LX40-16P
LX40-16P
    HRS(广濑)
LX40-16P 数据手册
Ultra Low-profile Interface Connectors with 2.0mm Mounting Height LX Series ■Overview ■ Features Lower Profile 1. Low profile on the PCB 2. Strong Construction Use of metal shell guarantees that fully mated connectors will withstand 30N max. force applied on the plug in any direction. (Fig.2) 3. High contact reliability Bellows contact with long mating stroke provides highly reliable mating as well as soft insertion feeling. Mating durability is up to 5,000 times long. 2 When mounted on the PCB surface the receptacle height is 2.0mm. (Fig.1) 2.9 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. LX Series is a super low profile interface connector with sequential mating design and friction lock, which has been developed for low profile mobile terminals. This connenctor features ESD problem prevention in 0.5mm terminal pitch and 2.0mm small and low profile design, which makes it suitable to small mobile devices. Existing 3200 Series LX Series Fig.1 Strong Construction 30N 4. Sequenced contact mating The protection of the circuit is assured by having the 2 contact at each end of the receptacle are longer by 0.5mm, with electrical wipe of 1.45mm. Location of the circuit protection contacts can be changed as required. Remaining contacts electrical wipe is 0.95mm. 30N 5. Incorrect Insertion Prevention Connectors will not be damaged when angled or reverse plug insertion is attempted. (Fig.3) 6. Safety plug release Fig.2 Incorrect insertion prevention Plug will release when an excessive pull force is applied to the cable. 7. RoHS Compliant All materials and substances used to produce this product comply with RoHS standards. ■ Applications DSC, Tablet device, thin electronic equipment, mobile phones and other portable devices requiring high durability interface connectors. Angled insertion In cases where the application will demand a high level of reliability, such as automotive, please contact a company representative for further information. Reversed insertion Fig.3 2019.7r 1 LX Series●Ultra Low-profile Interface Connectors with 2.0mm Mounting Height ■Product specifications Current rating 0.5A (1A max. can be carried via 2 random contacts) Ratings Voltage rating 50V AC Characteristic Storage temperature range : – 55ç to +85ç Specification Conditions 1.Contact resistance 70mø max. 2.Insulation resistance 3.Withstanding voltage 100mA DC 1000Mø min. (dry) 100V DC 10Mø min. (high humidity) No flashover or insulation breakdown. 250V AC / 1 minute 4.Mating/un-mating forces Mating : 10N max., un-mating : 4N min. 5. Durability (mating/n-mating) Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Operating temperature range : – 40ç to +70ç 6. Shock 7. Vibration 8. Temperature cycle 9. Salt spray With corresponding connector. Amount of change of contact resistance : 20mø max. 5,000 times No electrical discontinuity of 1µ sec. Max. Acceleration of 490 m/s2, 11 ms duration, Contact resistance : 20mø max. sine half-wave waveform, 3 cycles, 3 axis. Contact resistance : 20mø max. Frequency : 10 to 55 Hz, single amplitude of 0.75mm, Insulation resistance : 10Mø min. acceleration of 98 m/s2, 2 hours, 3 axis. Contact resistance : 20mø max. Temperature : – 55ç ➝ +5ç to +35ç ➝ +85ç ➝ +5ç to +35ç Insulation resistance : 10Mø min. Time No heavy corrosions 5% water solution at 35°C for 48 hours : 30 ➝ 2 to 3 ➝ 30 ➝ 2 to 3 min ■Materials / Finish ●Receptacles Component Insulator Material Synthetic resin Contacts Copper alloy Shell Stainless steel Component Insulator Material Synthetic resin Contacts Copper alloy Metal shield Covers Strain relief clamp Self tapping screws Stainless steel Synthetic resin Copper alloy Steel Finish/Color Black Contact area : Gold plated Mounting area : Gold flash plated Soldering area : Gold flash plated Remarks UL94V-0 Finish/Color Black Contact area : Gold plated Termination area : Gold flash plated -------------Black -------------Trivalent black chromate Remarks UL94V-0 --------------------------- ●Plugs ■Product Number Structure Refer to the chart below when determining the product specifications from the product number. Please select from the product numbers listed in this catalog when placing orders. ●Receptacles 1 Series number LX 60 - 16 S 1 2 3 : LX 2 Termination type 40 : Solder type 4 60 : Right angle SMT ●Plugs 3 Number of contacts : 12, 16, 20 4 Contact type LX 40 - 16 P 1 2 3 P : Male contact (Plug) 4 S : Female contact (Receptacle) ●Bushing 5 Bushing LX 40 - 16 BS(4.5) 1 2 2 3 5 BS(4.0) : Dia. 4.0mm cable BS(4.5) : Dia. 4.5mm cable BS(5.0) : Dia. 5.0mm cable --------------------------UL94V-0 -------------Screw size: M2 LX Series●Ultra Low-profile Interface Connectors with 2.0mm Mounting Height ■Receptacles ●12 pos. (5.5) 2.55 P=0.5 No.12 6.5 No.1 .5 2 R0 Ø1 0.8 4 10.6 3.6 245-0018-3 LX60-16S 245-0001-0 LX60-20S 245-0016-8 RoHS 2Ø1 .1 Ho le (5.5) P=0.5 0.35 1.2 LX60-12S Packaging 2,000 pcs/reel 5.7 HRS No. PCB edge 0.3 3.8 2.8 1.5 Part No. 4 6.5 7.8 1.9 1.9 No conductive traces in this area ●16 pos. 2.55 (9.5) P=0.5 2.55 P=0.5 6.5 No.1 .5 R0 (9.5) Ø1 .1 P=0.5 le No conductive traces in this area Land area 5.7 PCB edge 1.9 7 10.5 11.8 No conductive traces in this area 0.3 0.3 1.9 3.8 2.8 1.5 5.7 1.9 5 8.5 9.8 0.35 Ho le PCB edge Ø1 3.6 BRecommended PCB mounting pattern 2- 1.2 0.35 Ho 6.7 14.6 1.2 (7.5) P=0.5 0.8 Ø1 3.6 BRecommended PCB mounting pattern 2-Ø .5 R0 2 0.8 5 12.6 6.5 No.1 No.20 2 No.16 1.1 Land area ●20 pos. (7.5) 3.8 2.8 1.5 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. BRecommended PCB mounting pattern 1.9 Land area 3 LX Series●Ultra Low-profile Interface Connectors with 2.0mm Mounting Height ■Plugs Ø5 .9 ●12 pos. 8 14.8 (R 3.2 21.4 ) 5.1 ) 6.2 4 1. Part No. HRS No. LX40-12P 245-0019-6 LX40-16P 245-0002-3 LX40-20P 245-0017-0 Packaging RoHS No.1 ●20 pos. Ø6 .4 .9 ●16 pos. 8 16.8 (R 3. No.12 1 Ø6 (R 18.8 3. 8.4 8) 21.4 21.4 8) 5.1 1. No.1 4) 1. (R (R 5.5 No.16 No.1 6.2 4) 6.2 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. (R No.20 ■Bushing Part No. HRS No. LX40-12BS(4.0) 245-0020-5 LX40-16BS(4.5) 245-0021-8 LX40-20BS(5.0) 245-0022-0 Packaging RoHS 100 pcs/pack 4 LX Series●Ultra Low-profile Interface Connectors with 2.0mm Mounting Height Receptacle Packaging Specifications ●Embossed carrier tape dimensions ●Reel dimensions Unreeling directions C JcgZZa^c\Y^gZXi^dch B (% ¢-% .5 2 ¢(-% Ø1 1.75 4 A 9 >ch^YZY^bZch^dc (mm) Part No. B C 24 11.5 12 LX60-12S LX60-16S (mm) Part No. A D E 25.5 29.5 LX60-12S LX60-16S LX60-20S LX60-20S Receptacles Recommended Temperature Profile  This measurement is performed on the contact lead section. The temperature profile may vary due to external conditions such as the type of cream solder, manufacturer, and board size. Please contact the solder manufacturer for their specifications. * % E:6@/'*% '*% '(%b^c# '%% &-% &*% &*% .%¤(%h &%% (%¤&%h *% Applicable Plug Cable (mm) Part No. Cable diameter LX40-12P Ø4 max. LX40-16P Ø4.5 max. LX40-20P Ø5 max. Wire size Ø0.6mm max. (AWG#30 to 32 or equivalent) Note 1 : Applicable cable sizes are guidelines. (There may be slight differences depending on the cable outer insulation) Note 2 : Cables must be attached using single piece overmolded bushings on the cable. Note 3 : Please refer to applicable Cable Termination Procedures Manual for correct plug assembly and cable termination. BMated Condition Dimensions 2 Receptacle 1.4 Plug 0.5 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 4 ( ¢& : Djih^YZY^bZch^dc 2 (mm) 5 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. LX Series●Ultra Low-profile Interface Connectors with 2.0mm Mounting Height USA: HIROSE ELECTRIC (U.S.A.), INC. HEADQUARTERS CHICAGO OFFICE 2300 Warrenville Road, Suite 150, Downers Grove, IL 60515 Phone : +1-630-282-6700 http://www.hirose.com/us/ USA: HIROSE ELECTRIC (U.S.A.), INC. SAN JOSE OFFICE 2841 Junction Ave, Suite 200 San Jose, CA. 95134 Phone : +1-408-253-9640 Fax : +1-408-253-9641 http://www.hirose.com/us/ USA: HIROSE ELECTRIC (U.S.A.), INC. DETROIT OFFICE (AUTOMOTIVE) 17197 N. Laurel Park Drive, Suite 253, Livonia, MI 48152 Phone : +1-734-542-9963 Fax : +1-734-542-9964 http://www.hirose.com/us/ USA: HIROSE ELECTRIC (U.S.A.), INC. BOSTON OFFICE 300 Brickstone Square Suite 201, Andover, MA 01810 Phone : +1-978-662-5255 THE NETHERLANDS: HIROSE ELECTRIC EUROPE B.V. Hogehillweg #8 1101 CC Amsterdam Z-O Phone : +31-20-6557460 Fax : +31-20-6557469 http://www.hirose.com/eu/ GERMANY: HIROSE ELECTRIC EUROPE B.V. GERMAN BRANCH Schoenbergstr. 20, 73760 ostfildern Phone : +49-711-456002-1 Fax : +49-711-456002-299 http://www.hirose.com/eu/ GERMANY: HIROSE ELECTRIC EUROPE B.V. NUREMBERG OFFICE Neumeyerstrasse 22-26, 90411 Nurnberg Phone : +49-911 32 68 89 63 Fax : +49-911 32 68 89 69 http://www.hirose.com/eu/ GERMANY: HIROSE ELECTRIC EUROPE B.V. HANOVER OFFICE Bayernstr. 3, Haus C 30855 Langenhagen, Germany Phone : +49-511 97 82 61 30 Fax : +49-511 97 82 61 35 http://www.hirose.com/eu/ FRANCE: HIROSE ELECTRIC EUROPE B.V. PARIS OFFICE 130 Avenue Joseph Kessel, Bat E, 78960 Voisins le Bretonneux, France Phone : +33-1-85764886 Fax : +33-1-85764823 http://www.hirose.com/eu/ UNITED KINGDOM: HIROSE ELECTRIC EUROPE BV (UK BRANCH) 4 Newton Court, Kelvin Drive, Knowlhill, Milton Keynes, MK5 8NH Phone : +44-1908 202050 Fax : +44-1908 202058 http://www.hirose.com/eu/ CHINA: HIROSE ELECTRIC (CHINA) CO., LTD. (SHANGHAI, HEADQUARTERS) 18, Enterprise Center Tower 2, 209# Gong He Road, Jing’an District, Shanghai, CHINA 200070 Phone : +86-21-6391-3355 Fax : +86-21-6391-3335 http://www.hirose.com/cn/ CHINA: HIROSE ELECTRIC (CHINA) CO.,LTD. BEIJING BRANCH A1001, Ocean International Center, Building 56# East 4th Ring Middle Road, ChaoYang District, Beijing, 100025 Phone : +86-10-5165-9332 Fax : +86-10-5908-1381 http://www.hirose.com/cn/ CHINA: HIROSE ELECTRIC (CHINA) CO., LTD. SHENZHEN BRANCH Room 09-13, 19/F, Office Tower Shun Hing Square, Di Wang Commercial Centre, 5002 Shen Nan Dong Road, Shenzhen City, Guangdong Province, 518008 Phone : +86-755-8207-0851 Fax : +86-755-8207-0873 http://www.hirose.com/cn/ HONG KONG: HIROSE ELECTRIC HONGKONG TRADING CO., LTD. Room 1001, West Wing, Tsim Sha Tsui Centre, 66 Mody Road, Tsim Sha Tsui East, Kowloon, Hong Kong Phone : +852-2803-5338 Fax : +852-2591-6560 http://www.hirose.com/hk/ TAIWAN: HIROSE ELECTRIC TAIWAN CO., LTD. 103 8F, No.87, Zhengzhou Rd., Taipei Phone : +886-2-2555-7377 Fax : +886-2-2555-7355 http://www.hirose.com/tw/ KOREA: HIROSE KOREA CO.,LTD. 143, Gongdan 1-daero, Siheung-si, Gyeonggi-do, 15084, Korea Phone : +82-31-496-7000 Fax : +82-31-496-7100 http://www.hirose.co.kr/ SINGAPORE: INDIA: HIROSE ELECTRIC SINGAPORE PTE. LTD. DELHI LIAISON OFFICE HIROSE ELECTRIC SINGAPORE PTE. LTD. 03, Anson Road, #20-01, Springleaf Tower, Office NO.552, Regus-Green Boulevard, Level5, Tower C, Sec62, Plot B-9A, Block B, Noida, 201301, Uttar Pradesh, India Singapore 079909 Phone : +91-12-660-8018 Phone : +65-6324-6113 Fax : +91-120-4804949 Fax : +65-6324-6123 http://www.hirose.com/sg/ http://www.hirose.com/sg/ INDIA: HIROSE ELECTRIC SINGAPORE PTE. LTD. BANGALORE LIAISON OFFICE Unit No-403, 4th Floor, No-84, Barton Centre, Mahatma Gandhi (MG) Road, Bangalore 560 001, Karnataka, India Phone : +91-80-4120 1907 Fax : +91-80-4120 9908 http://www.hirose.com/sg/ MALAYSIA: THAILAND: PENANG REPRESENTATIVE OFFICE BANGKOK OFFICE (REPRESENTATIVE OFFICE) 73-3-1, Ideal@The One, Jalan Mahsuri, Bayan Unit 4703, 47th FL., 1 Empire Tower, South Sathorn Road, Yannawa, Sathorn, Bangkok 10120 Thailand Lepas Penang, 11950, Malaysia Phone : +66-2-686-1255 Phone : +604-648-5536 Fax : +66-2-686-3433 http://www.hirose.com/sg/ http://www.hirose.com/sg/ ® 6 2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN TEL: +81-45-620-3526 Fax: +81-45-591-3726 http://www.hirose.com http://www.hirose-connectors.com The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use. The contents of this catalog are current as of date of 07/2019. Contents are subject to change without notice for the purpose of improvements.
LX40-16P 价格&库存
很抱歉,暂时无法提供与“LX40-16P”相匹配的价格&库存,您可以联系我们找货
LX40-16P
  • 1+42.189231+5.23393
  • 10+38.3420110+4.75665
  • 25+36.3178425+4.50553
  • 50+35.4742650+4.40088
  • 100+33.78484100+4.19129
  • 250+29.56170250+3.66738
  • 450+28.71704450+3.56259
  • 950+24.49404950+3.03869
  • 2400+22.804782400+2.82912
库存:173
