N201-025-BL-FL
N201-025-BL-FL
    TRIPPLITE
    N201-025-BL-FL
N201-025-BL-FL 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Cat6 Gigabit Snagless Molded Flat (UTP) Ethernet Cable (RJ45 M/M), PoE, Blue, 25 ft. (7.62 m) MODEL NUMBER: N201-025-BL-FL Highlights ● Thin, Flat flexible cable for confined spaces ● Meets Category 6 cabling standards ● High-quality copper wire and a shortened body plug design ● Feature molded connectors with integral strain relief System Requirements ● For 1000 Base-T (1Gbps Ethernet), 10/100 Base-T (Ethernet), 100 Mbps TPDDI, 155 Mbps ATM, ISDN, voice and Token Ring TYPE 3 applications as well as EIA/TIA applications. Package Includes ● Features ● Thin, Flat flexible cable for confined spaces ● Meets Category 6 cabling standards ● High-quality copper wire and a shortened body plug design ● Feature molded connectors with integral strain relief ● EIA/TIA 568 Compliant ● Up to 1Gbps transfer rates Specifications OVERVIEW UPC Code 037332151605 Technology Cat6 PHYSICAL Cable Jacket Color Blue Cable Jacket Material PVC Cable Jacket Rating CM Cable Shielding UTP Cable Outer Diameter (OD) 6.0 mm Number of Conductors 4 Pair 1/3 25-ft. (7.62 m) Blue Flat Cat6 Molded Patch Cable 1000 Eaton Boulevard Cleveland, OH 44122 United States Conductor Material Stranded Copper Conductor Gauge 32 AWG Cable Length (ft.) 25 Cable Length (m) 7.62 Cable Length (in.) 300 Cable Length (cm) 762 Shipping Dimensions (hwd / in.) 0.25 x 5.80 x 7.40 Shipping Dimensions (hwd / cm) 0.64 x 14.73 x 18.80 Shipping Weight (lbs.) 0.20 Shipping Weight (kg) 0.09 ENVIRONMENTAL Operating Temperature Range 14 to 122 F (-10 to 50 C) Storage Temperature Range 5 to 140 F (-15 to 60 C) Operating Humidity Range 0% to 90% RH, Non-Condensing Storage Humidity Range 0% to 90% RH, Non-Condensing COMMUNICATIONS Bandwidth per TIA Standard 250 MHz Maximum Bandwidth as Tested 500 MHz Network Compatibility 1 Gbps (Gigabit) IEEE Standards Supported 802.3an; 802.3at CONNECTIONS Side A - Connector 1 RJ45 (MALE) Side B - Connector 1 RJ45 (MALE) Crossover Wiring No Contact Plating Gold PoE Type Type 2 PoE+ (30W, IEEE 802.3at) Connector Type Snagless; Molded Wiring Configuration EIA/TIA 568B Angled Connector No FEATURES & SPECIFICATIONS IP68 Rated No Snagless Connector Yes Antibacterial No 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States STANDARDS & COMPLIANCE Product Certifications UL Listed; cUL Listed Product Compliance CE (Europe); RoHS; IEEE 802.3an 10GBase-T; IEEE 802.3at PoE+; REACH; UKCA WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
N201-025-BL-FL 价格&库存
很抱歉,暂时无法提供与“N201-025-BL-FL”相匹配的价格&库存,您可以联系我们找货
