Serial ATA (SATA) Latching Signal Cable 7Pin
(M/M), 8-in. (20.32 cm)
MODEL NUMBER: P940-08I
Highlights
Connect your high-speed Serial
ATA device to a Serial ATA
controller
Support data transfer rates of up
to 6.0 Gbps ( SATA II )
Cable is shielded to protect
against EMI/RFI
Applications
controller
Compatible with Serial ATA
Hard Drives, Blu-ray/DVD/CD
Drives and other Serial ATA
devices
System Requirements
Serial ATA device
Serial ATA controller
Package Includes
Features
Connect your high-speed Serial ATA device to a Serial ATA controller
Compatible with Serial ATA Hard Drives, Blu-ray/DVD/CD Drives and other Serial ATA devices
Metal latches ensure secure connections
Support data transfer rates of up to 6.0 Gbps
Narrow cables design simplifies cable routing and installation and improves air flow within CPU (no
more big ribbons blocking air movement)
Meets Serial ATA 1.0 standards, including Errata 029
Cable is shielded to protect against EMI/RFI
Specifications
OVERVIEW
UPC Code
037332140999
Technology
SATA/eSATA
PHYSICAL
Color
Red
Cable Jacket Color
Red
Cable Outer Diameter (OD)
2.4/8.0mm
Wire Gauge (AWG)
26
Cable Length (ft.)
0.7
1/2
P940-08I Latching Serial ATA
Signal Cable - 8 in.
Cable Length (m)
0.21
Cable Length (in.)
8
Cable Length (cm)
20.32
Shipping Dimensions (hwd / in.)
5.30 x 3.90 x 0.50
Shipping Dimensions (hwd / cm)
13.46 x 9.91 x 1.27
Shipping Weight (lbs.)
0.14
Shipping Weight (kg)
0.06
CONNECTIONS
Side A - Connector 1
7 PIN SATA (MALE)
Side B - Connector 1
7 PIN SATA (MALE)
FEATURES & SPECIFICATIONS
IP68 Rated
No
IP20 Rated
No
STANDARDS & COMPLIANCE
Product Compliance
RoHS; EIA/ECA-310-E
WARRANTY
Product Warranty Period
(Worldwide)
Lifetime limited warranty
© 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does
not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice.
Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies:
https://www.tripplite.com/products/product-certification-agencies
2/2
很抱歉,暂时无法提供与“P940-08I”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+4.887511+0.59140
