Internal SAS Cable, 4-in-1 32Pin (SFF-8484) to
32Pin (SFF-8484) Cable, 1M (3-ft.)
MODEL NUMBER: S500-01M
Highlights
32-pin SFF-8484 to SFF-8484
Internal SAS Cable
Supports data rates up to
6.0Gbs
Straight backshell configuration
System Requirements
SAS Host Bus Adapter and
Backplane with SFF-8484
mating connector
Package Includes
Description
Tripp Lite's 32-pin SFF-8484 to SFF-8484 Internal SAS (Serial Attached SCSI) cable is ideal for use with
SAS controllers to SAS disk drive back planes. High-performance cable provides differential pair signaling
with less than 5ps/m in pair skew, improved EMI protection, and 3.0Gbs data rate with rates up to 6.0Gbs.
Thinner, flexible cable enables more efficient routing, with improved airflow and thermal mechanics.
Configuration of storage devices is simplified. Tripp Lite's SAS assemblies are RoHS compliant and
feature a
Features
Internal SAS 4-in-1 SFF-8484 to SFF-8484 Cable - 1 meter
Supports data rates of up to 6.0Gbs
Thin, flexible cable for easy routing and increased airflow
RoHS compliant
Specifications
OVERVIEW
UPC Code
037332138132
PHYSICAL
Color
Black
Cable Length (ft.)
3
Cable Length (m)
0.91
Shipping Dimensions (hwd / in.)
9.00 x 7.00 x 0.50
Shipping Dimensions (hwd / cm)
22.86 x 17.78 x 1.27
1/2
1-Meter Internal SAS 4-in-1
Shipping Weight (lbs.)
0.35
Shipping Weight (kg)
0.16
CONNECTIONS
Side A - Connector 1
SFF-8484
Side B - Connector 1
SFF-8484
WARRANTY
Product Warranty Period
(Worldwide)
Lifetime limited warranty
© 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does
not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice.
Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies:
https://www.tripplite.com/products/product-certification-agencies
2/2
很抱歉,暂时无法提供与“S500-01M”相匹配的价格&库存,您可以联系我们找货
