P943-19I
P943-19I
    TRIPPLITE
    P943-19I
P943-19I 数据手册
Serial ATA (SATA) Right Angle Signal Cable (7Pin-Up/7Pin-Down), 19-in. MODEL NUMBER: P943-19I Highlights ● Connect your high-speed Serial ATA device to a Serial ATA controller ● Support data transfer rates of up to 6.0 Gbps ● Cable is shielded to protect against EMI/RFI System Requirements ● Serial ATA device ● Serial ATA controller Package Includes ● Description Tripp Lite expands its line of hard drive cables with the introduction of our new line of serial ATA cables. The signal cables connect any high speed Serial ATA device to a Serial ATA controller. Serial ATA delivers two significant benefits: it support much higher data transfer rates (up to 6.0 Gbps...backward compatible to 1.5Gbps) and the narrow cable design helps improve internal air flow. Perfect for the desktop or server that has multiple drives. These cables feature 7-pin right-angle key up/7-pin right-angle key down female connectors and offer easy installation. Features ● Connect your high-speed Serial ATA device to a Serial ATA controller ● Support data transfer rates of up to 6.0 Gbps ● Narrow cables design: 1) simplifies cable routing and installation 2) improves air flow within CPU (no more big ribbons blocking air movement) 3)Right Angle design for tight spaces ● Meets Serial ATA 1.0 standards, including Errata 029 ● Cable is shielded to protect against EMI/RFI Specifications OVERVIEW UPC Code 037332120083 Technology SATA/eSATA PHYSICAL Color Red Cable Length (ft.) 1.6 Cable Length (m) 0.49 1/2 19-in. Serial ATA Right Angle (SATA) Signal Cable 7Pin/7Pin, Up/Down Cable Length (in.) 19 Cable Length (cm) 48.26 Shipping Dimensions (hwd / in.) 9.00 x 7.00 x 0.50 Shipping Dimensions (hwd / cm) 22.86 x 17.78 x 1.27 Shipping Weight (lbs.) 0.03 Shipping Weight (kg) 0.01 CONNECTIONS Side A - Connector 1 7 PIN SATA (MALE) - RIGHT ANGLE UP Side B - Connector 1 7 PIN SATA (MALE) - RIGHT ANGLE DOWN WARRANTY Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice. Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies: https://www.tripplite.com/products/product-certification-agencies 2/2
P943-19I 价格&库存
很抱歉,暂时无法提供与“P943-19I”相匹配的价格&库存,您可以联系我们找货
