N201-002-GN
N201-002-GN
    TRIPPLITE
    N201-002-GN
N201-002-GN 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Cat6 Gigabit Snagless Molded (UTP) Ethernet Cable (RJ45 M/M), PoE, Green, 2 ft. (0.61 m) MODEL NUMBER: N201-002-GN Highlights ● Meets Category 6 cabling standards. ● Drastically reduce impedance and structural return loss compared to standard 100Mhz wire. ● High-quality copper wire and a shortened body plug design. ● Feature molded connectors with integral strain relief ● Snagless boots protect the locking tabs on the RJ45 connectors from being damaged during installation System Requirements ● For 1000 Base-T (1Gbps Ethernet), 10/100 Base-T (Ethernet), 100 Mbps TPDDI, 155 Mbps ATM, ISDN, voice and Token Ring TYPE 3 applications as well as EIA/TIA applications. Features Package Includes ● Meets category 6 cabling standards. ● Premium cabling for category 6, category 5e and category 5 applications ● Length: 2-ft. Color: green Connectors: RJ45 male ● Drastically reduce impedance and structural return loss compared to standard 100MHz wire ● High-quality copper wire and a staggered-pin plug design to keep near-end crosstalk levels to a minimum ● Feature molded connectors with integral strain relief ● Snagless design protects the locking tabs on the RJ45 connectors from being damaged or snapped off during installation ● PVC 4-pair stranded UTP ● Deliver stable performance up to 550MHz/1 Gbps communication ● Meets most current industry standards including IEEE 802.3ab, IEEE 802.5, ANSI/EIA/TIA 568, ISO/IEC 11801 and ETL (category 6 draft 11) ● Available in other colors and lengths ● Specifications OVERVIEW UPC Code 037332182609 Technology Cat6 PHYSICAL Cable Jacket Color Green 1/3 2-ft. Cat6 Green Gigabit Patch Cord Snagless Molded 1000 Eaton Boulevard Cleveland, OH 44122 United States Cable Jacket Material PVC Cable Jacket Rating CM Cable Shielding UTP Cable Outer Diameter (OD) 6.0 mm Number of Conductors 4 Pair Conductor Material Stranded Copper Conductor Gauge 24 AWG Cable Length (ft.) 2 Cable Length (m) 0.61 Cable Length (in.) 24 Cable Length (cm) 61 Shipping Dimensions (hwd / in.) 7.00 x 9.00 x 0.50 Shipping Dimensions (hwd / cm) 17.78 x 22.86 x 1.27 Shipping Weight (lbs.) 0.10 Shipping Weight (kg) 0.05 ENVIRONMENTAL Operating Temperature Range 14 to 122 F (-10 to 50 C) Storage Temperature Range 5 to 140 F (-15 to 60 C) Operating Humidity Range 0% to 90% RH, Non-Condensing Storage Humidity Range 0% to 90% RH, Non-Condensing COMMUNICATIONS Bandwidth per TIA Standard 250 MHz Maximum Bandwidth as Tested 500 MHz Network Compatibility 1 Gbps (Gigabit) IEEE Standards Supported 802.3an; 802.3at CONNECTIONS Side A - Connector 1 RJ45 (MALE) Side B - Connector 1 RJ45 (MALE) Crossover Wiring No Contact Plating Gold PoE Type Type 2 PoE+ (30W, IEEE 802.3at) Connector Type Snagless; Molded Wiring Configuration EIA/TIA 568B 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Angled Connector No FEATURES & SPECIFICATIONS IP68 Rated No Snagless Connector Yes Antibacterial No IP20 Rated No STANDARDS & COMPLIANCE Product Certifications UL Listed; cUL Listed Product Compliance CE (Europe); RoHS; IEEE 802.3an 10GBase-T; IEEE 802.3at PoE+; REACH; UKCA WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
N201-002-GN 价格&库存
很抱歉,暂时无法提供与“N201-002-GN”相匹配的价格&库存,您可以联系我们找货
