P940-19I
P940-19I
    TRIPPLITE
    7 Position SATA Receptacle to Receptacle 1.58' (482.6mm) Red Shielded
P940-19I 数据手册
Serial ATA (SATA) Latching Signal Cable (7Pin/7Pin), 19-in. (48.26 cm) MODEL NUMBER: P940-19I Highlights ● Connect your high-speed Serial ATA device to a Serial ATA controller ● Support data transfer rates of up to 6.0 Gbps ● Cable is shielded to protect against EMI/RFI Applications ● Connect your high-speed Serial ATA device to a Serial ATA controller ● Compatible with Serial ATA Hard Drives, Blu-ray/DVD/CD Drives and other Serial ATA devices System Requirements ● Serial ATA device ● Serial ATA controller Package Includes Features ● ● Connect your high-speed Serial ATA device to a Serial ATA controller ● Compatible with Serial ATA Hard Drives, Blu-ray/DVD/CD Drives and other Serial ATA devices ● Metal latches ensure secure connections ● Support data transfer rates of up to 6.0 Gbps ● Narrow cables design simplifies cable routing and installation and improves air flow within CPU (no more big ribbons blocking air movement) ● Meets Serial ATA 1.0 standards, including Errata 029 ● Cable is shielded to protect against EMI/RFI Specifications OVERVIEW UPC Code 037332118134 Technology SATA/eSATA PHYSICAL Color Red Cable Jacket Color Red Cable Outer Diameter (OD) 2.4/8.0mm Wire Gauge (AWG) 26 Cable Length (ft.) 1.6 1/2 19-in. Serial ATA (SATA) Latching Signal Cable 7Pin/7Pin, Straight/Straight Cable Length (m) 0.49 Cable Length (in.) 18 Cable Length (cm) 45.72 Shipping Dimensions (hwd / in.) 5.30 x 3.90 x 0.50 Shipping Dimensions (hwd / cm) 13.46 x 9.91 x 1.27 Shipping Weight (lbs.) 0.14 Shipping Weight (kg) 0.06 CONNECTIONS Side A - Connector 1 7 PIN SATA (MALE) Side B - Connector 1 7 PIN SATA (MALE) FEATURES & SPECIFICATIONS IP68 Rated No IP20 Rated No STANDARDS & COMPLIANCE Product Compliance RoHS WARRANTY Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice. Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies: https://www.tripplite.com/products/product-certification-agencies 2/2
P940-19I 价格&库存
很抱歉,暂时无法提供与“P940-19I”相匹配的价格&库存,您可以联系我们找货
P940-19I
  • 1+54.219161+7.04832
