N282-03M-28-BK
N282-03M-28-BK
    TRIPPLITE
    N282-03M-28-BK
N282-03M-28-BK 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States QSFP28 to QSFP28 100GbE Passive DAC Cable (M/M), QSFP-100G-CU3M Compatible, 3M (9.84 ft.) MODEL NUMBER: N282-03M-28-BK Highlights ● Supports serial data rates up to 100 Gbps ● Complies with MSA SFF-8665 specifications ● Compatible to Cisco QSFP100G-CU3M ● Meets or exceeds 100GBASECR4 standards ● Multi-platform support for 128G Fibre Channel and EDR InfiniBand ● Pull-tab ejectors for quick, easy connections System Requirements ● Networking switch or other hardware with open QSFP+ ports Package Includes ● Combines four SFP channels operating at up to 28 Gpbs into one affordable 100GbE cable. Ideal for data centers, high-end servers and enterprise wiring closets. Features Connect Network Equipment at Speeds Up to 100 Gbps ● Combines four 28 Gbps SFP channels into single high-density cable ● Ideal for data centers, high-end servers and enterprise wiring closets ● Multi-platform support for 128G Fibre Channel and EDR InfiniBand ● Lower port cost and power budget when compared to fiber optics Top-of-the-Line Construction ● 100 GbE 38-position “board-as-connector” design ● Zinc die-cast male QSFP+ connectors for superior EMI resistance ● Ergonomic pull-tab ejectors for quick, easy connections ● 8-pair wire technology optimized for bandwidth-intense applications ● Flexible 26 AWG conductors maintain smooth high-frequency response Fully Compliant and Compatible ● Meets or exceeds strict 100-Gigabit Ethernet (100GBASE-CR4) standards ● Complies with IEEE 802.3bj and RoHS ● Complies with latest QSFP28 MSA (Multi-Source Agreement) SFF-8665 architecture ● Compatible with all QSFP and QSRP+ ports ● Compatible to Cisco QSFP-100G-CU3M Specifications 1/3 N282-03M-28-BK QSFP28 to QSFP28 100GbE Passive DAC Copper InfiniBand Cable (M/M), 3 m (10 ft.) 1000 Eaton Boulevard Cleveland, OH 44122 United States OVERVIEW UPC Code 037332193162 Product Type Passive PHYSICAL Color Black Cable Jacket Color Black Cable Jacket Material PVC Cable Outer Diameter (OD) 9.5mm Wire Gauge (AWG) 26 Cable Length (ft.) 9.8 Cable Length (m) 2.99 Cable Length (in.) 117.6 Cable Length (cm) 298.704 Minimum Bend Radius 50mm Shipping Dimensions (hwd / in.) 17.00 x 14.00 x 0.50 Shipping Dimensions (hwd / cm) 43.18 x 35.56 x 1.27 Shipping Weight (lbs.) 0.86 Shipping Weight (kg) 0.39 ENVIRONMENTAL Operating Temperature Range 0 to +70 Storage Temperature Range -20 to +85 Operating Humidity Range 5% to 85% RH Storage Humidity Range 5% to 85% RH COMMUNICATIONS Network Compatibility 100 Gbps IEEE Standards Supported 802.3bj CONNECTIONS Side A - Connector 1 QSFP+ (MALE) Side B - Connector 1 QSFP+ (MALE) STANDARDS & COMPLIANCE Product Compliance MSA SFF-8665; RoHS; IEEE 802.3bj; REACH 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
N282-03M-28-BK 价格&库存
很抱歉,暂时无法提供与“N282-03M-28-BK”相匹配的价格&库存,您可以联系我们找货
