GT8E-2022SC
GT8E-2022SC
    HRS(广濑)
GT8E-2022SC 数据手册
Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. GT8E Series 2.0mm Pitch, Wire-to-Board, Wire-to-Wire Connector Mar. 2022 GT8E Series/2.0mm Pitch, Wire-to-Board, Wire-to-Wire Connector Features 1. Contact portion oxidation prevention Air- tight dimple design prevents oxidation of the contact portion. Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 2. Mis- insertion prevention design 3. Prying prevention 4. Ensures high peeling strength The SMT type pin header uses a lead reflow retention tab to ensure high peeling strength. Applications For use inside automotive and industrial equipment. 2 GT8E Series/2.0mm Pitch, Wire-to-Board, Wire-to-Wire Connector Female Connector Terminal 1.7 Part No. HRS No. Material Finish GT8E-2022SCF CL0758-0033-4-00 Tin Plating GT8E-2022SCF(01) CL0758-0033-4-01 Gold Plating GT8B-2428SCF CL0758-0055-7-00 GT8B-2428SCF(01) CL0758-0055-7-01 Gold Plating GT8E-2022SC(Note) CL0758-0101-2-00 Tin Plating Phosphor Bronze Tin Plating Wire Size Jacket Outer Diameter 20-22 AWG φ 1.3-1.5 24-28 AWG φ 0.9-1.1 20-22 AWG φ 1.3-1.5 Purchase Unit 10,000pcs per reel 100pcs per bag Note : Product packaged in bag for use with hand tool. Male Connector Terminal 15.45 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 6.2 1.9 1.5 Part No. HRS No. GT8E-2022PCF CL0758-0039-0-00 GT8EF-2022PCF CL0758-0111-6-00 GT8E-2428PCF CL0758-0067-6-00 GT8EF-2428PCF CL0758-0106-6-00 Material Finish Tin Plating Brass Gold Plating Tin Plating Gold Plating 3 Wire Size Jacket Outer Diameter 20-22 AWG φ 1.3-1.5 24-28 AWG Purchase Unit 10,000pcs per reel 8,000pcs per reel φ 0.9-1.1 10,000pcs per reel φ 1.3-1.5 8,000pcs per reel GT8E Series/2.0mm Pitch, Wire-to-Board, Wire-to-Wire Connector Female Connector Housing (1 Row Type) GT8E-#S-HU 10 ● A 4.6 7.6 B Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. P=2 C Unit : mm Part No. HRS No. Material Color No. of Pos. A B C GT8E-3S-HU CL0758-0061-0-00 3 7.9 7.9 4.0 GT8E-4S-HU CL0758-0047-9-00 4 8.6 8.6 6.0 GT8E-5S-HU CL0758-0062-2-00 5 12.0 8.0 GT8E-6S-HU CL0758-0048-1-00 6 12.6 10.0 GT8E-7S-HU CL0758-0063-5-00 7 15.6 GT8E-8S-HU CL0758-0049-4-00 8 16.6 14.0 GT8E-10S-HU CL0758-0050-3-00 10 20.6 18.0 PBT Black Note : The compatible terminals for tin plating are GT8E-2022SCF, GT8B-2428SCF, and GT8E-2022SC. The compatible terminals for gold plating are GT8E-2022SCF(01) and GT8B-2428SCF(01). 4 7.1 12.0 Purchase Unit 100pcs per bag GT8E Series/2.0mm Pitch, Wire-to-Board, Wire-to-Wire Connector GT8E-#S-2C 10 ● Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 4.6 7.6 A Unit : mm Part No. HRS No. GT8E-2S-2C CL0758-0030-6-00 GT8E-8S-2C CL0758-0029-7-00 Material Color PBT Black No. of Pos. A Purchase Unit 2 7.1 8 16.6 100pcs per bag Note 1 : The compatible terminals for tin plating are GT8E-2022SCF, GT8B-2428SCF, and GT8E-2022SC. The compatible terminals for gold plating are GT8E-2022SCF(01) and GT8B-2428SCF(01). Note 2 : Socket GT8E-2S-2C mates with GT8E-2P-2H(57), GT8E-8/2P-2H(56) and GT8E-2P-DS(55). Socket GT8E-8S-2C mates with GT8E-8/2P-2H(56) and GT8E-8/5P-2H(55). 5 GT8E Series/2.0mm Pitch, Wire-to-Board, Wire-to-Wire Connector 10 Female Connector Housing (2 Row Type) A 10 7.45 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 5.8 P=2 B Unit : mm Part No. HRS No. GT8E-12DS-HU CL0758-0051-6-00 GT8E-16DS-HU CL0758-0064-8-00 GT8E-20DS-HU CL0758-0052-9-00 GT8E-24DS-HU CL0758-0054-4-00 Material PBT Color Black No. of Pos. A B 12 16.6 14.0 16 21.85 18.0 20 24.6 22.0 24 28.6 26.0 Note : The compatible terminals for tin plating are GT8E-2022SCF, GT8B-2428SCF, and GT8E-2022SC. The compatible terminals for gold plating are GT8E-2022SCF(01) and GT8B-2428SCF(01). 6 Purchase Unit 100pcs per bag GT8E Series/2.0mm Pitch, Wire-to-Board, Wire-to-Wire Connector 11 Female Connector Housing (Low Height Type) Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 4.6 5.7 A P=2 B * Unit : mm Part No. HRS No. GT8EC-3S-HU CL0758-1017-3-00 GT8EC-5S-HU CL0758-0074-1-00 GT8EC-8S-HU CL0758-1018-6-00 GT8EC-14S-HU CL0758-0224-2-00 Material PBT Color Black No. of Pos. A B 3 7.9 4.0 5 12.0 8.0 8 16.6 14.0 14 28.4 26.0 Note : The compatible terminals for tin plating are GT8E-2022SCF, GT8B-2428SCF, and GT8E-2022SC. The compatible terminals for gold plating are GT8E-2022SCF(01) and GT8B-2428SCF(01). 7 Purchase Unit 100pcs per bag GT8E Series/2.0mm Pitch, Wire-to-Board, Wire-to-Wire Connector In-line Type 3 1 * GT8E-3P-HU PBT 21.8 6.9 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. A 2 B Diagram of Mating Condition During Use GT8E-#P-HU (23.2) GT8E-#S-HU  Unit : mm Part No. HRS No. GT8E-3P-HU CL0758-0084-5-00 GT8E-4P-HU CL0758-0082-0-00 GT8E-8P-HU CL0758-0038-8-00 Material Color No. of Pos. 3 PBT Black 4 8 A 10.55 18.55 B 4.0 6.0 14.0 Note 1 : The compatible terminals for tin plating are GT8E-2022PCF and GT8E-2428PCF. The compatible terminals for gold plating are GT8EF-2022PCF and GT8EF-2428PCF. Note 2 : GT8E-3P-HU mates with GT-8E-3S-HU. GT8E-4P-HU mates with GT8E-4S-HU. GT8E-8P-HU mates with GT8E-8S-2C. Note 3 : GT8E-8P-HU can mate with GT8E-8S-HU, but if mated at a diagonal can interfere with the male terminal. 8 Purchase Unit 100pcs per bag GT8E Series/2.0mm Pitch, Wire-to-Board, Wire-to-Wire Connector 13.65 11.1 Right Angle Pin Header (1 Row SMT Type) A B 1.5 D Diagram of Mating Condition During Use (12.5) GT8E-#P-2H GT8E-#S-HU Recommended PCB Dimensions E 4.3 R1 2 7.4 6-φ 1. 2 3 1.06 4.8 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. C 0.1 0.1 6.9 Lot Indicator F Unit : mm Part No. HRS No. GT8EA-2P-2H(55) CL0758-0113-1-55 GT8E-3P-2H(55) CL0758-0096-4-55 Housing Terminal (Finish) Tin Plating Contact Area : Gold Plating Mounting Area : Tin Plating No. of Pos. A B C D E F Purchase Unit 2 12.9 9.05 2.0 10.58 2.0 10.58 450pcs per reel 3 13.7 9.85 4.0 11.28 4.0 11.28 4 14.4 10.55 6.0 11.98 6.0 11.98 5 17.8 13.95 8.0 15.38 8.0 15.38 6 18.4 14.55 10.0 15.98 10.0 15.98 7 21.4 17.55 12.0 18.98 12.0 18.98 GT8E-3P-2H(56) CL0758-0096-4-56 GT8E-4P-2H(55) CL0758-0079-5-55 GT8E-5P-2H(55) CL0758-1004-1-55 GT8E-6P-2H(55) CL0758-1005-4-55 GT8E-7P-2H(55) CL0758-0126-3-55 GT8E-8P-2H(55) CL0758-1006-7-55 8 22.4 18.55 14.0 19.98 14.0 19.98 GT8E-10P-2H(55) CL0758-1007-0-55 10 26.4 22.55 18.0 23.98 18.0 23.98 GT8E-14P-2H(55) CL0758-0223-0-55 14 36.4 30.55 26.0 31.78 26.0 31.78 Material : PPS Color : Black Tin Plating 9 400pcs per reel 450pcs per reel GT8E Series/2.0mm Pitch, Wire-to-Board, Wire-to-Wire Connector PIN No.9 A PIN No.12 13.65 11.1 Right Angle Pin Header (2 Row SMT Type) B 0.1 10.23 * PIN No.1 P=2 0.1 PIN No.8 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. C D Diagram of Mating Condition During Use (12.5) (1.4) GT8E-#DS-HU GT8E-#DP-2H Recommended PCB Dimensions 12 8 11 7 6 5 4 3 10 2 9 1 2.5 5.27 1 7.4 4.3 7.5 1.2 6-φ (T 4 6 8 10 12 13 14 15 ) ole -H gh u hro 1 19.98 0.7 4-R Pin Arrangement 2 2 3 Unit : mm Part No. HRS No. GT8E-12DP-2H(55) CL0758-1008-2-55 GT8E-16DP-2H(55) CL0758-1009-5-55 GT8E-20DP-2H(55) CL0758-1010-4-55 GT8E-24DP-2H(55) CL0758-1011-7-55 Housing Material : PPS Color : Black Terminal (Finish) Tin Plating 10 No. of Pos. A B C D 12 22.4 18.55 14.0 19.98 16 27.45 23.6 18.0 25.03 20 30.2 26.35 22.0 27.78 24 34.2 30.35 26.0 31.78 Purchase Unit 300pcs per reel GT8E Series/2.0mm Pitch, Wire-to-Board, Wire-to-Wire Connector Straight Pin Header (1 Row SMT Type) A * E Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 4.2 12 B P=2 C 4.3 9.5 D Diagram of Mating Condition During Use GT8E-#S-HU (1.4) (13.4) GT8E-#P-2V Recommended PCB Dimensions (Connector Side) G 2 6× φ1 .2 2.5 4.65 7.4 4.3 R1 1 2 F Unit : mm Part No. HRS No. GT8E-2P-2V(55) CL0758-0202-0-55 GT8E-4P-2V(55) CL0758-0121-0-55 GT8E-7P-2V(55) CL0758-0227-0-55 GT8E-10P-2V(55) CL0758-0232-0-55 Housing Material : PPS Color : Black Terminal No. of Pos. (Finish) Tin Plating A B C D E F G 2 13.0 9.15 2.0 10.6 6.85 2.0 10.6 4 14.4 10.55 6.0 11.98 7.3 6.0 11.98 7 21.4 17.55 12.0 19.1 7.3 12.0 19.1 10 26.4 22.55 18.0 24.1 7.3 18 24.1 11 Purchase Unit 300pcs per reel GT8E Series/2.0mm Pitch, Wire-to-Board, Wire-to-Wire Connector Straight Pin Header (1 Row SMT with L-shaped Retention Tabs) 4 (Mated Portion) 9.95 2 (Mated Portion) 17.6 14.6 11.95 2 4 Diagram of Mating Condition During Use GT8E-3S-HU (1.4) (13.35) GT8EH-3P-2V Recommended PCB Dimensions 4 2 3.3 Part No. GT8EH-3P-2V(55) HRS No. CL0758-1016-0-55 11.4 2.4 5.4 0.9 2.15 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 10.4 3.3 Housing Terminal (Finish) No. of Pos. Purchase Unit Material : PPS Color : Black Tin Plating 3 200pcs per reel 12 GT8E Series/2.0mm Pitch, Wire-to-Board, Wire-to-Wire Connector Straight Pin Header (2 Row SMT with L-shaped Retention Tabs) PIN No.9 10.95 9.95 PIN No.12 PIN No.8 2 PIN No.1 D 11.95 A B C Recommended PCB Dimensions 3.2 20.1 6.175 3.3 2 3.3 14 2.95 5.4 12.35 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Lot No. 0.9 Note : Drawing of GT8EH-12DP-2V(58) Unit : mm Part No. HRS No. GT8EH-12DP-2V(58) CL0758-1019-9-58 GT8EH-14DP-2V(56) CL0758-0225-5-56 GT8EH-24DP-2V(57) CL0758-1020-8-57 Housing Material : PPS Color : Black Terminal (Finish) No. of Pos. A B C D Tin Plating 12 26.3 23.3 19.1 14.0 Contact Area : Gold Plating Mounting Area : Tin Plating 14 28.3 25.3 21.1 16 24 38.3 35.3 31.1 26 13 Purchase Unit 200pcs per reel GT8E Series/2.0mm Pitch, Wire-to-Board, Wire-to-Wire Connector Right Angle Pin Header (1 Row SMT, Low Profile Type) 11.1 13.65 0.6 3.9 2 13 9.15 6 0.1 0.1 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. * 10.58 Diagram of Mating Condition During Use (12.5) (1.4) GT8E-2S-2C GT8E-2P-2H Recommended PCB Dimensions 2 1.06 4.3 7.4 4.8 3 .2 φ1 6- Part No. GT8E-2P-2H(57) HRS No. CL0758-0032-1-57 R1 2 10.58 Housing Terminal (Finish) No. of Pos. Purchase Unit Material : PPS Color : Black Tin Plating 2 500pcs per reel Note : This product mates with GT8E-2S-2C. 14 GT8E Series/2.0mm Pitch, Wire-to-Board, Wire-to-Wire Connector Right Angle Pin Header (1 Row SMT, Low Profile Hybrid Type) ● 8 pin / 2 pin Hybrid Type 14 5.2 2 9.5 11.1 13.65 2 31.25 6 * 0.1 1.4 28.48 Diagram of Mating Condition During Use (12.5) (1.4) GT8E-8/2P-2H GT8E-2S-2C, GT8E-8S-2C Recommended PCB Dimensions 2 14 5.2 2 1.06 .2 φ1 67.4 4.8 3 4.3 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 27.05 2 Part No. HRS No. GT8E-8/2P-2H(56) CL0758-0031-9-56 Note : This product mates with GT8E-2S-2C and GT8E-8S-2C. 15 R1 28.48 Housing Terminal (Finish) Purchase Unit Material : PPS Color : Black Tin Plating 500pcs per reel GT8E Series/2.0mm Pitch, Wire-to-Board, Wire-to-Wire Connector 8 pin / 5 pin Hybrid Type 14 4.6 2 8 9.5 11.1 2 13.65 ● 36.45 31.85 6 0.1 1.4 33.68 Diagram of Mating Condition During Use (1.4) GT8E-8S-2C,GT8E-5S-HU (12.5) GT8E-8/5P-2H Recommended PCB Dimensions 3.19 2 14 4.6 8 2 1.06 .2 φ1 67.4 4.8 3 4.3 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. * Part No. HRS No. GT8E-8/5P-2H(55) CL0758-0073-9-55 2 Note : This product mates with GT8E-5S-HU and GT8E-8S-2C. 16 R1 33.68 Housing Terminal (Finish) Purchase Unit Material : PPS Color : Black Tin Plating 500pcs per reel GT8E Series/2.0mm Pitch, Wire-to-Board, Wire-to-Wire Connector 11.1 12.85 Right Angle Pin Header (1 Row Through-Hole Type) A B 3 P=2 C D Diagram of Mating Condition During Use (12.5) Connector Side Recommended PCB Dimensions and Pin No. ) ole -H gh rou Th .1( φ1 10 L T 2( 1. φ 6- hr 6- le) Ho h- g ou nd La R 1.9 sφ iu ad 6.25 P=2 E 75 1. φ s diu Ra d an 1 4.3 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 3 4.5 7 * F Unit : mm Part No. HRS No. GT8E-2P-DS(55) CL0758-0040-0-55 GT8E-3P-DS(55) Housing Terminal No. of Pos. (Finish) A B C D E F Purchase Unit 2 13.0 9.15 2.0 10.58 2.0 10.58 192pcs per tray CL0758-0057-2-55 3 13.7 9.85 4.0 11.28 4.0 11.28 184pcs per tray GT8E-4P-DS(55) CL0758-0041-2-55 4 14.4 10.55 6.0 11.98 6.0 11.98 176pcs per tray GT8E-5P-DS(55) CL0758-0058-5-55 5 17.8 13.95 8.0 15.38 8.0 15.38 144pcs per tray GT8E-6P-DS(55) CL0758-0042-5-55 6 18.4 14.55 10.0 15.98 10.0 15.98 136pcs per tray GT8E-7P-DS(55) CL0758-0059-8-55 7 21.4 17.55 12.0 18.98 12.0 18.98 120pcs per tray GT8E-8P-DS(55) CL0758-0043-8-55 8 22.4 18.55 14.0 19.98 14.0 19.98 112pcs per tray GT8E-10P-DS(55) CL0758-0044-0-55 10 26.4 22.55 18.0 23.98 18.0 23.98 96pcs per tray Material : PPS Color : Black Tin Plating Note 1 : This product mates with GT8E-#S-HU. Note 2 : Only GT8E-2P-DS mates with GT8E-2S-2C. 17 GT8E Series/2.0mm Pitch, Wire-to-Board, Wire-to-Wire Connector 11.1 14.85 Right Angle Pin Header (2 Row Through-Hole Type) A B 3 3 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 4.5 9.83 * P=2 2 C D Diagram of Mating Condition During Use 10.5 (12.5) ) ole gh et er φ 1. 9 h-H Di am 1 4.3 6.25 14 6-φ 15 2 24 nd E P=2 1.2 (Th 6rou La g φ 1. 1 Lan d (T hr ou Dia me -H ter ole ) φ 1.7 5 Connector Side Recommended PCB Dimensions and Pin No. F Unit : mm Part No. HRS No. GT8E-12DP-DS(55) CL0758-0045-3-55 GT8E-16DP-DS(55) CL0758-0060-7-55 GT8E-20DP-DS(55) CL0758-0046-6-55 GT8E-24DP-DS(55) CL0758-0053-1-55 Housing Material : PPS Color : Black Terminal No. of Pos. (Finish) Tin Plating A B C D E F Purchase Unit 12 22.4 18.55 14.0 19.98 14.0 19.98 104pcs per tray 16 27.25 23.6 18.0 25.03 18.0 25.03 88pcs per tray 20 30.0 26.35 22.0 27.78 22.0 27.78 80pcs per tray 24 34.0 30.35 26.0 31.78 26.0 31.78 72pcs per tray Note : This product mates with GT8E-#DS-HU. 18 GT8E Series/2.0mm Pitch, Wire-to-Board, Wire-to-Wire Connector Male Connector Straight Pin Header (Through-Hole Type) A 3 2 B 9.5 12.1 Diagram of Mating Condition During Use (13.5) GT8E-#S-HU GT8E-#-DSA ole ) Recommended PCB Dimensions (Th .1 2 1. o hr (T ) ole -H h ug φ 6- 4.3 .75 φ1 B P=2 φ1 ter me rou gh Dia -H nd La Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. C 6 La nd D A iam eter φ1 .9 Unit : mm Part No. HRS No. GT8E-2P-DSA(55) CL0758-0204-5-55 GT8E-3P-DSA(55) CL0758-0112-9-55 GT8E-4P-DSA(55) CL0758-0065-0-55 GT8E-5P-DSA(55) CL0758-0205-8-55 GT8E-6P-DSA(55) CL0758-0201-7-55 GT8E-7P-DSA(55) CL0758-0066-3-55 Housing Terminal (Finish) Material : PA Color : Black Material : PBT Color : Black Tin Plating Material : PA Color : Black Material : PBT Color : Black 19 No. of Pos. A B C Purchase Unit 2 10.58 2.0 13.0 160pcs per tray 3 11.28 4.0 13.7 150pcs per tray 4 12.0 6.0 14.4 150pcs per tray 5 16.4 8.0 18.8 110pcs per tray 6 16.98 10.0 19.4 110pcs per tray 7 18.98 12.0 21.4 100pcs per tray GT8E Series/2.0mm Pitch, Wire-to-Board, Wire-to-Wire Connector Termination Tools Instruction manuals are available for each termination tool. Please contact a Hirose sales representative. Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Automatic Crimp Machine Product No. : CM-105C The picture is an example. There may be changes. Specifications Item Specification Press Capacity 1.5ton Stroke Length 30mm Number of Strokes 200spm(50Hz) Weight 75kg Motor 0.2kw Crimping Speed 2,000 to 4,000pcs./h Terminal Part No. Reference 240spm(60Hz) 100V AC Terminal HRS No. Applicator Part No. Applicator HRS No. CM-105C CL0901-0001-0-00 AP105-GT8B-2428S CL0901-5172-3-00 GT8B-2428SCF CL0758-0055-7-00 GT8B-2428SCF(01) CL0758-0055-7-01 GT8E-2428PCF CL0758-0067-6-00 AP105-GT8E-2428P CL0901-5192-0-00 GT8EF-2428PCF CL0758-0106-6-00 AP105-GT8EF-2428P CL0901-5194-6-00 GT8E-2022SCF CL0758-0033-4-00 GT8E-2022SCF(01) CL0758-0033-4-01 AP105-GT8-2022S CL0901-5144-8-00 GT8E-2022PCF CL0758-0039-0-00 GT8EF-2022PCF CL0758-0111-6-00 AP105-GT8E-2022P CL0901-5161-7-00 The crimp height of the terminal must be set for each cable type. Please contact your sales representative. Please note that a new cable requires a new crimp height setting and evaluation requires a few days. 20 GT8E Series/2.0mm Pitch, Wire-to-Board, Wire-to-Wire Connector Hand Tool The picture is an example. There may be changes. Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Terminal Part No. Terminal HRS No. GT8B-2428SCF CL0758-0055-7-00 GT8B-2428SCF(01) CL0758-0055-7-01 GT8E-2022SCF CL0758-0033-4-00 GT8E-2022SC CL0758-0101-2-00 GT8E-2022SCF(01) CL0758-0033-4-01 Hand Tool Part No. Hand Tool HRS No. HT102/GT8-2428S CL0780-0019-4-00 HT304/GT8E-2022S CL0780-0042-6-00 ・HT304/GT8E-2022S is compatible with 0.3SQ (22 AWG equivalent) ・HT304/GT8E-2022S is not compatible with 0.5SQ (20 AWG equivalent). ・Use HT304/GT8E-2022S by cutting the reels into loose terminals. While Taking into Consideration Specifications mentioned in this catalog are reference values. When considering to order or use this product, please confirm the Drawing and Product Specifications sheets. Use an appropriate cable when using the connector in combination with cables. If considering usage of a non- specified cable, please contact your sales representative. If assembly process is done by jigs & tools which are not identified by Hirose, assurance will not be given. If considering usage for below mentioned applications, please contact your sales representative. In cases where the application will demand a high level of reliability, such as automotive, medical instruments, public infrastructure, aerospace/ defense etc. Hirose must review before assurance of reliability can be given. 2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN        https://www.hirose.com ※ The contents of this catalog are current as of date of 3/ 2022. Contents are subject to change without notice for the purpose of improvements. 21
GT8E-2022SC
物料型号: - 该文档是广濑电机株式会社(HIROSE ELECTRIC CO., LTD.)的产品目录,介绍了GT8E系列2.0mm间距的线对板、线对线连接器。
器件简介: - GT8E系列连接器具备接触部位防氧化设计、防误插设计、防撬设计,并确保了高剥离强度。适用于汽车和工业设备内部。
引脚分配: - 提供了多种型号的连接器,包括不同的引脚数量和配置,例如1排和2排类型,以及不同的引脚间距。
参数特性: - 详细列出了不同型号的连接器的参数,如物料、镀层、线径、外套外径、购买单位等。
功能详解: - 描述了连接器的特点,例如防氧化的密封设计、高剥离强度的SMT型针头使用铅回流保持片等。
应用信息: - 主要用于汽车和工业设备。
封装信息: - 提供了连接器的封装尺寸和推荐PCB尺寸,以及与连接器兼容的端子型号。
GT8E-2022SC 价格&库存
很抱歉,暂时无法提供与“GT8E-2022SC”相匹配的价格&库存,您可以联系我们找货
GT8E-2022SC
  • 1+9.681601+1.20921
  • 10+7.3545310+0.91857
  • 25+6.6150825+0.82621
  • 50+6.1109050+0.76324
  • 100+5.64918100+0.70557
  • 250+5.10405250+0.63749
  • 500+4.73506500+0.59140
  • 1000+4.400141000+0.54957
  • 2500+4.004972500+0.50021
库存:633
