N280-03M-BK
N280-03M-BK
    TRIPPLITE
    N280-03M-BK
N280-03M-BK 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States SFP+ 10Gbase-CU Passive Twinax Copper Cable, SFP-H10GB-CU3M Compatible, Black, 3M (9.84 ft.) Highlights ● 3M (9.84-ft.) Black 30AWG SFP+ High Speed Passive Copper 10Gbps Cable ● Fully compliant to MSA SFF8431 specification ● Equivalent to Cisco SFPH10GB-CU3M (See the Support tab on this web page for additional cross references) ● Low Cost alternative to Fiber Optic MODEL NUMBER: N280-03M-BK System Requirements Tripp Lite SFP+ Direct Attach Cable ( DAC ) Twinaxial cables conform to SFF-8431 standards, and as such can be used with the following manufacturers equipment that are open to 3rd party cables: QLOGIC * EMULEX * JUNIPER * Features ARISTA * IBM * DELL * EXTREME ● 3 m. (10 ft.) Black 30Awg SFP+ High Speed Passive Copper 10Gbps Cable EMC * BROADCOM * FINISAR * ● Fully compliant to MSA SFF-8431 specification VOLTAIRE * CISCO ● Equivalent to Cisco SFP-H10GB-CU3M ● Use in 10Gbps Ethernet and Fibre Channel applications CONFIRMED EQUIPMENT LIST ( ● 100ohm Twinaxial cable, Diecast metal shells, pull-to-release latching *ensure the latest firmware and ● Support for 1x, 2x, 4x and 8x Fiber Channel data rates software is installed ) ● Hot-Pluggable SFP 20PIN footprint CISCO NEXUS * ● Low power consumption CISCO CATALYST * CISCO CATALYST 3750x CISCO CATALYST 2960 CISCO CATALYST 3500 CISCO CATALYST 3550 CISCO NEXUS 5010 ARISTA 70505-64 QUANTA T3048 EXTREME X250E JUNIPER EX3200 NOT COMPATIBLE TO 3RD PARTY CABLES: HP and BROCADE Package Includes 1/3 1000 Eaton Boulevard Cleveland, OH 44122 United States ● Specifications OVERVIEW UPC Code 037332178152 Product Type Passive PHYSICAL Color Black Cable Jacket Color Black Cable Jacket Material PVC Cable Outer Diameter (OD) 4.2mm Wire Gauge (AWG) 30 Cable Length (ft.) 9.8 Cable Length (m) 2.99 Cable Length (in.) 117.6 Cable Length (cm) 298.704 Minimum Bend Radius 23mm Shipping Dimensions (hwd / in.) 17.00 x 14.00 x 0.50 Shipping Dimensions (hwd / cm) 43.18 x 35.56 x 1.27 Shipping Weight (lbs.) 0.33 Shipping Weight (kg) 0.15 ENVIRONMENTAL Operating Temperature Range 0 to +70 Storage Temperature Range -20 to +85 Operating Humidity Range 5% to 85% RH Storage Humidity Range 5% to 85% RH COMMUNICATIONS Network Compatibility 10 Gbps IEEE Standards Supported 802.3BA CONNECTIONS 2/3 3 m. (10 ft.) Black 30Awg SFP+ High Speed Passive Copper 10Gbps Cable 1000 Eaton Boulevard Cleveland, OH 44122 United States Side A - Connector 1 SFP+ (MALE) Side B - Connector 1 SFP+ (MALE) STANDARDS & COMPLIANCE Product Compliance RoHS WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
N280-03M-BK 价格&库存
很抱歉,暂时无法提供与“N280-03M-BK”相匹配的价格&库存,您可以联系我们找货
