N281-03M-BK
N281-03M-BK
    TRIPPLITE
    DACCOPPERINFINIBANDCABLE
N281-03M-BK 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States QSFP+ to 10 GbE SFP+ Passive DAC Breakout Cable (M/M), QSFP+ to (x4) SFP+, Compatible to Cisco QSFP-4SFP10G-CU3M, 3M (9.84 ft.) MODEL NUMBER: N281-03M-BK Highlights ● Supports serial data rates up to 40 Gbps ● Complies with MSA SFF-8431 and SFF-8436 specifications ● Compatible to Cisco QSFP4SFP10G-CU3M ● SDR, DDR and QDR compatible ● Zinc die-cast QSFP+ and SFP+ male connectors ● Pull-tab ejectors for quick, easy connections System Requirements ● Networking switch or other hardware with open QSFP+ ports Package Includes ● Connects and distributes your 40 GbE system directly into four 10 GbE servers, switches and/or adapters. Features Splits a 40 GbE Network System to Four 10 GbE Servers, Switches and/or Adapters ● Ideal for data centers, high-end servers and enterprise wiring closets ● Lower port cost and power budget when compared to fiber optics ● Multi-platform support for 40GBASE-CR4, 10GBASE-CR4, 6G SAS, Fibre Channel and SONET Top-of-the-Line Construction ● Zinc die-cast male connectors for superior EMI resistance ● Ergonomic pull-tab ejectors for quick, easy connections ● 8-pair wire technology optimized for bandwidth-intense applications ● Flexible 30 AWG conductors maintain smooth high-frequency response Fully Compliant and Compatible ● Compatible with SDR, DDR and QDR ● Compatible with all QSFP and QSRP+ ports ● Complies with latest MSA (Multi-Source Agreement) SFF-8431 and SFF-8436 architecture ● Compatible to Cisco QSFP-4SFP10G-CU3M Specifications OVERVIEW UPC Code 037332193124 1/3 N281-03M-BK 40 GbE QSFP+ to 10 GbE SFP+ Passive DAC Copper Breakout Cable (M/M), 3 m (10 ft.) 1000 Eaton Boulevard Cleveland, OH 44122 United States Product Type Passive PHYSICAL Color Black Cable Jacket Color Black Cable Jacket Material PVC Cable Outer Diameter (OD) 4.2mm Wire Gauge (AWG) 30 Cable Length (ft.) 9.8 Cable Length (m) 2.99 Cable Length (in.) 117.6 Cable Length (cm) 298.704 Minimum Bend Radius 23mm Shipping Dimensions (hwd / in.) 17.00 x 14.00 x 0.50 Shipping Dimensions (hwd / cm) 43.18 x 35.56 x 1.27 Shipping Weight (lbs.) 1.10 Shipping Weight (kg) 0.50 ENVIRONMENTAL Operating Temperature Range 0 to +70 Storage Temperature Range -20 to +85 Operating Humidity Range 5% to 85% RH Storage Humidity Range 5% to 85% RH COMMUNICATIONS Network Compatibility 40 Gbps IEEE Standards Supported 802.3BA CONNECTIONS Side A - Connector 1 QSFP+ (MALE) Side B - Connector 1 (4) SFP+ (MALE) STANDARDS & COMPLIANCE Product Compliance MSA SFF-8431; MSA SFF-8436; RoHS; REACH WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
N281-03M-BK 价格&库存
很抱歉,暂时无法提供与“N281-03M-BK”相匹配的价格&库存,您可以联系我们找货
