HIF2E-30D-2.54RB
HIF2E-30D-2.54RB
    HRS(广濑)
HIF2E-30D-2.54RB 数据手册
2.54mm Connectors Directly Mounted on Board HIF2E Series ■Features 1. Directly Mounted on Board This connector can be directly mounted on the board using the 1.27mm pitch flat cable. 2. Variation in Number of Contacts 10, 14, 16, 20, 26, 30, 34, 40, 50, and 60 contacts, are available Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 3. Applicable Cable The applicable cable is UL2651 28 AWG flat cable (7 cores/0.127mm, jacket dia. : 0.8 to 1.0mm). ■Product Specifications Operating Temperature Range : –55 to +85ç (Note 1) Storage Temperature Range : –10 to +60ç (Note 2) Current rating : 1A Rating Voltage rating : 200V AC Operating Moisture Range : 40 to 80% Item 1. Insulation Resistance Storage Humidity Range Specification : 40 to 70% (Note 2) Condition 1000MΩ min 500V DC 2. Withstanding voltage No flashover or insulation breakdown. 650V AC/1 minute 3. Contact Resistance 15mΩ max 0.1A 4. Vibration No electrical discontinuity of 1μs or more Frequency: 10 to 55 Hz, single amplitude of 0.75 mm, 2 hours in each of the 3 directions. 5. Humidity (Steady state) Insulation resistance : 1000MΩ min. 6. Temperature Cycle 96 hours at temperature of 40ç and humidity of 90% to 95% (-65ç : 30 minutes ➝ 15 to 35ç : 5 minutes max. No damage, cracks, or parts looseness. 125ç : 30 minutes ➝ 15 to 35ç : 5 minutes max.) 5 cycles 7. Resistance to Soldering heat No deformation of components affecting performance. Solder bath : 260ç for 10 seconds Manual soldering : 360ç for 5 seconds Note 1 : Includes temperature rise caused by current flow. Note 2 : The term "storage" refers to products stored for long period of time prior to mounting and use. Operating Temperature Range and Humidity range covers non conducting condition of installed connectors in storage, shipment or during transportation. ■Materials / Finish Part Material Finish HIF2E-*D-2.54R B HIF2E-*D-2.54R A Black Gray Insulator PBT Contact Copper alloy Gold plated over nickel underplated Remarks UL94V-0 –––––– ■ Product Number Structure Refer to the chart below when determining the product specifications from the product number. Please select from the product numbers listed in this catalog when placing orders. HIF2E - * D - 2.54 RB q q Series Name w Number of Contacts e Contact alignment r Contact Pitch w e r t : HIF2E t Connection method and contact plating type : 10, 14, 16, 20, 26, 30, 34, 40, 50, and 60 RB : Universal type circuit plated RA : Hirose original circuit plated : D : Double : 2.54mm B9 HIF2E Series●2.54mm Connector Directly Mounted on Board Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ■Combination Pattern Unit : mm 10 contacts 14 contacts 16 contacts 20 contacts 26 contacts 30 contacts 34 contacts 40 contacts 50 contacts 60 contacts A 17.17 22.25 24.79 29.87 37.49 42.57 47.65 55.27 67.97 80.67 B 10.16 15.24 17.78 22.86 30.48 35.56 40.64 48.26 60.96 73.66 BPCB mounting pattern A: Total pitch of connectors n: Number of contacts Through-hole finish hole diameter on printed board: 0.9 +0.1 +0 B10 HIF2E Series●2.54mm Connector Directly Mounted on Board Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ■Universal Circuit Type (Mold color: black) Unit : mm Part No. HIF2E-10D-2.54RB(20) HIF2E-14D-2.54RB(20) HIF2E-16D-2.54RB(20) HIF2E-20D-2.54RB(20) HIF2E-26D-2.54RB(20) HIF2E-30D-2.54RB(20) HIF2E-34D-2.54RB(20) HIF2E-40D-2.54RB(20) HIF2E-50D-2.54RB(20) HIF2E-60D-2.54RB(20) HRS No. No. of Contacts 10 561-0601-1 20 14 561-0602-4 20 16 561-0603-7 20 20 561-0604-0 20 26 561-0605-2 20 30 561-0606-5 20 34 561-0607-8 20 40 561-0608-0 20 50 561-0609-3 20 60 561-0610-2 20 A 17.17 22.25 24.79 29.87 37.49 42.57 47.65 55.27 67.97 80.67 B RoHS 10.16 15.24 17.78 22.86 30.48 YES 35.56 40.64 48.26 60.96 73.66 ■Hirose Original Circuit Type (Mold color: gray) Unit : mm Part No. HIF2E-10D-2.54RA(20) HIF2E-14D-2.54RA(20) HIF2E-16D-2.54RA(20) HIF2E-20D-2.54RA(20) HIF2E-26D-2.54RA(20) HIF2E-30D-2.54RA(20) HIF2E-34D-2.54RA(20) HIF2E-40D-2.54RA(20) HIF2E-50D-2.54RA(20) HIF2E-60D-2.54RA(20) HRS No. No. of Contacts 10 561-0501-7 20 14 561-0502-0 20 16 561-0503-2 20 20 561-0504-5 20 26 561-0505-8 20 30 561-0506-0 20 34 561-0507-3 20 40 561-0508-6 20 50 561-0509-9 20 60 561-0510-8 20 A 17.17 22.25 24.79 29.87 37.49 42.57 47.65 55.27 67.97 80.67 B RoHS 10.16 15.24 17.78 22.86 30.48 YES 35.56 40.64 48.26 60.96 73.66 B11 HIF2E Series●2.54mm Connector Directly Mounted on Board BConnection Circuit Diagram HIF2E-*D-2.54RB Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ●Type A-A ●Type A-B HIF2E-*D-2.54RA ●Type A-A ●Type A-B Note: In the above circuit connection diagram, the mark and character marking directions are optional. B12
HIF2E-30D-2.54RB
物料型号:HIF2E系列
器件简介:HIF2E系列连接器可以直接通过1.27mm间距的扁平电缆安装在PCB板上。提供10至60个接触点的多种选择。
引脚分配:接触点数量有10, 14, 16, 20, 26, 30, 34, 40, 50, 和 60个接触点。
参数特性: - 电流额定值:1A - 工作温度范围:-55至+85°C - 存储温度范围:-10至+60°C - 绝缘电阻:最小1000MΩ - 耐电压:无闪络或绝缘击穿,650V AC/1分钟 - 接触电阻:最大15mΩ - 振动测试:在10至55Hz频率下,振幅0.75mm,每个方向2小时,无电气中断超过1秒 - 湿热测试:在40°C和90至95%湿度下96小时,绝缘电阻最小1000MΩ - 温度循环测试:(-65°C:30分钟 → 15至35°C:最多5分钟 → 125°C:30分钟 → 15至35°C:最多5分钟),5个周期,无损坏、裂纹或零件松动 - 耐焊接热:无影响性能的组件变形,260°C焊料浴10秒或手工焊接360°C 5秒
功能详解:HIF2E系列连接器设计用于直接安装在PCB板上,适用于需要频繁插拔的应用场景,具有优良的电气和机械性能。
应用信息:适用于需要频繁插拔的电子设备,如测试设备、测量设备等。
封装信息: - 绝缘体材料:PBT - 表面处理:UL94V-0等级 - 接触材料:铜合金,表面镀金,底层镀镍 - 产品编号结构:提供了详细的产品编号规则,以确定产品规格。
HIF2E-30D-2.54RB 价格&库存
很抱歉,暂时无法提供与“HIF2E-30D-2.54RB”相匹配的价格&库存,您可以联系我们找货
