1000 Eaton Boulevard
Cleveland, OH 44122
United States
SFP+ 10Gbase-CU Passive Twinax Copper Cable,
SFP-H10GB-CU1-5M Compatible, Black, 5 ft.
(1.52 m)
Highlights
1.5 m. (5 ft.) 30AWG SFP+ High
Speed Passive Copper 10Gbps
Cable
Fully compliant to MSA SFF8431 specification
Equivalent to Cisco SFPH10GB-CU1-5M
Low Cost alternative to Fiber
Optic
MODEL NUMBER: N280-005-BK
System Requirements
Tripp Lite SFP+ Direct Attach
Cable ( DAC ) Twinaxial cables
conform to SFF-8431 standards,
and as such can be used with the
following manufacturers equipment
that are open to 3rd party cables:
QLOGIC * EMULEX * JUNIPER *
ARISTA * IBM * DELL * EXTREME
EMC * BROADCOM * FINISAR *
Features
VOLTAIRE * CISCO
1.5 m. (5 ft.) 30Awg SFP+ High Speed Passive Copper 10Gbps Cable
Fully compliant to MSA SFF-8431 specification
Equivalent to Cisco SFP-H10GB-CU1-5M (See the Support tab on this web page for additional cross
references)
Use in 10Gbps Ethernet and Fibre Channel applications
software is installed )
100ohm Twinaxial cable, Diecast metal shells, pull-to-release latching
CISCO NEXUS *
Support for 1x, 2x, 4x and 8x Fiber Channel data rates
CISCO CATALYST *
Hot-Pluggable SFP 20PIN footprint
CISCO CATALYST 3750x
Low power consumption
CISCO CATALYST 2960
CONFIRMED EQUIPMENT LIST (
*ensure the latest firmware and
CISCO CATALYST 3500
CISCO CATALYST 3550
CISCO NEXUS 5010
ARISTA 70505-64
QUANTA T3048
EXTREME X250E
JUNIPER EX3200
NOT COMPATIBLE TO 3RD
PARTY CABLES: HP and
BROCADE
Package Includes
1/3
Cleveland, OH 44122
United States
Cable
Specifications
OVERVIEW
UPC Code
037332178138
Product Type
Passive
PHYSICAL
Color
Black
Cable Jacket Color
Black
Cable Jacket Material
PVC
Cable Outer Diameter (OD)
4.2mm
Wire Gauge (AWG)
30
Cable Length (ft.)
5
Cable Length (m)
1.52
Cable Length (in.)
60
Cable Length (cm)
152.4
Minimum Bend Radius
23mm
Shipping Dimensions (hwd / in.)
12.00 x 10.50 x 0.50
Shipping Dimensions (hwd / cm)
30.48 x 26.67 x 1.27
Shipping Weight (lbs.)
0.24
Shipping Weight (kg)
0.11
ENVIRONMENTAL
Operating Temperature Range
0 to +70
Storage Temperature Range
-20 to +85
Operating Humidity Range
5% to 85% RH
Storage Humidity Range
5% to 85% RH
COMMUNICATIONS
Network Compatibility
10 Gbps
IEEE Standards Supported
802.3BA
CONNECTIONS
Side A - Connector 1
SFP+ (MALE)
2/3
Cleveland, OH 44122
United States
Side B - Connector 1
SFP+ (MALE)
STANDARDS & COMPLIANCE
Product Compliance
RoHS
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
Lifetime limited warranty
© 2022 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“N280-005-BK”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+507.699511+65.80753
