1000 Eaton Boulevard
Cleveland, OH 44122
United States
SFP+ 10GBASE-CU Passive Twinax Copper
Cable, SFP-H10GB-CU50CM Compatible, Black,
20-in. (50.8 cm)
MODEL NUMBER: N280-20N-BK
Highlights
20-in. (50.8 cm) 30 AWG SFP+
high-speed passive copper
cable for 10G Ethernet
applications
Complies with MSA SFF-8431
specs
Equivalent to Cisco SFPH10GB-CU1-5M
An excellent low-cost alternative
to fiber optic cabling
System Requirements
Conforms to SFF-8431
standards and can be used with
manufacturers' equipment open
to third-party cables, including
ARISTA, BROADCOM, CISCO,
DELL, EMC, EMULEX,
EXTREME, FINISAR, IBM,
JUNIPER, QLOGIC and
VOLTAIRE
Confirmed equipment list (with
updated firmware and software):
CISCO NEXUS, CISCO
CATALYST, CISCO CATALYST
3750x, CISCO CATALYST
2960, CISCO CATALYST 3500,
CISCO CATALYST 3550,
CISCO NEXUS 5010, ARISTA
70505-64, QUANTA T3048,
EXTREME X250E, JUNIPER
EX3200
Not compatible with third-party
cables: HP, BROCADE
Features
20-in. (50.8 cm) 30 AWG SFP+ high-speed passive copper cable is fully compliant to MSA SFF-8431
specification
Supports 1x, 2x, 4x and 8x Fiber Channel data rates
Low-power equivalence to Cisco SFP-H10GB-CU1-5M
Ideal for 10G Ethernet and Fibre Channel applications
100-ohm twinaxial cable with die-cast metal shells and pull-tab latches
Package Includes
Specifications
OVERVIEW
UPC Code
037332178213
Product Type
Passive
PHYSICAL
Color
Black
Cable Jacket Color
Black
1/3
N280-20N-BK SFP+ HighSpeed Passive Copper Cable,
10 Gbps, 30 AWG, Black, 20-in.
(50.8 cm)
Cleveland, OH 44122
United States
Cable Jacket Material
PVC
Cable Outer Diameter (OD)
4.2mm
Wire Gauge (AWG)
30
Cable Length (ft.)
1.7
Cable Length (m)
0.52
Cable Length (in.)
19.68
Cable Length (cm)
49.9872
Minimum Bend Radius
23mm
Shipping Dimensions (hwd / in.)
12.00 x 10.50 x 0.50
Shipping Dimensions (hwd / cm)
30.48 x 26.67 x 1.27
Shipping Weight (lbs.)
0.18
Shipping Weight (kg)
0.08
ENVIRONMENTAL
Operating Temperature Range
0 to +70
Storage Temperature Range
-20 to +85
Operating Humidity Range
5% to 85% RH
Storage Humidity Range
5% to 85% RH
COMMUNICATIONS
Network Compatibility
10 Gbps
IEEE Standards Supported
802.3BA
CONNECTIONS
Side A - Connector 1
SFP+ (MALE)
Side B - Connector 1
SFP+ (MALE)
STANDARDS & COMPLIANCE
Product Compliance
RoHS
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
Lifetime limited warranty
2/3
Cleveland, OH 44122
United States
© 2022 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“N280-20N-BK”相匹配的价格&库存,您可以联系我们找货
