N282-20N-BK
N282-20N-BK
    TRIPPLITE
    DACCOPPERINFINIBANDCABLE
N282-20N-BK 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States QSFP+ to QSFP+ 40Gb Passive DAC Copper Infiniband Cable, 0.5M (20-in.) MODEL NUMBER: N282-20N-BK Highlights ● 40Gbps QSFP+ to QSFP+ 0.5M (20-in.) patch cable ● Meets or Exceeds 40-Gigabit Ethernet 40GBASE-CR4 standards ● Fully compliant to the latest QSFP+ MSA (Multi Source Agreement) ● SDR, DDR, and QDR Compatible System Requirements ● Networking Switch or other hardware with open QSFP+ Port(s) Package Includes ● Features ● 0.5M (20-in.) QSFP+ tp QSFP+ 40Gb Passive DAC Copper Infiniband cable ● Meets or Exceeds strict 40-Gigabit Ethernet 40GBase-CR4 standards ● SDR, DDR, and QDR Compatible ● QSFP+ to QSFP+ 30AWG SFF-8436 compliant cable and connector ● Up to 10.3125 Gbps transfer rate per channel ( 40Gb aggregate ) ● Multi-platform support for 40Gb, SAS, Fibre Channel, and SONET ● Zinc die-cast QSFP+ connectors with "Pull-to-Release" latching ● Fully compliant to latest QSFP+ MSA ( Multi Source Agreement ) ● Lower port cost and reduced power budget vs Fiber Optics ● RoHS, SFF-8436, and IEEE 802.3ba Compliant ● BER better than 10¹² Specifications OVERVIEW UPC Code 037332186096 Product Type Passive PHYSICAL Color Black Cable Jacket Color Black Cable Jacket Material PVC 1/2 0.5M (20-in.) QSFP+ to QSFP+ High Speed Passive Copper 40GB Cable 1000 Eaton Boulevard Cleveland, OH 44122 United States Cable Outer Diameter (OD) 6.5mm Wire Gauge (AWG) 30 Cable Length (ft.) 1.7 Cable Length (m) 0.52 Cable Length (in.) 20 Cable Length (cm) 50.80 Minimum Bend Radius 38mm Shipping Dimensions (hwd / in.) 12.00 x 10.50 x 0.50 Shipping Dimensions (hwd / cm) 30.48 x 26.67 x 1.27 Shipping Weight (lbs.) 0.23 Shipping Weight (kg) 0.10 ENVIRONMENTAL Operating Temperature Range 0 to +70 Storage Temperature Range -20 to +85 Operating Humidity Range 5% to 85% RH Storage Humidity Range 5% to 85% RH COMMUNICATIONS Network Compatibility 40 Gbps IEEE Standards Supported 802.3BA CONNECTIONS Side A - Connector 1 QSFP+ (MALE) Side B - Connector 1 QSFP+ (MALE) STANDARDS & COMPLIANCE Product Compliance MSA SFF-8436; RoHS WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 2/2
N282-20N-BK 价格&库存
很抱歉,暂时无法提供与“N282-20N-BK”相匹配的价格&库存,您可以联系我们找货
