N280-06M-BK
N280-06M-BK
    TRIPPLITE
    TWINAXPASSCOPPERCABLEBLK20'
N280-06M-BK 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States SFP+ 10GBase-CU Passive Twinax Copper Cable, SFP-H10GB-CU5M Compatible, Black, 6M (19.68 ft.) Highlights ● 6M (19.68-ft.) Black 24AWG SFP+ High Speed Passive Copper 10Gbps Cable ● Fully compliant to MSA SFF8431 specification ● Equivalent to Cisco SFPH10GB-CU1-5M ● Low-cost alternative to Fiber Optic MODEL NUMBER: N280-06M-BK System Requirements Tripp Lite SFP+ Direct Attach Cable ( DAC ) Twinaxial cables conform to SFF-8431 standards, and as such can be used with the following manufacturers equipment that are open to 3rd party cables: QLOGIC * EMULEX * JUNIPER * ARISTA * IBM * DELL * EXTREME EMC * BROADCOM * FINISAR * Features VOLTAIRE * CISCO ● 6M (19.68-ft.) Black 24Awg SFP+ High Speed Passive Copper 10Gbps Cable ● Fully compliant to MSA SFF-8431 specification ● Equivalent to Cisco SFP-H10GB-CU1-5M (See the Support tab on this web page for additional cross references) ● Use in 10Gbps Ethernet and Fibre Channel applications software is installed ) ● 100ohm Twinaxial cable, Diecast metal shells, pull-to-release latching CISCO NEXUS * ● Support for 1x, 2x, 4x and 8x Fiber Channel data rates CISCO CATALYST * ● Hot-Pluggable SFP 20PIN footprint CISCO CATALYST 3750x ● Low power consumption CISCO CATALYST 2960 CONFIRMED EQUIPMENT LIST ( *ensure the latest firmware and CISCO CATALYST 3500 CISCO CATALYST 3550 CISCO NEXUS 5010 ARISTA 70505-64 QUANTA T3048 EXTREME X250E JUNIPER EX3200 NOT COMPATIBLE TO 3RD PARTY CABLES: HP and BROCADE Package Includes ● 1/3 6M (19.68-ft.) Black 24Awg SFP+ High Speed Passive 1000 Eaton Boulevard Cleveland, OH 44122 United States Copper 10Gbps Cable Specifications OVERVIEW UPC Code 037332178183 Product Type Passive PHYSICAL Color Black Cable Jacket Color Black Cable Jacket Material PVC Cable Outer Diameter (OD) 6.0mm Wire Gauge (AWG) 24 Cable Length (ft.) 19.7 Cable Length (m) 6.01 Cable Length (in.) 236.4 Cable Length (cm) 600.456 Minimum Bend Radius 35mm Shipping Dimensions (hwd / in.) 17.00 x 14.00 x 0.50 Shipping Dimensions (hwd / cm) 43.18 x 35.56 x 1.27 Shipping Weight (lbs.) 0.84 Shipping Weight (kg) 0.38 ENVIRONMENTAL Operating Temperature Range 0 to +70 Storage Temperature Range -20 to +85 Operating Humidity Range 5% to 85% RH Storage Humidity Range 5% to 85% RH COMMUNICATIONS Network Compatibility 10 Gbps IEEE Standards Supported 802.3BA CONNECTIONS Side A - Connector 1 SFP+ (MALE) 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Side B - Connector 1 SFP+ (MALE) STANDARDS & COMPLIANCE Product Compliance RoHS WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
N280-06M-BK 价格&库存
很抱歉,暂时无法提供与“N280-06M-BK”相匹配的价格&库存,您可以联系我们找货
