ratio : 100% Maximum of 0.03mm at the connector center, with both ends of the connector as reference points. Refer to "Board to cable connectors Use Handbook". Refer to “Board to cable connectors Use Handbook”. The crimp contact termination must be performed using specified tools. All dimensions and crimp conditions are listed in applicable Crimp Condition Table and Crimping Quality Standards Manual. 7 MDF51 Series●High Voltage Wire-to-Board Connectors 8. Precautions ■ Mating 1 Socket will self-align in the header. 2 Align the Socket over the header and firmly push-down at the “O” symbol until both locks are fully engaged. Tactile “click” sensation will confirm fully locked condition. Lock release Crimp socket Lock release PUSH Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Crimp socket O mark symbol Header Step 1 Step 2 ■Unmating 1 Compress both locks evenly, toward each other. 2 While compressing the lock releases pull the socket straight up until free of the header. PUSH Crimp socket O mark symbol Header PUSH Step 1 Step 2 ■The crimped contacts must be fully inserted in the crimp socket horizontally and will self-guide itself in the proper position ■The header must be mounted on the PC board when mating with the corresponding socket. ■Differences in colors shade of the molded components will not affect form, fit or function. ■Contact HRS if additional information is required. 8 Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. MDF51 Series●High Voltage Wire-to-Board Connectors MEMO : 9 Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. MDF51 Series●High Voltage Wire-to-Board Connectors MEMO : 10 Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. MDF51 Series●High Voltage Wire-to-Board Connectors MEMO : 11 Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. MDF51 Series●High Voltage Wire-to-Board Connectors USA: HIROSE ELECTRIC (U.S.A.), INC. HEADQUARTERS 2688 Westhills Court, Simi Valley, CA 93065-6235 Phone : +1-805-522-7958 Fax : +1-805-522-3217 http://www.hirose.com/us/ USA: HIROSE ELECTRIC (U.S.A.), INC. SAN JOSE OFFICE 3255 Scott Boulevard, Building 7, Suite 101 Santa Clara, CA 95054 Phone : +1-408-253-9640 Fax : +1-408-253-9641 http://www.hirose.com/us/ USA: HIROSE ELECTRIC (U.S.A.), INC. CHICAGO OFFICE 580 Waters Edge Lane, Suite 205 Lombard IL 60148 Phone : +1-630-282-6701 Mail : inquiries@hirose.com http://www.hirose.com/us/ USA: HIROSE ELECTRIC (U.S.A.), INC. DETROIT OFFICE (AUTOMOTIVE) 17197 N. Laurel Park Drive, Suite 253, Livonia, MI 48152 Phone : +1-734-542-9963 Fax : +1-734-542-9964 http://www.hirose.com/us/ THE NETHERLANDS: HIROSE ELECTRIC EUROPE B.V. Hogehillweg #8 1101 CC Amsterdam Z-O Phone : +31-20-6557460 Fax : +31-20-6557469 http://www.hirose.com/eu/ GERMANY: HIROSE ELECTRIC EUROPE B.V. GERMAN BRANCH Herzog-Carl-Strasse 4 D-73760 Ostfildern (Scharnhauser Park) Phone : +49-711-4560-02-1 Fax : +49-711-4560-02-299 http://www.hirose.com/eu/ GERMANY: HIROSE ELECTRIC EUROPE B.V. NUERNBERG OFFICE Muggenhofer Str. 136 90429 Nuernberg Phone : +49-911 32 68 89 63 Fax : +49-911 32 68 89 69 http://www.hirose.com/eu/ GERMANY: HIROSE ELECTRIC EUROPE B.V. HANOVER OFFICE Bayernstr. 3, Haus C 30855 Langenhagen, Germany Phone : +49-511 97 82 61 30 Fax : +49-511 97 82 61 35 http://www.hirose.com/eu/ FRANCE: HIROSE ELECTRIC EUROPE B.V. PARIS OFFICE Regus La Garenne Colombes,Place de La Belgique, 71 Boulevard National La Garenne Colombes, 92250, France Phone : +33 (0) 1 7082 3170 Fax : +33 (1) 7082 3101 http://www.hirose.com/eu/ UNITED KINGDOM: HIROSE ELECTRIC EUROPE BV (UK BRANCH) 4 Newton Court, Kelvin Drive, Knowlhill, Milton Keynes, MK5 8NH Phone : +44-1908 202050 Fax : +44-1908 202058 http://www.hirose.com/eu/ CHINA: HIROSE ELECTRIC (SHANGHAI) CO., LTD. 1601, Henderson Metropolitan, NO.300, East Nanjing Road, Huangpu District, Shanghai, China 200001 Phone : +86-21-6391-3355 Fax : +86-21-6391-3335 http://www.hirose.com/cn/ CHINA: HIROSE ELECTRIC (SHANGHAI) CO.,LTD. BEIJING BRANCH A1001, Ocean International Center, Building 56# East 4th Ring Middle Road, ChaoYang District, Beijing, 100025 Phone : +86-10-5165-9332 Fax : +86-10-5908-1381 http://www.hirose.com/cn/ CHINA: HIROSE ELECTRIC TECHNOLOGIES (SHENZHEN) CO., LTD. Room 09-13, 19/F, Office Tower Shun Hing Square, Di Wang Commercial Centre, 5002 Shen Nan Dong Road, Shenzhen City, Guangdong Province, 518008 Phone : +86-755-8207-0851 Fax : +86-755-8207-0873 http://www.hirose.com/cn/ HONG KONG: HIROSE ELECTRIC HONGKONG TRADING CO., LTD. Room 1001, West Wing, Tsim Sha Tsui Centre, 66 Mody Road, Tsim Sha Tsui East, Kowloon, Hong Kong Phone : +852-2803-5338 Fax : +852-2591-6560 http://www.hirose.com/hk/ TAIWAN: HIROSE ELECTRIC TAIWAN CO., LTD. 103 8F, No.87, Zhengzhou Rd., Taipei Phone : +886-2-2555-7377 Fax : +886-2-2555-7350 http://www.hirose.com/tw/ KOREA: HIROSE KOREA CO., LTD. 250, Huimanggongwon-ro, Siheung-si, Gyeonggi-do, Korea, 429-849 Phone : +82-31-496-7000,7124 Fax : +82-31-496-7100 http://www.hirose.co.kr/ SINGAPORE: INDIA: HIROSE ELECTRIC SINGAPORE PTE. LTD. DELHI LIAISON OFFICE HIROSE ELECTRIC SINGAPORE PTE. LTD. 10 Anson Road #26-16, International Plaza Office NO.519, Regus-Green Boulevard, Level5, Tower C, Sec62, Plot B-9A, Block B, Noida, 201301, Uttar Pradesh, India 079903, Singapore Phone : +91-12-660-8018 Phone : +65-6324-6113 Fax : +91-120-4804949 Fax : +65-6324-6123 http://www.hirose.com/sg/ http://www.hirose.com/sg/ INDIA: HIROSE ELECTRIC SINGAPORE PTE. LTD. BANGALORE LIAISON OFFICE Unit No-403, 4th Floor, No-84, Barton Centre, Mahatma Gandhi (MG) Road, Bangalore 560 001, Karnataka, India Phone : +91-80-4120 1907 Fax : +91-80-4120 9908 http://www.hirose.com/sg/ MALAYSIA: HIROSE ELECTRIC SINGAPORE PTE. LTD. 1-10-07, Suntech @ Penang Cybercity (1164),Lintang Mayang Pasir 3,11950, Bayan Baru, Penang, Malaysia. Phone : +604-619-2564 Fax : +604-619-2574 http://www.hirose.com/sg/ ® 12 THAILAND: HIROSE ELECTRIC SINGAPORE PTE. LTD. BANGKOK OFFICE (REPRESENTATIVE OFFICE) Unit 4703, 47th FL., 1 Empire Tower, South Sathorn Road, Yannawa, Sathorn, Bangkok 10120 Thailand Phone : +66-2-686-1255 Fax : +66-2-686-3433 http://www.hirose.com/sg/ 2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN TEL: +81-45-620-3526 Fax: +81-45-591-3726 http://www.hirose.com http://www.hirose-connectors.com The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use. The contents of this catalog are current as of date of 08/2015. Contents are subject to change without notice for the purpose of improvements.
MDF51-24SCF 价格&库存
很抱歉,暂时无法提供与“MDF51-24SCF”相匹配的价格&库存,您可以联系我们找货
