N201-020-RD
N201-020-RD
    TRIPPLITE
    N201-020-RD
N201-020-RD 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Cat6 Gigabit Snagless Molded (UTP) Ethernet Cable (RJ45 M/M), PoE, Red, 20 ft. (6.09 m) MODEL NUMBER: N201-020-RD Highlights ● Meets Category 6 cabling standards ● Meets most current industry standards including IEEE 802.3ab, IEEE 802.5, ANSI/EIA/TIA 568, ISO/IEC 11801, and ETL (Category 6, draft 11) ● Drastically reduce impedance and structural return loss compared to standard 100Mhz wire. ● Snagless boots protect the locking tabs on the RJ45 connectors from being damaged during installation ● Feature molded connectors with integral strain relief. Rated for 550 MHz/1 Gbps communication Package Includes 20-ft. (6.09 m) Cat6 Red Gigabit Patch Cord Snagless Molded Features ● Length: 20-ft. (6.09 m)/Color: Red /Connectors: RJ45 male ● Meets category 6 cabling standards ● Premium cabling for category 6, category 5e and category 5 applications ● High-quality copper wire and a staggered-pin plug design to keep near-end crosstalk levels to a minimum ● Feature molded connectors with integral strain relief ● Snagless design protects the locking tabs on the RJ45 connectors from being damaged or snapped off during installation ● PVC 4-pair stranded UTP Specifications OVERVIEW UPC Code 037332146205 Technology Cat6 PHYSICAL Cable Jacket Color Red Cable Jacket Material PVC Cable Jacket Rating CM Cable Shielding UTP Cable Outer Diameter (OD) 6.0 mm 1/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Number of Conductors 4 Pair Conductor Material Stranded Copper Conductor Gauge 24 AWG Cable Length (ft.) 20 Cable Length (m) 6.10 Cable Length (in.) 240 Cable Length (cm) 609.6 Shipping Dimensions (hwd / in.) 11.00 x 7.00 x 0.50 Shipping Dimensions (hwd / cm) 27.94 x 17.78 x 1.27 Shipping Weight (lbs.) 0.56 Shipping Weight (kg) 0.25 ENVIRONMENTAL Operating Temperature Range 14 to 122 F (-10 to 50 C) Storage Temperature Range 5 to 140 F (-15 to 60 C) Operating Humidity Range 0% to 90% RH, Non-Condensing Storage Humidity Range 0% to 90% RH, Non-Condensing COMMUNICATIONS Bandwidth per TIA Standard 250 MHz Maximum Bandwidth as Tested 500 MHz Network Compatibility 1 Gbps (Gigabit) IEEE Standards Supported 802.3an; 802.3at CONNECTIONS Side A - Connector 1 RJ45 (MALE) Side B - Connector 1 RJ45 (MALE) Crossover Wiring No Contact Plating Gold PoE Type Type 2 PoE+ (30W, IEEE 802.3at) Connector Type Snagless; Molded Wiring Configuration EIA/TIA 568B Angled Connector No FEATURES & SPECIFICATIONS IP68 Rated No Snagless Connector Yes 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Antibacterial No STANDARDS & COMPLIANCE Product Certifications UL Listed; cUL Listed Product Compliance CE (Europe); RoHS; IEEE 802.3an 10GBase-T; IEEE 802.3at PoE+; REACH; UKCA WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
N201-020-RD 价格&库存
很抱歉,暂时无法提供与“N201-020-RD”相匹配的价格&库存,您可以联系我们找货
