Internal SAS Cable, 4-in-1 32Pin (SFF-8484) to 4 x
7pin Cable, 20-in. (0.5M)
MODEL NUMBER: S502-20N
Highlights
32-pin SFF-8484 to 4 x 7-pin
internal SAS cable
Supports data rates of up to
6.0Gbs
Straight backshell configuration
0.5 meter in length ( 20 inch )
System Requirements
SAS Host Bus Adapter and
Backplane with SFF-8484
mating connector
Package Includes
Description
Tripp Lite's 32-pin SFF-8484 to 4 x 7-pin internal SAS cable (Serial Attached SCSI) cable is ideal for
connecting SAS controllers to individual SAS/SATA disk drives. High-performance cable provides
differential pair signaling with less than 5ps/m in pair skew, improved EMI protection, and 3.0Gbs data
rate with rates up to 6.0Gbs. Thinner, flexible cable enables more efficient routing, with improved airflow
and thermal mechanics. Configuration of storage devices is simplified. Tripp Lite SAS assemblies are
RoHS compliant and feature a lifetime warranty.
Features
SFF-8484 to 4 x 7pin SAS Cable - 0.5 meter ( 20inch )
Supports data rates up to 6.0Gbs
Thin, flexible cable for easy routing and increased airflow
RoHS Compliant
Specifications
OVERVIEW
UPC Code
037332149961
Technology
SAS; Ribbon/Internal
PHYSICAL
Color
Red
Cable Jacket Color
Red
Cable Length (ft.)
1.7
Cable Length (m)
0.52
1/2
0.5-Meter ( 20 inch ) Internal
SAS 4-in-1 SFF-8484 to 4 x 7pin
Cable
Shipping Dimensions (hwd / in.)
0.25 x 6.30 x 9.60
Shipping Dimensions (hwd / cm)
0.64 x 16.00 x 24.38
Shipping Weight (lbs.)
0.10
Shipping Weight (kg)
0.05
CONNECTIONS
Side A - Connector 1
SFF-8484
Side B - Connector 1
7 PIN SATA (MALE)
WARRANTY
Product Warranty Period
(Worldwide)
Lifetime limited warranty
© 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does
not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice.
Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies:
https://www.tripplite.com/products/product-certification-agencies
2/2
很抱歉,暂时无法提供与“S502-20N”相匹配的价格&库存,您可以联系我们找货
