N201-001-RD
N201-001-RD
    TRIPPLITE
    N201-001-RD
N201-001-RD 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Cat6 Gigabit Snagless Molded (UTP) Ethernet Cable (RJ45 M/M), PoE, Red, 1 ft. (0.31 m) Highlights ● Premium cabling for Category 6, Category 5e and Category 5 applications, rated for 550 MHz/1 Gbps communications ● Designed to meet Category 6 specifications; reduces crosstalk and return loss ● IEEE 802.3ab ● PVC 4-pair stranded UTP ● Features boots with integral strain-relief and RJ45 (Male) connectors MODEL NUMBER: N201-001-RD System Requirements For 1000 Base-T (1Gbps Ethernet), 10/100 Base-T (Ethernet), 100 Mbps TPDDI, 155 Mbps ATM, ISDN, voice and Token Ring TYPE 3 applications as well as EIA/TIA applications. Package Includes Features 1-ft. Cat6 Gigabit Red Snagless Molded Patch Cable ● Premium cabling for category 6, category 5e and category 5 applications ● Snagless design protects the locking tabs on the RJ45 connectors from being damaged or snapped off during installation ● Length: 1-ft./Color: Red/Connectors: RJ45 male ● Drastically reduce impedance and structural return loss compared to standard 100MHz wire ● High-quality copper wire and a staggered-pin plug design to keep near-end crosstalk levels to a minimumFeature molded connectors with integral strain relief ● Meets most current industry standards including IEEE 802.3ab, IEEE 802.5, ANSI/EIA/TIA 568, ISO/IEC 11801 and ETL (category 6 draft 11) ● PVC 4-pair stranded UTP ● Deliver stable performance up to 550MHz/1 Gbps Specifications OVERVIEW UPC Code 037332146106 Technology Cat6 PHYSICAL Cable Jacket Color Red Cable Jacket Material PVC Cable Jacket Rating CM Cable Shielding UTP 1/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Cable Outer Diameter (OD) 6.0 mm Number of Conductors 4 Pair Conductor Material Stranded Copper Conductor Gauge 24 AWG Cable Length (ft.) 1 Cable Length (m) 0.30 Cable Length (in.) 12 Cable Length (cm) 30.5 Shipping Dimensions (hwd / in.) 7.00 x 9.00 x 0.50 Shipping Dimensions (hwd / cm) 17.78 x 22.86 x 1.27 Shipping Weight (lbs.) 0.06 Shipping Weight (kg) 0.03 ENVIRONMENTAL Operating Temperature Range 14 to 122 F (-10 to 50 C) Storage Temperature Range 5 to 140 F (-15 to 60 C) Operating Humidity Range 0% to 90% RH, Non-Condensing Storage Humidity Range 0% to 90% RH, Non-Condensing COMMUNICATIONS Bandwidth per TIA Standard 250 MHz Maximum Bandwidth as Tested 500 MHz Network Compatibility 1 Gbps (Gigabit) IEEE Standards Supported 802.3an; 802.3at CONNECTIONS Side A - Connector 1 RJ45 (MALE) Side B - Connector 1 RJ45 (MALE) Crossover Wiring No Contact Plating Gold PoE Type Type 2 PoE+ (30W, IEEE 802.3at) Connector Type Snagless; Molded Wiring Configuration EIA/TIA 568B Angled Connector No FEATURES & SPECIFICATIONS IP68 Rated No 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Snagless Connector Yes Antibacterial No IP20 Rated No STANDARDS & COMPLIANCE Product Certifications UL Listed; cUL Listed Product Compliance CE (Europe); RoHS; IEEE 802.3an 10GBase-T; IEEE 802.3at PoE+; REACH; UKCA WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
N201-001-RD 价格&库存
很抱歉,暂时无法提供与“N201-001-RD”相匹配的价格&库存,您可以联系我们找货
